Holm-z's TJ build... work in progress - Page 16 - JeepForum.com
post #226 of 293 Old 10-05-2013, 11:09 AM Thread Starter
Holm-z
Finally got my new wheel bearings on last night!! Drivers side was definitely on its last leg.. Now the front end is done!!!
Now the next thing I have to do is replace both front fog lightbulbs in my KC day lighters. Ordere the bulbs today 15 bucks a piece and will be in on Monday.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #227 of 293 Old 10-10-2013, 11:27 AM Thread Starter
Holm-z
The bulbs ended up being 11.99 a piece, so that made me happy . But when I took the jeep out for a test spin, the freakin mirror fell out of the casing and smashed in the roadway! So I went and bought a small 5" round mirror that fits into the aftermarket bracket. Drove it to work in Keene last night and I'm impressed!!! She drives ok!! Still having some transmission problems but hopefully that will be solve when I do the mml and new fluid in the tranny.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #228 of 293 Old 10-18-2013, 04:57 PM Thread Starter
Holm-z
Got it inspected today, Yaahooooo!!!! Now I don't have to worry about the state troopers when I pass them!!
Still have to do the mml, in another week or so I should get a chance to install it. Also got my truck back from the repair shop... Looks like new! Hopefully it stays that way for a while.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #229 of 293 Old 12-07-2013, 03:37 PM Thread Starter
Holm-z
Well, not much progress on the Jeep... Still having a clutch/transmission issue. When the clutch is pressed all the way in its fine, but when I let off in Neutral, the transmission is trying to grab and pull forward. Still havent done the the MML, so im hoping it just needs adjusting. If that doesnt fix it, ill have to start a winter project and im not looking forward to that!
I did take it out and drive it around the other day. Thankfully everything else we did over the summer is holding up and feeling ok.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #230 of 293 Old 03-10-2014, 08:54 PM Thread Starter
Holm-z
Took it out and drove it for about an hour yesterday... Still having some shifting issues but she fired right up with no hesitation and felt good driving otherwise. We have one more snowstorm moving in this week so im not done snowmobiling for the year that means my jeep will have to wait a few more weeks before I start focusing my attention on her.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #231 of 293 Old 04-26-2014, 04:20 PM Thread Starter
Holm-z
Pulled the jeep out again the other day and bought some up/down stream o2 sensors. Started PB blasting them and then tried to replace the upper sensor...
NOPE!! They are pretty much welded on there. Stripped the nut on it and even used a propane torch for some heat... Still nothing...
Next step is to get it up on a lift and use a oxy acetelyne torch to heat it up.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #232 of 293 Old 05-23-2014, 04:17 PM Thread Starter
Holm-z
Well I finally got around to getting the upstream O2 sensor out... End up having to use an oxy-acyeteline torch to get it hot enough to break free. Once we got that on, started her up and no sputtering!!! Finally!
Cleared the code and onto the next project of the day, MML. That wasn't too bad to do, didn't have to use the torches on those! It took a little muscle to move the engine to the exact bolt alignment holes at first but other than that it was a breeze.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #233 of 293 Old 05-23-2014, 04:46 PM Thread Starter
Holm-z
Few more driveway pics. My buddy backed his TJ next to mine for comparison. He's deciding on a lift to hopefully do this summer.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #234 of 293 Old 05-24-2014, 04:59 PM
HighRoller02TJ
looks good
HighRoller02TJ is offline
post #235 of 293 Old 05-27-2014, 03:03 PM Thread Starter
Holm-z
Originally Posted by HighRoller02TJ View Post
looks good
Thanks man
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #236 of 293 Old 05-27-2014, 03:15 PM Thread Starter
Holm-z
Went out for a little spin in woods the other day
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #237 of 293 Old 05-27-2014, 03:41 PM Thread Starter
Holm-z
This also showed up today...
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #238 of 293 Old 05-27-2014, 04:05 PM Thread Starter
Holm-z
Now for the install!!!!!
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #239 of 293 Old 05-29-2014, 08:28 PM Thread Starter
Holm-z
Well I got the Winch all mounted up and secured and started the wiring yesterday... Thought I got it all worked out and went to start my jeep and nothing. No power to the jeep whatsoever. Tried to even jump start it and it wouldn't turn over. So I Brought out the battery charger and charged it over night. When i went to start it this morning... same thing.. nothing, no power at all. So i ripped the old battery out and put it this one.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #240 of 293 Old 05-29-2014, 08:33 PM Thread Starter
Holm-z
So once I got the new one hooked up and go to start it, All my lights work and it turns over but wont fire. Now this is without the winch hooked up at all, just the normal connections. I noticed when I turn the key to "on" the fuel pump doesn't turn on and no pressure at the fuel rail. So im thinking some sort of wiring issue or a blown fuse. I went over every possible fuse I could find and all of them are still good... Not sure where to turn now!!
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
1998 , nh , sport , tj , wrangler
My 97 TJ Build Current Work in Progress TinkerAB Jeep Builds 12 08-20-2011 03:55 PM
A Work in Progress... 04TJrubicon Jeep Builds 7 12-11-2009 09:18 AM
My 98 TJ, work in progress alex32TJ Jeep Builds 3 09-01-2009 01:04 PM
Another build in progress. AZ Bulldog Jeep Builds 5 12-04-2007 05:04 PM
Work in progress jeepnurse Jeep Builds 5 05-15-2006 08:32 AM
