Highline project - JeepForum.com
post #1 of 16 Old 05-06-2012, 03:14 PM Thread Starter
abeckert
Highline project
I decided I wanted to do a highline on my new(to me) jeep. I was originally going to do a highline with the stock fenders, but I've wanted tube fenders so I decided to go ahead and do both at the same time. I had the jeep torn apart fixing the exhaust so it seemed like as good a time as any to start. I had pulled the fender off to get better access to the manifold so I was already one step ahead.
Passenger side off
I ordered tubes from Jeeptubes.com. They are very nice pieces. Well bent and accurate. They were well packaged and arrived in perfect condition. They require a little work to fit well, but I paid a fraction of what highlines cost built and I wanted to get more fab experience.
I ordered front tubes and flares as well as rear flares.
Next it was time to actually cut the hood. I taped along the body line and cut just below it. I figure I can always cut a little more off, but I think I might leave the line as it is. I saw a thread on jeepforum where someone had rewelded the lower lip back on for rigidity so I may try that down the line.
Point of no return
Next I started on some brackets to attach the tubes. I used some angle iron and flat stock.
I sliced and re-welded the top of the angle so it matches the body line a little better
Drivers side tube tacked into place. I may have to do a little adjusting, but I think its in a pretty good spot.
Head on shot
The hood is sitting a little high, it pulls down pretty lcose to the top of the tube so I'm not woried about that gap right now. The latches should keep it close.
So far Im pretty happy with the progress considering I've not done anything this in depth before.
More to come.
abeckert is offline
post #2 of 16 Old 05-06-2012, 03:37 PM
Tenshots1
Looks good. Are you going to be able to fit the latches on the side of the hood? are you going to use the stock inner fenders or fab some up?
1998 XJ Build:
Tenshots1 is online now
post #3 of 16 Old 05-06-2012, 03:41 PM
mcjeepin1996
Very cool. Always wondered how people did them themselves.
mcjeepin1996 is offline
post #4 of 16 Old 05-06-2012, 04:29 PM
G Beasley
The rewelded lip thread is from Hendrix http://www.jeepforum.com/forum/f9/ro...style-1012297/
It really sets his high line apart from many others . Nice work so far , still have a lot of fitting and welding to go !
G Beasley is offline
post #5 of 16 Old 05-07-2012, 05:56 AM Thread Starter
abeckert
I've seen a couple people reuse the stock latches, but I may end up using some hood pins anyway. I'll have to wait and see if it works out.
As for the inner fender, I'd like to reuse the stock fender to keep costs down. I had thought about using some marine aluminum too cus I think that would look cool on the underside.
It'll be a fairly slow process as I'm learning along with this, but I'm having a good time doing it.
abeckert is offline
post #6 of 16 Old 05-11-2012, 06:47 PM Thread Starter
abeckert
Got a little more done today.
I got both main tubes welded and the down tubes in. next i'll be plating the top and sides, then I'll get started on the flare.
abeckert is offline
post #7 of 16 Old 12-16-2012, 11:49 AM Thread Starter
abeckert
Its been a long time since i started this project and a lot of time since I posted any progress. Time and funds dictated when I could work on this but, ive finally got most of this done.
I decided to go with hood pins rather than the stock latches
I wanted to use round JK turn signals for a CJ look, but in the interest of saving money I decided to reuse the stock rectangle lamps. I actually kind of like the look so it worked out.
I still have to figure out what I'm going to do for inner fenders. When I tried working with the stock inners before, it didn't really seem to work. I may look at something like GenRights inner fender kit, Ive also thought about getting some aluminium and make a couple panels that way.
Now I just need to get some bigger meats toput under there. That probably wont happen til tax time though...
abeckert is offline
post #8 of 16 Old 12-16-2012, 12:47 PM
CarolinaCrawler
Redbull gives you wings!!
Eagle Scout Jeeper #1
2000 TJ 2.5in RC X-Flex lift, Fast back top, 8.8, 1inBL, 265's on ProComp 7031s - Sold :(
2002 WJ Limited all stock for now - Current
http://www.facebook.com/profile.php?id=1587300482
CarolinaCrawler is offline
post #9 of 16 Old 12-16-2012, 12:56 PM
Tenshots1
Dang why so big on the flares?
1998 XJ Build:
post #10 of 16 Old 12-17-2012, 01:18 AM
sixgunmatt
'97 TJ Sport 4.0L, D30/D44 4.88 Gears, RE Extreme Duty 5.5" LA with Rear Tri Link truss, 35x12.50/R15 MT Baja MTZs, 15x8 Pro Comps, RE Anti-Sway Bar Quick Disconnects, RE Monotube Shocks, AA SYE, Tom Wood's CV DS, Magnaflow Exhaust, Spectre Performance Intake through Cowl, etc...
sixgunmatt is offline
post #11 of 16 Old 12-17-2012, 02:35 AM Thread Starter
abeckert
They do look big now, but next to the jeep are full size axles. Once they are in and bigger tires are on it should look ok.
abeckert is offline
post #12 of 16 Old 12-17-2012, 08:46 AM
CDW_327
Dang.
CDW_327 is offline
post #13 of 16 Old 12-17-2012, 10:18 AM
Moabrubi
Wow... are those like 18" flares???
Moabrubi is offline
post #14 of 16 Old 12-17-2012, 10:51 AM
Imped
Imped's Avatar
Those flares......
OlllllllO
IndyORV
Imped is online now
post #15 of 16 Old 12-17-2012, 02:24 PM
lamar_j77
Well, you are never going to get decent gas mileage out of it now.....
lamar_j77 is offline
Highline fenders hoovail Jeep Picture Requests 21 02-02-2012 09:58 AM
CJ/YJ/TJ Highline Fenders Tylerzap Jeep Picture Requests 7 09-27-2011 05:51 AM
Highline complete JSahara00 Jeep Builds 24 03-12-2011 04:20 PM
Highline diy or aev, 33-35's and 1inch bl CRISTOF1 Jeep Picture Requests 0 10-17-2009 08:25 PM
Let's see 33's, Highline, No Lift WCoon Jeep Picture Requests 3 08-24-2009 07:22 AM
