A Hokies 04' TJ build - Page 23 - JeepForum.com
post #331 of 733 Old 01-08-2014, 12:23 PM
jeepster1407
Awesome build man! I love the cross-member! I may try and steal your design if you don't mind!
_________
My Thread -
jeepster1407 is offline
post #332 of 733 Old 01-08-2014, 12:56 PM Thread Starter
jeepinhokie
thanks
the crossmember is very nice to have. I can drop the skids if i need to and not worry about having to put them back on right away.
there are more vibrations inside the cab with the crossmember. the rubber brown dog bushings helped out alot though. there is just no substitute for isolating vibrations than the huge chunk of rubber from the OEM mount.
your TJ looks nice too, I like the pieces you have fabbed yourself. As you can see i'm a do it myself type guy too.
HOKIES UNITED!
jeepinhokie is offline
post #333 of 733 Old 01-09-2014, 11:47 AM Thread Starter
jeepinhokie
going to drop this here for future reference. replica of genright mini boatsides; I plan on building something similar. http://www.jeepforum.com/forum/f37/t...ockers-894976/
I should be able to do it for less than $200 vs $500 from genright.
also plan on building a body mounted swing away tire carrier something kind of like this... with my own changes.
HOKIES UNITED!
post #334 of 733 Old 01-15-2014, 06:18 PM Thread Starter
jeepinhokie
Extinguishers came in the mail today. Mount is back ordered for a week.
Just need to figure out a mount for mine.
HOKIES UNITED!
post #335 of 733 Old 02-05-2014, 09:37 AM
AllTerrainJK
I saw your 3 link pics in the MC duroflex thread and searched for this build thread. I will be fabbing a 3 and 4 link suspension system so I'm doing research. I'm at the point where you replaced the urethane crossmember bushings with BD rubber. I recently purchased the Ruff Stuff bushing kit to replace my UCF lowpro mount and skid. The idle vibes are very annoying. Do you know if RS changed to rubber or are they still urethane? I didn't even think to check when I ordered them. From the things I have read so far you have done a great job on your build. Looking forward to reading the rest.
Roads? Where we're going we don't need roads!
AllTerrainJK is offline
post #336 of 733 Old 02-05-2014, 09:54 AM Thread Starter
jeepinhokie
i never heard back from Ruff Stuff on partnering with Brown Dog to provide rubber bushings in their kit; so I have to imagine they did not. from everything I learned, the rubber bushings are much more expensive to produce than the poly ones, which is why I had a bit of a hard time finding rubber ones.
The guys at Brown Dog were great to work with and very helpful. while the vibes arent gone 100% they are much less evident.
i've been thining about trying to add a third rubber mount in the center of my crossmember where it connects with the trans. i dont think it would harm anything, but i'm also not sure it would help much either.
HOKIES UNITED!
post #337 of 733 Old 02-05-2014, 03:10 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
I was told when I was researching for my trans mount that two bushings at the frame was plenty. Adding another would provide too much movement in the design.
Either hard mount the crossmember to the frame with one bushing, or mount two bushings at the frame and hard mount the trans to the crossmember.
Mail crawling.
MisfitSeven is offline
post #338 of 733 Old 02-05-2014, 04:16 PM Thread Starter
jeepinhokie
That's the way I designed mine. Two at the frame. Just thinking out loud really. Now that you mention the movement aspect of it all, I wouldn't want to do 3. Good call.
HOKIES UNITED!
post #339 of 733 Old 02-05-2014, 07:05 PM Thread Starter
jeepinhokie
Got my fire extinguisher mounted this evening. Bolted straight to the seat frame with grade 8 bolts. Easily accessible and hopefully plenty out of the way. If I find myself hitting it, I'll move it. As of now I think it'll be fine.
Tiny zip ties hold the latches closed securely. They easily break if the extinguisher is needed.
HOKIES UNITED!
post #340 of 733 Old 02-06-2014, 06:07 AM
AllTerrainJK
I'm finally caught up to present on your build. Very nicely done. I have a couple questions if you don't mind. How did you come up with the placement for the frame side brackets? Did you design the geometry using a link calculator?
post #341 of 733 Old 02-06-2014, 07:12 AM Thread Starter
jeepinhokie
the frame brackets themselves dictate alot of the geometry. all i had to do was pick a spot on the frame to mount them. i wanted them tucked close to the tires for ground clearance, not as short as a short arm and not as long as a long arm. the rear arms ended up a little shorter than I imagined, but they still work great.
the other factor is the duroflex joints. they do not like to me misaligned so the link mounts on the axles need to be perfectly in line with the frame side mounts. Unlike a johnny joint that can be misaligned during the build, which would complicate the decision on where to place the axle side mounts.
The vertical separation had to be determined. the truss on the rear diff was tall enough that I could place the links on top and the lowers could be on the centerline of the axle. the front was similar.
The front upper frame side mount had to be rotated 90 degrees from the way the poly per mount would have it installed. I decided to add that small link mount to accomplish that. that gave me some adjustability and some more vertical separation at the frame.
really if your using pre-made brackets there isnt alot you can do with the geometry.
that being said i trusted the guys in my jeep club whos shop i was doing the work with to lead me in the proper direction.
there is some adjustability in the rear uppers on the frame side if i felt the rear end was hopping around during hill climbs. and there was some adjustability in the front upper frame side until i choped off the lower corner of the mount for some added driveshaft clearance.
honestly, I did some research and came to the conclusion that I could use the calculator, but in the end the design would have to be fitted to the confines of the TJ frame/body.
I would like to put the numbers into the calculator, but the jeep does great offroad and i'm not one to fix a problem i dont have.
HOKIES UNITED!
post #342 of 733 Old 02-06-2014, 08:16 AM
srfnfly227
Is there a reason that you didn't use a 4 link frame mount up front? Seems like that would have been nearly identical to what you ended up making.
Savvy 3" Springs, 4 Link rear with outboarded shocks, Savvy UnderArmor, 255/85R16 Toyo M/T
srfnfly227 is offline
post #343 of 733 Old 02-06-2014, 08:37 AM Thread Starter
jeepinhokie
Lee,
i probably could have used something like the 4 link bracket. i didnt for a few reasons.
1. Cost, 4 link brackets are more expensive than 3 link
2. I already had the poly 3 link brackets and getting a single link mount was easier
3. geometry. I didint know where the axle side mount was going to end up on diff. with the mount i used i was able to adjust it to where i wanted it AND be straight. with a 4 link bracket the geometry is set and if the axle side mount needed to be moved it wouldnt be easy. plus i ended up having to cut the bottom corner of the mount off to give the driveshaft more clearance, that would have been more difficult with the 4 link mount.
4. Plan B. if my 3 mount didnt work as needed i could always fall back to the traditional 3 link mount with the joints rotated 90 degrees from eachother. not ideal, but it would work. it would wear the joints out faster though.
in the end i'm glad i did it the way i did. the small amount of fabrication time was well worth it.
HOKIES UNITED!
post #344 of 733 Old 02-06-2014, 08:48 AM Thread Starter
jeepinhokie
i tried to take a good picture of the 3 link mount. its plenty dirty under the jeep from this winter.
HOKIES UNITED!
post #345 of 733 Old 03-14-2014, 07:32 AM Thread Starter
jeepinhokie
Getting some needed wheeling in this weekend. Just a single day up at RC with a couple guys from my local group.
HOKIES UNITED!
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 10:59 PM
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
