A Hokies 04' TJ build - Page 19 - JeepForum.com
post #271 of 733 Old 10-04-2013, 10:17 PM
Strings72
Did you sell the currie trackbar?
03 TJ: constantly evolving
06 Dodge 2500 CTD 6spd 4x4
Check out my build:
Strings72 is offline
post #272 of 733 Old 10-05-2013, 06:29 AM Thread Starter
jeepinhokie
Yes. Sold it a while ago. Saved myself some money by not sending it back and saved the buyer money too.
HOKIES UNITED!
jeepinhokie is offline
post #273 of 733 Old 10-07-2013, 07:21 PM Thread Starter
jeepinhokie
Odd tire wear I'm noticing. I've tried different tire pressures. 26 to 21. Toe is roughly 1/16".
Any thoughts? Notice every short center tread is different than the longer center tread.
First two are front tires and last two are rear tires. Two rear tires were on the front 1,500 miles ago before I rotated them. Sont remember specifics about where the 5th tire went.
HOKIES UNITED!
post #274 of 733 Old 10-08-2013, 01:23 PM Thread Starter
jeepinhokie
Latest off road adventure.
HOKIES UNITED!
post #275 of 733 Old 10-08-2013, 04:02 PM
IEcrawlerTJ01
What tire pressure you running?
Looks like 10-12lbs
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #276 of 733 Old 10-08-2013, 05:03 PM Thread Starter
jeepinhokie
Looks like 10-12lbs
Off road 10 ish.
On 21-25
HOKIES UNITED!
post #277 of 733 Old 10-08-2013, 05:41 PM
IEcrawlerTJ01
Originally Posted by jeepinhokie
Off road 10 ish.
On 21-25
Thought so. You could really alleviate alot of your small tire spinning by dropping to 7-8psi
It will handle like a whole new rig. 10 is not low enough for the goodyears nor most tires for that matter
Try it out next time. You will be surprised at how much better your jeep will work
Other than that jeep looks good man
Nuff said...
post #278 of 733 Old 10-08-2013, 07:13 PM Thread Starter
jeepinhokie
Yeah. I realize I could take it lower, but I'm a little gun shy after my experience with the duratracs sidewalls.
I have to re-calibrate my staun deflators so ill set them closer to 8.
Thanks.
HOKIES UNITED!
post #279 of 733 Old 10-14-2013, 08:36 PM Thread Starter
jeepinhokie
Posted my old axles up for sale.
http://www.jeepforum.com/forum/f126/...plete-1683265/
HOKIES UNITED!
post #280 of 733 Old 10-15-2013, 03:35 AM
marktj97
Originally Posted by jeepinhokie View Post
Pm sent for d30!
marktj97 is offline
post #281 of 733 Old 10-19-2013, 09:02 AM Thread Starter
jeepinhokie
Originally Posted by marktj97
Pm sent for d30!
Front is gone. Thanks mark.
HOKIES UNITED!
post #282 of 733 Old 10-19-2013, 09:10 AM Thread Starter
jeepinhokie
Have a few spare TJ parts.
From the top.
2 sets of front uppers, one set of lower control arms.
Stock trac bars, front and rear
2 TJ Drag links with V8 ZJ tie rods. Both tie rods are slightly bent. Easy to straighten.
Currie correctlync drag link, TRE has a little play. But would be good for offroad toys or occasional on road use. Isn't bad, but I didn't like feeling it in the steering wheel.
Make offer, come get
HOKIES UNITED!
post #283 of 733 Old 10-19-2013, 10:34 AM
BamaJeepman21
Is the TRE in the Currie draglink replacable? If so what do you want for it?
-Jack
BamaJeepman21 is offline
post #284 of 733 Old 10-19-2013, 10:57 AM Thread Starter
jeepinhokie
No it's all one piece.
HOKIES UNITED!
post #285 of 733 Old 10-19-2013, 10:59 AM
BamaJeepman21
Well damn.
-Jack
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
