Quantcast Highline complete - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Highline complete
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 01-04-2010, 10:18 PM   #1
JSahara00
Highline complete
I just finished up the highline last night.. I like the way it came out.. i still need to lower it now..
The top of the fenders are 48 inches from the ground..
Also need to find a place for the windshield washer fluid res..
I will have more pics tomorrow...
Its a 4 inch short arm on it now with 2 inch coil spacers.. ( was a mistake) and 35's
JSahara00 is offline   Reply With Quote
Old 01-04-2010, 10:21 PM   #2
AlTheKillerr
just take out the 2" spacers and be done
AlTheKillerr is offline   Reply With Quote
Old 01-04-2010, 10:28 PM   #3
RanTJWJ
Heck you could get rid of the 4 inch and keep the spacer. Low center of gravity baby
RanTJWJ is offline   Reply With Quote
Old 01-04-2010, 10:32 PM   #4
JSahara00
well im going for LCG.. But i blew the shocks and crap so im just going to put in a 2inch and thinking of making my own control arms.. i have all the stock suspension but its all just such junk....
Old 01-04-2010, 11:00 PM   #5
Imped
TITS
Imped's Avatar
Looks well done. More pics from more angles would be great. You could run no lift with plenty of room. I say go with some 2 or 2.5" springs and rock it. What about a tummy tuck? You'll be dropping it so you may want to lose the shovel.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 01-04-2010, 11:01 PM   #6
GraKee99
GraKee99's Avatar
What did you use to cut the hood?
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote
Old 01-04-2010, 11:06 PM   #7
JSahara00
I was thinking of being cheap 4WD sells a 2inch for under 400 its just shocks and springs.. I think the RC control arms i have will work they were off the 4 in lift i have.. I will try to do something for the skid plate.. i read for alot of them you need to raise the engine mounts and it kicks it all off at an angle but im a little scared of that cause there is minimal space under the hood....
I used a sawzall
It saws ALL
Old 01-04-2010, 11:29 PM   #8
Imped
TITS
Imped's Avatar
I used a sawzall
It saws ALL
You're just misinformed. Learn what's actually happening and what has to (or doesn't have to) be done. And the RC 2.5 is under 300 with real shocks and springs. Good ones at that. Your current RC control arms are crap, assuming you have the fixed arms with bushings on both ends. Go with some quality short arms or make your own with some nice joints.
OlllllllO
Float Test Build
IndyORV
Best served cold
Old 01-04-2010, 11:32 PM   #9
JSahara00
Crap.... yes
better than stock... yes
I will look into the RC 2.5 thanks for the heads up
I think i will make my own control arms sounds entertaining...
Who do you like for CA manufacturers?
Old 01-04-2010, 11:36 PM   #10
AlTheKillerr
depends on who you ask, but id say build your own and go with a medium length arm or get currie or clayton long arms
Old 01-05-2010, 12:21 AM   #11
Imped
TITS
Imped's Avatar
Crap.... yes
If you want to make your own, I'd start researching link geometry if you're not already familiar with it. I'd go with Currie Johnny Joints on some .25" wall DOM tubing for the lowers and .175" wall for the uppers. That's generally a good starting point. While you're at it, you might as well cut off the factory lower mounts and go with something a bit higher clearance. Check out Poly Performance while you're at it.
And in terms of the RC arms--they might be stronger than stock but they flex much worse than stock due to them being solid. All that does is limit you and put a TON of force on your control arm mounts.
OlllllllO
Float Test Build
IndyORV
Best served cold
Old 01-05-2010, 12:55 AM   #12
rs4race
I like the rears. Can you take some pics of what you had to do for them?
rs4race is offline   Reply With Quote
Old 01-05-2010, 11:43 AM   #13
JSahara00
i can get more pics tonight..
Old 01-05-2010, 02:21 PM   #14
rs4race
nice. Did you cut the tub or just raise the flares?
I had thought about raising the flares in the back and doing something like metalcloaks in the front. I wasnt sure if the rear tire arch under the flare was cut up higher or not. Rite now on 33's I rub the rear fenders alot when flexing but maybee with this I can cure that and gain some travel.
Old 01-05-2010, 02:45 PM   #15
JSahara00
yea the flares are moved up and the tub is cut and the fuel cap bezel was trimmed to fit the flares..
Glock Forum
