A Hokies 04' TJ build - Page 16 - JeepForum.com
post #226 of 721 Old 08-30-2013, 10:15 AM Thread Starter
jeepinhokie
And it begins…
HOKIES UNITED!
jeepinhokie is offline
post #227 of 721 Old 08-30-2013, 04:11 PM Thread Starter
jeepinhokie
Got the axle out, frame side brackets burned in, bridge welded to axle, sway bar mounts cut down and rewelded, and started mounting the axle side link mounts.
Came home to meet the UPS driver with the correct track bar from metalcloak.
Need to find a shock bushing tonight to be able to mount the shocks to the existing coil over mounts.
HOKIES UNITED!
post #228 of 721 Old 08-31-2013, 10:29 AM Thread Starter
jeepinhokie
Moving right along
HOKIES UNITED!
post #229 of 721 Old 08-31-2013, 04:57 PM Thread Starter
jeepinhokie
Got the links made and hung, steering installed and drivers side flipped, trac bar mount fabbed and installed, steering stabilizer mount fabbed.
Trac bar and will require roughly 1.25" of Bumpstops before it hits he diff cover. I could clearance the cover if I need to. Shock placement will determine if I can get any more up travel.
HOKIES UNITED!
post #230 of 721 Old 08-31-2013, 05:03 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Nice work man, looks like it's coming together quickly. Is that an Artec front 3 link bracket?
gst95dsm is offline
post #231 of 721 Old 08-31-2013, 05:14 PM
IEcrawlerTJ01
Looks like genright or poly brackets with a custom upper frame mount
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #232 of 721 Old 08-31-2013, 05:16 PM Thread Starter
jeepinhokie
No. That's a poly performance 3link bracket with a vertical link mount added and gusseted. Ill add more pictures later. I posted a picture of it a whole back just mocked up
Should button it up tomorrow.
HOKIES UNITED!
post #233 of 721 Old 08-31-2013, 05:33 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
That's hot!
What are your plans for the lower shock mounts?
Mail crawling.
MisfitSeven is offline
post #234 of 721 Old 08-31-2013, 05:50 PM Thread Starter
jeepinhokie
Originally Posted by MisfitSeven
That's hot!
Shocks will go either on top or on the side of the lower link mount.
Probably have to replace the bushings. We dicked the bushing up trying to remove the bar pin.
HOKIES UNITED!
post #235 of 721 Old 09-02-2013, 08:32 AM
srfnfly227
srfnfly227's Avatar
Looks good buddy. Get it back on the road yet?
Savvy 3" Springs, 4 Link rear with outboarded shocks, Savvy UnderArmor, 255/85R16 Toyo M/T
srfnfly227 is offline
post #236 of 721 Old 09-02-2013, 08:04 PM Thread Starter
jeepinhokie
Got it back on the road today. Had a few items to button up in the am.
Found out that the axle lock sensor was misaligned when they reinstalled my carrier. So we had to pull the carrier out a bit to get it re aligned. Of course we found this out right after re assembling the axle completely. Luckily I hadn't put fluid in the diff yet.
Other than that everything went about as smoothly as it could for undertaking such a large project in one weekend.
Need to shorten my driveshaft or get a new one and probably clearance the upper link mount when I get it installed.
Also need to make a new support arm for the front of the engine skid.
HOKIES UNITED!
post #237 of 721 Old 09-04-2013, 01:57 PM
Strings72
Probably my favorite build. Keep it up
03 TJ: constantly evolving
06 Dodge 2500 CTD 6spd 4x4
Check out my build:
Strings72 is offline
post #238 of 721 Old 09-04-2013, 03:02 PM
BamaJeepman21
So how's it ride?
-Jack
BamaJeepman21 is offline
post #239 of 721 Old 09-04-2013, 05:35 PM Thread Starter
jeepinhokie
thanks. these axles and links should work well for me for many years to come. plan to focus on other aspects of the jeep now.
Originally Posted by BamaJeepman21 View Post
So how's it ride?
as far as the ride goes...
small cracks in the road are all but non existent. the joints soak up most of the small stuff pretty well. they are great
large cracks or dips in the road are still there, but controlled.
My jeep is still on the light side, so the HD OME springs/shocks are a bit stiff. so the ride is not as smooth as it could be. hopefully the ride will smooth out as i add some weight to the jeep. ie. putting my skid plates back on, tub mounted tire carrier, corner and rocker armor, full cage, etc.
might also be tempted to go ORI's. right now the suuspension is just about set up for some serious travel, but my limitation at the moment is the current springs and shocks.
going to cut and shorten the front driveshaft tonight. the upper link mount might have to change. I think it looks good and sure does provide the proper function, but it sticks out a little too far. i might be able to cut the bottom corner off, but i might also have to redesign the entire upper link. cheating the axle to the passenger side will help to. probably end up doing a combination.
HOKIES UNITED!
post #240 of 721 Old 09-04-2013, 09:50 PM Thread Starter
jeepinhokie
Got the driveshaft cut down. Drove it up to 50mph with no noticeable vibrations. Ill keep an eye on it over the next few days.
Next up is to clearance the link mount and / or push the axle over to the passenger side to gain clearance. Probably both.
Also noticed that the passenger side of the axle might be bent a little... Ill have to do some more investigating on that, but the axle shaft has more space between the tube and shaft on the bottom than it does on the top (I might have that backwards)
HOKIES UNITED!
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 10:59 PM
Jeep Build: Minty White Country XJ Build GTEIS300 Jeep Builds 34 01-20-2013 11:42 AM
2000 TJ Build - LCG First Time Build japete01 Jeep Builds 82 06-07-2012 10:50 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 12:15 PM
JeepDVL45's 'Bruiser' Build -- A Daily Driver's slow build JeepDVL45 Jeep Builds 41 08-11-2011 10:44 AM
