Holm-z's TJ build... work in progress - Page 10 - JeepForum.com
post #136 of 293 Old 04-06-2013, 05:27 PM Thread Starter
Holm-z
Originally Posted by G Beasley
Just finished your thread , I am so glad I live in the south and we dont have the rust to fight like you guys do . It was funny to see Rutland mentioned as I stayed there for a few months when I was working in South Royalton . Anyways , keep up the good work the switches turned out awesome .
Thanks man! Yeah rust is such a pita!! It's on just about every car truck trailer around up here.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #137 of 293 Old 04-18-2013, 09:55 AM
Rubicon0311
Have you done your Monstaliner yet??
Rubicon0311 is offline
post #138 of 293 Old 04-21-2013, 07:10 AM
HighRoller02TJ
i still have the bestop windjammer and tonneau cover to give you. if i decide to go to go topless day NH i can give them to you then, im not sure if im going or not. how about you?
HighRoller02TJ is offline
post #139 of 293 Old 04-23-2013, 07:36 PM Thread Starter
Holm-z
Hey guys, sorry been busy with work as well as working on the race cars. I've sanded, washed then sanded the spots I missed the other day. Tonight was the first coat of rustoleum primer.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #140 of 293 Old 04-23-2013, 07:46 PM Thread Starter
Holm-z
Nice dude, thanks. I'm planning on going with my jeep if I can get it inspected by then, if not I may or may not go, depending on what else I got going on. Hopefully once race season starts, the cars will be on the trailers and my other garage bay will be open, If you still want to do that body lift.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #141 of 293 Old 04-23-2013, 07:48 PM
Rubicon0311
Put the Monstaliner on THICK! I didn't do so when I did my tub, I wasn't sure if I would have enough. Boy was I wrong.
post #142 of 293 Old 04-23-2013, 09:58 PM
HighRoller02TJ
Nice. Ive been soaking the bolts everyday. Before i install the lift i want to take every body mount bolt out and back in so when the lift is installed there is no dealing with broken bolts. so far i have 1 rear broken bolt to remove and the front body mount came out clean. working on the sides this week
post #143 of 293 Old 04-24-2013, 04:36 PM Thread Starter
Holm-z
Second coat of rustoleum on tonight. Looks really good, now I just got to order the monstaliner!
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #144 of 293 Old 04-25-2013, 11:05 AM Thread Starter
Holm-z
Did you get the 1 gallon kit? I think that's all i will need for the interior tub.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #145 of 293 Old 04-25-2013, 11:38 AM
goducks3620
you might want to pry out one of those metal drain plugs on each rear passenger well, that is what I did on mine before monstalining it. The JK oval plugs will fit in there and you'll want some drainage options back there.
goducks3620 is offline
post #146 of 293 Old 04-25-2013, 11:46 AM Thread Starter
Holm-z
I can pry them off? I was just gonna drill a 1" round hole in it and use the same plugs as the front. Ill have to go out and see cause that may work better, thanks for the tip
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #147 of 293 Old 04-25-2013, 11:47 AM
Rubicon0311
Yep, 1 gallon is plenty, I didn't put it on thick enough and had a bunch left over.
post #148 of 293 Old 04-25-2013, 11:50 AM
goducks3620
look underneath the jeep. each is held on with two metal tabs, once you pry them back, you can either pop it out from underneath or from top or both. The passenger one is above the heat shield so from top is easier there, once you open up the tabs from the side.
post #149 of 293 Old 04-25-2013, 11:58 AM
goducks3620
also, it'll roll easier if you remove those seat belt brackets and rear seat brackets. just put some earplugs or twisted paper in the holes. just take pictures so you can remember how to reassemble them
you can see how I did mine in post #201 on the "Monstaliner interiors and exteriors" thread if that helps.
post #150 of 293 Old 04-25-2013, 06:14 PM Thread Starter
Holm-z
Yeah I did remove the rear seat/seat belt/tailgate brackets as well as the seat belt retensioners, just haven't taken a pic of that yet. 3 of the rear seat bracket bolts broke, so I bought some 1" grade 8 bolts and washers/locknuts to use for when I re-install it. Im also going to be putting in seat risers in my front seats as well.
Im going to use earplugs but i don't have as many as I thought so Ill have to grab another packet. Ordered Monstaliner this morning so hopefully next week I'll be laying that in.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
1998 , nh , sport , tj , wrangler
My 97 TJ Build Current Work in Progress TinkerAB Jeep Builds 12 08-20-2011 03:55 PM
A Work in Progress... 04TJrubicon Jeep Builds 7 12-11-2009 09:18 AM
My 98 TJ, work in progress alex32TJ Jeep Builds 3 09-01-2009 01:04 PM
Another build in progress. AZ Bulldog Jeep Builds 5 12-04-2007 05:04 PM
Work in progress jeepnurse Jeep Builds 5 05-15-2006 08:32 AM
