A Hokies 04' TJ build - Page 8 - JeepForum.com
post #106 of 724 Old 04-18-2013, 03:28 PM Thread Starter
jeepinhokie
Got the new camshaft synchronizer and Clayton 3 link bridge in the mail today.
Pretty nice welds and it looks like it should fit nicely.
Also ordered a bunch of wiring supplies for the rubi pumps. Need to order switches tomorrow for the dash from OTRATTW.
HOKIES UNITED!
jeepinhokie is offline
post #107 of 724 Old 04-18-2013, 05:47 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Glad to see you back at it!
gst95dsm is offline
post #108 of 724 Old 04-18-2013, 07:34 PM Thread Starter
jeepinhokie
In the garage tonight I discovered one of the locker pumps isn't working like the other. Opened it up and found a line on the circuit board is toast. When I jumper the line the pump works like it is supposed to. Going to take it into work tomorrow and try to see if any of the nerds at work can solder a jumper into the circuit board to save the pump.
HOKIES UNITED!
post #109 of 724 Old 04-18-2013, 08:01 PM Thread Starter
jeepinhokie
In other news, I ordered 8 of these for the rear! OUCH! . I will need 6 more for the front when the time comes.
Just need to get some weld in bungs for the joints since metalcloak doesn't sell any. Probably going to order all 14 bungs and a front track bar from savvy.
HOKIES UNITED!
post #110 of 724 Old 04-18-2013, 09:09 PM
G Beasley
The Metal Cloak bushings/arms are popping up everywhere ! Hopefully you caj get the pump fixed .
G Beasley is offline
post #111 of 724 Old 04-18-2013, 10:16 PM
gst95dsm
gst95dsm's Avatar
It's a sign Beasley.... don't be the last guy with JJ's. Haha j/k. Nice purchase jeepinhokie!
gst95dsm is offline
post #112 of 724 Old 04-19-2013, 05:20 AM Thread Starter
jeepinhokie
I was on the fence about them. one day I was all JJs b/c i dont need MCs joints, the next day I was back to MCs joint. Tax refund being bigger than I expected settled that argument for me.
I feel that either the JJ or the Duroflex joint will be a huge imporvement over stock arms. the fact that I am going to redo the suspension probably will have more of an impact than either joint would. But for the extra $100 or so I figured I would give them a shot since i am trying to retain as much road manners as possible. everything i have read seems to indicate that the joints are just as tight as JJ but soak up a bit more road vibration. I will have no direct comparison to JJs to base my reviews on, but i have high hopes based on Impeds review.
The pump should be fixed here shortly. working for a special communications division of the DoD has its perks.
HOKIES UNITED!
post #113 of 724 Old 04-19-2013, 07:04 AM
srfnfly227
Glad to see things moving along buddy. Good choice on the control arms. I think you'll be happy.
Savvy 3" Springs, 4 Link rear with outboarded shocks, Savvy UnderArmor, 255/85R16 Toyo M/T
srfnfly227 is offline
post #114 of 724 Old 04-19-2013, 07:24 AM
srfnfly227
post #115 of 724 Old 04-19-2013, 07:31 AM Thread Starter
jeepinhokie
Lee that's pretty accurate... if only i could edit a JF screen on the monitor....
actually its been pretty busy around here lately. I think everyone is trying to prove their worth with all the budget cuts looming.
Got the locker pump fixed in one of the EE labs. should be good to go.
HOKIES UNITED!
post #116 of 724 Old 04-19-2013, 07:52 AM
G Beasley
Nice fix , tell the tech he has a future in Jeep pump repairs if the cuts hit yall .
post #117 of 724 Old 04-19-2013, 08:03 AM Thread Starter
jeepinhokie
I have not, but have you seen this failure before?
HOKIES UNITED!
post #118 of 724 Old 04-19-2013, 10:03 AM Thread Starter
jeepinhokie
ordered threaded weld in bungs from Ruffstuff. These ones are a bit more expensive than the cheaper currie ones savvy sells, but they have hex heads instead of the round currie ones. Savvy sells hex head threded inserts that come with Jam nuts, but they are $10 more per insert. The MC joints I bought come with Jam nuts so i dont need to buy them elsewhere which is nice b/c they can be expensive.
Hex heads will make tightening the jam nuts down easier without having to use a pipe wrench on the control arm.
HOKIES UNITED!
post #119 of 724 Old 04-19-2013, 05:12 PM
G Beasley
Its a solid pump from my experience but I have seen a few that were cooked and a few that had broken nipples .
post #120 of 724 Old 04-22-2013, 06:21 AM Thread Starter
jeepinhokie
thats the same impression i have of these pumps. I just had never heard of anyone pulling the cover off the bottom of the pump and finding the same damage I found. trying to figure out that the PO did to fry the pump.
either way hopefully i dont have any problems with my fix.
build update:
got a call from Will at Metalcloak saturday saying that the joints will ship in 3-4 weeks. the final countdown to build time begins.
I still need to work on the brake lines, flip the backing plates, install and wire the locker pumps, and pick up a pinion seal for the new 1310 yoke. I also need to get an exhaust shop identified to reroute the exhaust post 4 link.
i'm sure there is more...
HOKIES UNITED!
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
