A Hokies 04' TJ build - Page 10 - JeepForum.com
post #136 of 724 Old 05-17-2013, 10:37 PM
BamaJeepman21
Originally Posted by jeepinhokie View Post
Yeah something like that. All I know for certain is that it's more than I originally expected it to be.
Frame mounts
Axle mounts
Control arm joints/jam nuts/threaded inserts/DOM
Brake lines / calipers/ misc fittings
E-brake
Pump switches/electrical supplies/air line
Exhaust work
Paint
Fluids
Coil buckets
**** adds up fast.…
I got my axle with a truss/diff cover , 4.88s, chromoly shafts. Which saved me quite a bit of money in building the axle itself.
My thoughts on the custom arms…. If you can fabricate everything else for a 4 link. Then you can cut and weld some DOM for the arms. No sense in having some custom made when you can make them yourself.
I can't weld so anything that involves it will be done by someone I know and trust. The thing is, outboarding seems to be a rare concept outside of SoCal and Jeepforum.
-Jack
BamaJeepman21 is offline
post #137 of 724 Old 05-18-2013, 09:46 AM Thread Starter
jeepinhokie
Same here in regards to the welding. None of my build would be possible without a lot of help from friends from my local 4x4 club.
Outboarding doesn't have to go hand and hand with 4 linking. I plan to keep my current OME 2.5 springs and shocks and see if I'm happy with the flex being limited by the shocks. Granted, I will probably outboard and get slightly longer springs eventually. Thinking 3.5 MC springs and shocks TBD.
Basically for now I just want to move in the right direction for my future needs.
HOKIES UNITED!
jeepinhokie is offline
post #138 of 724 Old 05-18-2013, 09:59 AM
BamaJeepman21
It's be easier for me to outboard and 4 link at once. Get all the welding done.
Watch the compressed length on those MC coils. Since they're dual rate they have a really long compressed length.
-Jack
post #139 of 724 Old 05-24-2013, 03:59 PM Thread Starter
jeepinhokie
Got the 35 removed within an hour of starting the 4 link
As of now the jeep has frame mounts fully welded and all axle mounts tacked on and just about ready to pull the axle back out to final weld, set up brake lines, paint, etc.
HOKIES UNITED!
post #140 of 724 Old 05-24-2013, 05:22 PM
tyvanwie
subbed.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #141 of 724 Old 05-24-2013, 06:26 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Looks good. That's the quick way to 4 link.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #142 of 724 Old 05-24-2013, 08:00 PM Thread Starter
jeepinhokie
Just a few shots from the day!
More tomorrow.
imageuploadedbyag-free1369447198.319930.jpgimageuploadedbyag-free1369447214.886886.jpg
imageuploadedbyag-free1369447053.784406.jpgimageuploadedbyag-free1369447078.719357.jpgimageuploadedbyag-free1369447137.803125.jpgimageuploadedbyag-free1369447168.236783.jpg
HOKIES UNITED!
post #143 of 724 Old 05-24-2013, 08:22 PM
G Beasley
Holy cow ya'll arent messing around ! Is the goal to finish it this weekend ?
G Beasley is offline
post #144 of 724 Old 05-24-2013, 08:43 PM Thread Starter
jeepinhokie
That's the goal. Just the rear axle swap and 4 link though. The only thing that will need to be finished is the exhaust. Which I think I'm going to farm out to a local shop.
Still in the works is out boarding rear and front axle swap and 3 link. So I'm far from done! But it'll be drivable between the swaps.
HOKIES UNITED!
post #145 of 724 Old 05-24-2013, 11:28 PM
Jay12
You should fix the frame side coil buckets while you're in there.
Jay12 is offline
post #146 of 724 Old 05-25-2013, 04:42 PM Thread Starter
jeepinhokie
Got the axle finish welded, painted and put back in. Finished making the links. Brake lines made/routed/bled. Air line routed. Axle back together with new brakes flipped to he front, new e-brake cables with Blaine's wizard flip brackets. Pulled the front driveshaft (just in case, I forget about the 3.73's in the front). Swapped the yoke for a d30 yoke and pinion seal.
I'm one tired pup though.
Just need to check a few things tomorrow and I should be ready to roll out of the garage.
image-2359568492.jpg   image-156256557.jpg   image-2546611602.jpg   image-3613717746.jpg
HOKIES UNITED!
post #147 of 724 Old 05-26-2013, 01:52 PM Thread Starter
jeepinhokie
Got the jeep back down on the ground for a test drive at 10am. Flexed it out on the RTI ramp and found that the axle was a little far forward, so we pushed it back a tad and reset the pinion.
Drives nicely. I feel less road vibrations from the rear and it doesn't hop sideways. No binding anywhere and it flexes great.
I would post pictures but the JF App will not let me due to file size.
Now for an exhaust...
HOKIES UNITED!
post #148 of 724 Old 05-26-2013, 09:40 PM
BamaJeepman21
Poly frame brackets, BTF truss, and Duroflex joints correct?
I hope to do this soon and am happy to hear it rides great. Better than stock? Does it float over bumps now?
-Jack
post #149 of 724 Old 05-27-2013, 07:27 AM
G Beasley
At least we arent paying for the privilege to post pictures ?
Sounds like the Jeep is coming along , try photobucket to host the pictures . Its not bad to use , though the newest format isnt the most user friendly.
post #150 of 724 Old 05-27-2013, 07:44 AM Thread Starter
jeepinhokie
I have a shutter fly account but their app will not show a URL address. I'll have to do it in the PC.
I'm not sure who's truss it is. I think the BTF one has three bolts, vs the 4 this one has. Might be an earlier design, but they look very similar.
I wouldn't say it floats over bumps, after all I didn't change the shocks or coils. New coils and springs are in the plans. But for now the budget would t allow it.
The ride is definitely better than before with 145k miles on original arms and track bar. But yes it does ride softer than before. Ill wait till the front is 3 linked before I give my final answer. But I have no doubts that I'm headed in the right direction for my build.
HOKIES UNITED!
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
