Help with 8.8 swap in YJ - JeepForum.com
post #1 of 2 Old 09-22-2011, 04:31 AM Thread Starter
jerpwt
Junior Member
Ok guy/gals gonna start buying hardware for my 8.8 swap slowly.... Any good info on a cheap place to get all the odds and ins I need (besides more)? Like u bolts, u bolt plates, 7/8" wheel spacers, ect... Thanks in advance. Also anyway to do the e-brake cheap? And do I need to do anything to the driveshaft?
jerpwt is offline
post #2 of 2 Old 09-22-2011, 08:44 AM
chasmosis1
There's a lot of info on here about this that a search would provide. I'm not the type to bash, so I will tell you that after doing three so far it has become easy for me. The last one I did I had u-bolts made at a local spring shop, I used u-bolt plates from a Ranger, and reused the mounts that I cut off of the 8.8. I also reused the YJ shock tabs that I cut from the D35 housing and parking brake cables by cutting them and using cable crimp ends that you can get from any good garage door company. As for the spacers, they would be 3/8" and completely unnecessary unless you are running the stock wheel offset. You'll need a flange from an Explorer/Ranger to connect the drive shaft to the 8.8, and you may or may not need a 1310 to 1330 universal joint depending on what year YJ you have. Don't forget to weld the axle tubes to the housing with hi-nickel rod.
Yes.......I have a Jeep addiction.........
chasmosis1 is offline
90 YJ LS1 Swap jetcracker821 Jeep Builds 80 05-25-2017 06:57 PM
My 8.8 swap in my tj 97krawlwer Jeep Builds 3 02-14-2011 09:57 PM
YJ 8.8 swap & SLE lucious Jeep Builds 1 06-21-2010 11:14 PM
242 Swap XJ517 Jeep Builds 2 03-01-2010 10:05 PM
YJ V8 swap Arcticcat843 Jeep Picture Requests 3 01-06-2007 08:44 PM
