A Hokies 04' TJ build - JeepForum.com
post #1 of 724 Old 06-27-2012, 06:38 PM Thread Starter
jeepinhokie
I'll try and keep a current picture on top here:
I never though my Jeep was worthy of a "build" thread, because most of what I have done to it until now has been bolt on. nothing really being built. but that changed with my latest round of changes.
let me catch everyone up to my current progress, ill try and compress 5 years of info into a few pictures.
the first Jeep i looked at was a YJ, couldnt stand the square headlights!
A few more months and i came across a bone stock 2004 TJ for $11k. lets just call it a present to myself, after-all i was driving a 98 Ford Taurus... after graduating in 2007 and getting my first real job, i picked the jeep up without knowing a thing about them or the off-road world.
First thing i did to it was go play a little,
doors off ASAP,
I was saving up to buy a house, so the jeep stayed stock for 2 years.
my first "mod" was a set of KC daylighters on the windshield.
Then we took a trip down to Ocracoke
Finally it was time for a lift; I decided on a 2.5" OME HD lift. I used the hobby shop on base.
drove it around for probably 6 months until the tires wore out and i could justify replacing them. went with 33" Goodyear Duratracs, which is a choice i would later come to regret.
Went down to a buddy's farm for a camping weekend. got a little flex on a tree we were cutting up for firewood.
Then i went on my first real wheeling trip to Rausch Creek in PA.
where i quickly found out that 2.5" of SL isnt quite enough to keep 33"s out of the fenders.
Then a few more goodies came along. Rokmen mercenary bumper and steering skid. as well as an antirock. discussed here
Next was my first built item. my 33" was sitting on my OEM tire carrier and I came up with this to help with the stress. Its slotted to accommodate tire wear. I welded nuts to the backside of the stock bumper to allow easy adjustments.
then I mounted my high lift to the rear roll bar. cheap and simple solution, muffler clamps.
And this is how she sat for a little while.
went wheeling a few times with that set up.
upgraded my steering to the V8 ZJ tie rod and new drag link.
then more wheeling trips
jeepinhokie is offline
post #2 of 724 Old 06-27-2012, 06:39 PM Thread Starter
jeepinhokie
I had a teapot whistle in the engine when it was cold out, so i decided to tackle that. ended up being a cracked intake manifold. replaced with a JY one out of a cherokee.
Wheeled it some more. with my new MT/R's. as I mentioned earlier, the Duratracs just werent up to the task. Goodyear bought the Duratracs back from me for 75% of my origional purchase price, which i had to put towards the new MTR's. still cost me a pretty penny, but the MTR's should hold up much better. Duratracs vs MTRs discussed here
Obviously there were some things that i missed; like the warn VR8000 and removing my side steps.
HOKIES UNITED!
post #3 of 724 Old 06-27-2012, 06:40 PM Thread Starter
jeepinhokie
next up:
I'm working on a tummy tuck with crossmember and custom skids and putting an Aussie locker in the d30.
install to include. Novak cable shifter, AA SYE, tom woods driveshaft, ruffstuff crossmember mounting set, steel double adjustable rear upper control arms from Currie (thanks Lee), 4WD indicator switch, UCF engine skid mounting hardware, Aussie locker with new 5-760x U-joints and pinion seal, reworked my OME track bar bracket to work with the DC driveshaft.
Out with the old... good riddance
SYE in progress
Fabbing up the crossmember. went with a kit from ruffstuff for the bushings and some 2x2x1/4" box tubing. I chopped up the OEM trans mount and welded that to the 2x2.
In order to weld the bushings to the frame the fuel lines on the frame needed to be moved.
Skid stage one...
Engine skid in cardboard...
reworking the OME trackbar mount to work with the SYE and new DC driveshaft
rotating the pinion up required a little cutting on the coil buckets to clear the shocks.
Skid plate mocked up...
which brings me to today...
still need to order my Tom woods driveshaft, fab the engine skid, install the Aussie with new 5-760X u-joints and pinion seal.
