A Hokies 04' TJ build - Page 5 - JeepForum.com
post #61 of 733 Old 10-18-2012, 11:29 AM Thread Starter
jeepinhokie
Originally Posted by ctorres018
Did you run the SYE without a new drive shaft for a while ?
Yes. With the Aussie up front it wasn't ideal but nothing "bad" will happen.
Just have front 2 wheel drive.
HOKIES UNITED!
jeepinhokie is offline
post #62 of 733 Old 10-18-2012, 11:45 AM
ctorres018
1930 JK Wrangler
So I wouldn't be able to have 4 wheel drive ?
ctorres018 is offline
post #63 of 733 Old 10-19-2012, 05:33 AM Thread Starter
jeepinhokie
not until you put a new cv style rear driveshaft in... which if your putting in a SYE you would need to do anyway.
most people install the SYE, then measure for a new DS and custom order one. the time in between installing the SYE and when the new DS comes in you will need to drive around in 4wd, but with rear DS absent you will be driving around on only the front two wheels.
HOKIES UNITED!
post #64 of 733 Old 11-12-2012, 06:47 AM Thread Starter
jeepinhokie
contemplating a regear and axle swap... stay tuned.
picked up Rubi 44's from an 06. 4.88's, chromoly shafts, HD diff covers, rear truss for 4 link.
both axles need some work before i can throw them under the ol' Jeep.
for the rear i'm going to do a 4 link with poly performance brackets, probably outboarding the rear shocks while i'm at it. (going for something similar to Imped)
front is currently set up for a 4 link and I will revert that back to either a stock type set up or a 3 link (again think Imped). it has a teraflex high steer kit on it that is probably coming off in favor of my correctlync.
Its going to be alot of work to do it all, but it should set me up for several years (while i focus on other aspects of the jeep).
HOKIES UNITED!
post #65 of 733 Old 11-14-2012, 09:32 AM
srfnfly227
That's awesome buddy! Can't wait to see it all come together.
Savvy 3" Springs, 4 Link rear with outboarded shocks, Savvy UnderArmor, 255/85R16 Toyo M/T
srfnfly227 is offline
post #66 of 733 Old 11-14-2012, 10:00 AM Thread Starter
jeepinhokie
Thanks Lee,
You missed another great run to Rausch. Nothing too crazy and for once i think i made it through a wheeling trip without damaging anything. (i havent washed it yet, so we shall see if that holds true)
Starting to wonder if i got myself in over my head with the axle swap. but i'm sure Ill work it out.
Tenative plan as of now is to have it completed by late April, maybe in time for wheelin for hope. fingers crossed.
I need to figure out which bracketry i will be using. leaning toward Poly Performance, but there are other companies out there that make compariable bracketes for less, like Artec Industries and Barnes 4x4. most likely I will need a little something from everywhere.
also thinking about adding a Savvy GTS to the list of mods. the truss and diff cover are fairly large, so i might need a little more room out back.
first order of business is to finish some woodworking projects so i can have time/space to work on them, then get the axles in my garage stripped down. Ill clean them up and replace unit bearings, ball joints, u-joints, swap yokes, pinion seals, etc. then get them prepped for install. probably going to install the rear first and get the jeep drivable; then tackle the front later.
should be an interesting experience.
HOKIES UNITED!
post #67 of 733 Old 11-26-2012, 03:10 PM Thread Starter
jeepinhokie
Got some pictures of the axles. After the new years they get stripped down, wire wheeled and painted.
Probably going to sell the steering and wheel spacers
Should be a fun spring project.
image-1449965162.jpg   image-767067876.jpg   image-3901059974.jpg   image-2559415488.jpg   image-3467584343.jpg
HOKIES UNITED!
post #68 of 733 Old 11-26-2012, 03:33 PM Thread Starter
jeepinhokie
a few pictures from my past trip to Rausch Creek for the HRC Turkey Run (Nov 9,10,11).
more pictures and the obligatory video at a later date.
HOKIES UNITED!
post #69 of 733 Old 01-08-2013, 01:58 PM Thread Starter
jeepinhokie
I got the video finished a few weeks ago, just getting around to posting it here.
almost done with woodworking for the winter and will be moving the Rubicon 44's into the garage to be stripped down and overhauled before slapping them under the Jeep. 3 link front and 4 link rear.
stay tuned...
HOKIES UNITED!
post #70 of 733 Old 01-08-2013, 05:52 PM
midnight_f150
Great video. Jeep looks great you are doing a great job on it.
midnight_f150 is offline
post #71 of 733 Old 01-08-2013, 06:10 PM Thread Starter
jeepinhokie
Since thanksgiving I have been in woodworking mode. Starting with a rocking horse for a friends baby.
Then onto cutting boards for Christmas presents. I made 8 in total. They are maple and walnut end grain boards.
Then into a boat cradle for my father in laws new PT boat.
Then some quick trays for on top of dressers or coffee tables etc.
Then a sipo mahognany hall table with matching picture frame for myself.
I'm almost finished with the picture frame. That's what's been holding me up from digging into the axles. I have too many hobbies and not enough garage space to fit them all. So one hobby at a time will have to do for now.
HOKIES UNITED!
post #72 of 733 Old 01-27-2013, 04:18 PM Thread Starter
jeepinhokie
Got the axles moved into the garage and started to strip them down. More work over the next few days.
Ordering parts for the rear 4 link and rebuild of the front. Going to do this in two stages. Rear 4 link first, and front on stock control arms. Stage two is 3 link for the front. Maybe 2-3 months after the rear is finished.
Going to post the teraflex high steer kit for sale in the next few days.
HOKIES UNITED!
post #73 of 733 Old 01-27-2013, 08:52 PM
reichard117
2014 JK Wrangler
looks like some very well done craftsmanship. jeep and wood. looking forward to seeing these axles under your jeep
reichard117 is offline
post #74 of 733 Old 01-28-2013, 05:39 AM Thread Starter
jeepinhokie
Thanks,
i should finally be making some good progress on these over the next few weeks. now to break out the credit card... to the wife
HOKIES UNITED!
post #75 of 733 Old 01-28-2013, 07:57 PM Thread Starter
jeepinhokie
Very little time in the garage tonight but did manage to get the teraflex high steer knuckle off and cleaned up a little. Need to post it for sale tomorrow.
HOKIES UNITED!
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
