High Desert YJ - JeepForum.com
post #1 of 54 Old 12-18-2013, 06:54 PM Thread Starter
Buckbagger
High Desert YJ
Let me start off by saying that this project has been a year in the making due my crazy work schedule and the time it has taken me to find the parts I needed. The plan is to take this stock 1995 yj that I picked up locally and build it into a very capable 4x4. The jeep has the 2.5L 4-cyl.with the 5-speed Manual tranny.
Buckbagger is offline
post #2 of 54 Old 12-18-2013, 07:00 PM Thread Starter
Buckbagger
I have bought dana 44s from a pick and pull the front axle is out of a 89 grand wagoner and the rear is out of 1995 rodeo this axles are both six lug and are a few inches in width from one another. The axles gears are being replaced with with G2s 5.38s and aussie lockers
post #3 of 54 Old 12-18-2013, 07:03 PM Thread Starter
Buckbagger
here is some pictures of the front axle being removed
this is my first time trying to post anything like this so sorry if it doesn't make sense or if im doing it wrong
post #4 of 54 Old 12-19-2013, 07:40 AM Thread Starter
Buckbagger
I wanted to build this jeep with as many parts I could find at junkyards from old ranch trucks after a lot of searching I finally found a neighboring ranch that had a flat top dana 44 that I could take off there hands. After removing the knuckles and making sure they would pair up with my front dana 44 I sent the one knuckle off to machined. I went with Parts mike (http://www.partsmike.com) I also purchased there high steer arm kit as well as there stud kit.
this is what the knuckle looked like after being machined
After I installed the new carrier locker and gears in the front axle sorry I dont have any pictures this was done over six months ago and I forgot were I saved them I mounted the new knuckles replaced all seals throughout the axle might as well do it while you have it torn all apart.
The next step was to weld up some new spring perches so I could start to set up the SOA lift. After welding up the perches I mocked the axle up underneath the jeep.
Once I had the axle mocked up under the jeep it really starts to look better! My next step will be to set up the rear axle and mock it up in the rear I will try to take more pictures and if there are steps I left out your wondering about just ask and Ill try my best to answer your question
post #5 of 54 Old 01-23-2014, 05:16 PM Thread Starter
Buckbagger
Update-
Had some free time this last weekend and contiuned work on the jeep my next step was remove the old gears from the new rear axle and clean the housing for the new gears and locker.
The next step is to install the Aussie locker into the new carrier, a new carrier was need due to the fact that the gears are thick cut.
Here is the carrier with the aussie locker installed inside
Hope to install the gears and reassemble the axle within the next week or so
Just "Ledoux It"
My build thread http://www.jeepforum.com/forum/f22/high-desert-yj-1903466/
post #6 of 54 Old 02-09-2014, 06:47 PM Thread Starter
Buckbagger
Picked up this Hanson bumper/tire carrier and kirby skid plate off craigslist this weekend!
Just "Ledoux It"
post #7 of 54 Old 02-10-2014, 06:22 PM
lovett86
nice jeep
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #8 of 54 Old 02-10-2014, 06:31 PM
micahtbyrd
Awesome project... Looks like you are on the right track, and having fun... Very similar to my own rig...
95 YJ wrongler on 36's
micahtbyrd is offline
post #9 of 54 Old 02-11-2014, 06:33 AM Thread Starter
Buckbagger
Thanks guys! Im really excited about this project unlike my last rig Im starting with a stock rig so Im trying to get it right the first time! Micahtbyrd I see that you have the 4cylinder with 5.38s how does the jeep perform for you do you feel under powered? Been putting alot of consideration to doing a tranny swap with a lower first gear or maybe the teraflex 4-1 transfercase kit just hard to justify the $$$$ im on a pretty tight budget
Just "Ledoux It"
post #10 of 54 Old 02-12-2014, 04:58 AM
responder
Looks like that is a decent platform to start from. Good luck with the project and I will be watching the build progress!
responder is offline
post #11 of 54 Old 02-12-2014, 09:10 PM Thread Starter
Buckbagger
Thank you
Just "Ledoux It"
post #12 of 54 Old 02-13-2014, 06:52 PM
micahtbyrd
5.38's with 36's runs pretty close to stock rpm wise... Its got plenty of power to drive around, but as you may think it lacks a bit in first gear, and gets tired at highway speeds above 65... I am planning to move down to 35's some day when I kill my swampers. The 4.1 would help if you need to craw more than you need wheel speed... I find low range to be great for trails with the stock case and 5.38. 4.1 would make crawing more ideal... A low first gear trans would be great off road, but would be useless on road... I found with all my jeeps yj cj and xj, that all the factory power plants hate high revs over 3k, so its always a challenge being under or over geaded. If you ever get into a rig with over 200 horse its way different... All that being said I would gear as low as you can...
post #13 of 54 Old 02-14-2014, 08:06 AM Thread Starter
Buckbagger
Thanks for all the info you have reassured my thoughts about how the jeep will handle, guess it means its time to start saving for a 4-1 transfercase!
Just "Ledoux It"
post #14 of 54 Old 02-14-2014, 08:13 AM
brianandcara
1987 YJ Wrangler
Looks great. Just finishing up my 87 build I purchased out of Reno, gotta love high and dry, getting ready to post a write up on it.
brianandcara is offline
post #15 of 54 Old 02-14-2014, 02:21 PM Thread Starter
Buckbagger
I'll be looking for it
Just "Ledoux It"
