A Hokies 04' TJ build - Page 20 - JeepForum.com
post #286 of 733 Old 10-20-2013, 08:26 PM
jeepwrangler97
How many miles on the CAs?
My goal is to replace worn stuff with JJs, but it's hard to keep up with them sometimes.
Edit: did you figure out your odd tire wear? My tires are starting to wear weird
Sent by a messenger bird
jeepwrangler97 is offline
post #287 of 733 Old 10-21-2013, 05:43 AM Thread Starter
jeepinhokie
control arms came off my TJ and a buddies LJ. my TJ had 140k his closer to 40k.
i have not figured out my off tire wear. it has done the same thing with both axles. literally the only thing that stayed the same is my springs and shocks.
It has done it at 25 PSI and starting to do it again at 21 PSI. my toe is roughly 1/16". ill keep an eye on it and contact goodyear to see if they have any thoughts. they are probably going to say its my shocks.
HOKIES UNITED!
jeepinhokie is offline
post #288 of 733 Old 10-22-2013, 10:26 PM
jeepwrangler97
Hmm...I think I'm going to hold out & see if I can get some more Currie control arms.
Yeah, that's weird. I don't get how the shocks could do that, but I guess they are one of the only constant things in that equation
post #289 of 733 Old 10-23-2013, 05:38 PM Thread Starter
jeepinhokie
Yeah the only reason I would swap a stock control arm would be to fix an issue. Bent, bad bushing, etc.
HOKIES UNITED!
post #290 of 733 Old 10-25-2013, 12:41 PM Thread Starter
jeepinhokie
Got a few things done to the jeep today.
Pulled the skids and front driveshaft to measure for a new front driveshaft. 39.5" XB ordered from Tom woods.
Checked the diffs for proper fluid level.
Finally found the source of a speed bump knock in the front. Drag link adjuster is hitting the tie rod. With the passenger side flipped it puts the tie rod closer to the drag link, and with only 2.5" of lift the drag link adjuster is spun so that the clamps are toward the back. I suppose I need to pry them open and spin them 180 degrees. But then the clamps aren't clamping as they were designed to. I adjusted it so it doesn't knock so badly, but it still hits slightly.
Also found a loose antirock arm. And the rod ends are a little sloppy. .
HOKIES UNITED!
post #291 of 733 Old 10-30-2013, 07:18 PM Thread Starter
jeepinhokie
Got my staun tire deflators cleaned and re adjusted to 8psi. Not my favorite thing to do, but it needed to be done and makes setting the jeep up for the trail super easy. Let the air out of the tires and I'm ready to wheel, nothing else needed.
HOKIES UNITED!
post #292 of 733 Old 10-30-2013, 07:21 PM
IEcrawlerTJ01
Your gonna notice a huge difference in traction
It's gonna feel like a whole new jeep
Your gonna love it
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #293 of 733 Old 10-30-2013, 07:38 PM Thread Starter
jeepinhokie
Your gonna love it
I don't know about a whole new jeep. But your right, the added traction should be noticeable.
HOKIES UNITED!
post #294 of 733 Old 10-30-2013, 07:42 PM
IEcrawlerTJ01
In my experience. The drop from 12 to 8 is drastic
You will definitely feel a difference. Maybe it's more for me out here where it's dry
Nuff said...
post #295 of 733 Old 10-30-2013, 07:46 PM
janesy86
With the MTR/K's I've noticed even a vast improvement between 10 to 8.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #296 of 733 Old 10-30-2013, 07:57 PM Thread Starter
jeepinhokie
Well then I have good hopes for 8.
I have been happy with them offroad so far. So I have high hopes.
HOKIES UNITED!
post #297 of 733 Old 10-30-2013, 08:47 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
7 or go home! Haha, j/k but yeah the difference between even 10 and 8 is huge. 7.5 is my happy place.
gst95dsm is offline
post #298 of 733 Old 10-31-2013, 03:38 PM Thread Starter
jeepinhokie
Originally Posted by gst95dsm
7 or go home!
HAH. 7. get out of here you crazy kids. The world will end with only 7.
8's where it's at apparently. That's what all the cool kids are doing these days.
HOKIES UNITED!
post #299 of 733 Old 11-02-2013, 06:14 PM Thread Starter
jeepinhokie
Not entirely jeep related, but I rewired the trailer with LEDs all the way around. The pervious owner butchered the wiring and the trailer constantly had lights out.
No more bulbs to change, brighter lights and doesn't draw power from my tail lights.
Should be good to go for a few years.
HOKIES UNITED!
post #300 of 733 Old 11-02-2013, 08:26 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Not entirely jeep related, but I rewired the trailer with LEDs all the way around. The pervious owner butchered the wiring and the trailer constantly had lights out. No more bulbs to change, brighter lights and doesn't draw power from my tail lights. Should be good to go for a few years.
Will towing this trailer cause your flasher to blink fast? Or is that just specific to the vehicle only?
Mail crawling.
MisfitSeven is offline
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