HOKIES UNITED!
post #4 of 724 Old 06-28-2012, 07:27 AM
OhSethiO
looks awesome bro, I saw you said you used the hobby shop on base, what branch? I'm Navy. Unfortunately they dont have the hobby shop open on base anymore, so I have to do everything in my garage... lol
OhSethiO is offline
post #5 of 724 Old 06-28-2012, 07:42 AM
srfnfly227
Looks good buddy. I can't wait to see everything finished up.
Savvy 3" Springs, 4 Link rear with outboarded shocks, Savvy UnderArmor, 255/85R16 Toyo M/T
srfnfly227 is offline
post #6 of 724 Old 06-28-2012, 07:44 AM Thread Starter
jeepinhokie
i'm not in the military, but as a defense contractor I have access to the hobby shop on Pax River. I just have to pay more. Cost me $50 or $60 for use of the lift for the day and have access to whatever tools i didnt have myself.
thanks for your service.
Yeah, it should be another week or so till everything is buttoned up.
Wheeling on the 13th, so i've got a deadline now.
HOKIES UNITED!
post #7 of 724 Old 06-28-2012, 09:20 AM
Ben
How much body lift do you have? 1 or 1.5"?
Is the 2"x2" box steel flush with the bottom of the frame? Tough to tell from the pic of it. Or is the small amount of bend in the skid the difference...
Good work.
Ben is offline
post #8 of 724 Old 06-28-2012, 09:25 AM Thread Starter
jeepinhokie
Good work.
i have the 1.25" JKS BL.
and the 2x2 sits roughly 3/4" below the frame rails.
the 42RLE is the lowest point of the drivetrain. ill have to lower that part of the engine skid.
HOKIES UNITED!
post #9 of 724 Old 06-28-2012, 09:33 AM
chris86vw
Good work.
Curious about the same, I ordered materials (using dom not box) to do similar on mine just keep forgetting to go pick them up every morning. Will be starting on it this weekend.
I can't do a MML though so I need to be careful with how much I lift the trans.
Progress looks great
98TJ 4bt, 15GSW TDI, 12JSW TDI, 06 A3 2.0t GTX3071R, 00 Audi TTQ, 80 rabbit pickup, 02 LR Freelander
chris86vw is offline
post #10 of 724 Old 06-28-2012, 09:49 AM Thread Starter
jeepinhokie
I was able to jack everything up and put a little dent into the firewall, then lower everything back down a little for clearance. probably not more than 1/4" between the top of the trans and the firewall.
thanks for the compliment. hope to get it finished up within the next week and a half. I dont get to work on it everyday, so its slow. but at least i can drive it b/c of the crossmember.
take a look at what HENDRIX did on his in "what did you do to your TJ today" post number 69748. he used DOM also.
HOKIES UNITED!
post #11 of 724 Old 06-28-2012, 10:04 AM
chris86vw
Thanks will do.
post #12 of 724 Old 06-28-2012, 02:24 PM Thread Starter
jeepinhokie
Tom woods driveshaft is on its way!
Went with the XB, 17"
HOKIES UNITED!
post #13 of 724 Old 07-06-2012, 03:01 PM Thread Starter
jeepinhokie
One step closer to finishing this round of changes. Skids are done and painted.
Locker goes in Sunday.
Had to take the track bar mount off again. So I thought I would post up a picture of the angle I set it to.
image-2444989285.jpg   image-896959753.jpg   image-1048329070.jpg   image-2118409597.jpg
HOKIES UNITED!
post #14 of 724 Old 07-06-2012, 03:18 PM Thread Starter
jeepinhokie
A bit of a before and after shot. No skids yet though.
HOKIES UNITED!
post #15 of 724 Old 07-06-2012, 03:39 PM
G Beasley
The skids turned out nice , in retrospect I should have made mine .
In some of the above pictures I recognize Oak Ridge , but where is the old shack ?
G Beasley is offline
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
