Quantcast Hello, My '07 JK Project... - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Hello, My '07 JK Project...
Old 03-27-2009, 07:36 AM   #1
Liquor
BOUNTY HUNTER
Liquor's Avatar
"CAIN" An '07 JK Project...426 Hemi
In the Begining...
"CAIN" An '07 JK Steel Blue Unlimited Sahara Build
• Rock Krawler 5.5" X Factor Plus Coil Over Long Arm + Heavy Duty Drag Link and Tie Rod with Rock Krawler's Aluminum Remote Reservoir 14" 2.0 Coil-Overs at All Four Corners 14-250 16-350 Spring Rates
• Rubicon Electric Disconnect Swaybar
• Currie Rock Jock III Dana 60 Axles Front and Rear
• Superior 5.38 Gears
• Custom 1350 Driveshafts
• ARB Lockers
• PSC Steering With Cooler
• Atlas II 2-Speed Transfer Case
• Aluminum Block 426 Hemi
• G56 6-Speed Transmission (Same found in manual Ram 3500 Pickups)
• Ansani Design's Ram Air Hood (Painted to Match)
• Transmission Cooler
• Dual Yellow Top Optima Batteries for sound system and winch and a Red Top Battery for motor and accessories
• Woods Trunk (holds dual yellow top batteries)
• Walker Evans Beadlocks 17x8.5" 5x5.5 at 3.5" Back Spacing (Ring Painted to Match)
• 41.5x13.50-17" Pitbull Rocker Radials
• Poison Spyder BFH w/Comp Stinger
• Poison Spyder BFH Rear Bumper
• Poison Spyder Rock Brawler Sliders
• Poison Spyder Crusher Corners
• Poison Spyder Crusher Flares
• Poison Spyder TJ Tire Carrier - Modified to work on the JK
• LOD Trail Rack modified to fit behind rear SRT-8 Seats
• Poly Performance Transfer Case, Gas Tank, and Evap Skid Plates - Engine Skid modified to work with 426 Hemi
• Poly Performance Full Cage
• Blitz Gerry Cans Painted To Match
• Warn Powerplant with Viking Orange 3/8x100' Synthetic Line with Winch Safety Thimble Eye and 10' HD Line Protector
• AEV ProCal
• Front and Rear SRT-8 Bucket Seats (Power and Heated)
• Delta Quad Bar Xenon Headlights
• Delta Xenon Fog Lights
• Delta Skybar Xenon Lightbar
• Delta 150 Driving Lights
• Delta Windshield Light Mounts
• LED Rock/Trail Lights at all 4 Wheel Wells
• Custom "12VoltGuy" Switch Panel for Lights, Air, Winch, and Atlas Hi/Low Gears
• 3 Gallon On-board Air Tank
• 2 Air Chucks Routed to Front and Rear Bumpers
• Tail Gate (Custom Sheet-metal to Smooth it out and Raised JEEP Lettering)
• Relocated Radio Antenna to Rear Bumper and Replace it with Trail Rated Badge
• Cobra 75 WX ST
• 102" Whip Antenna and a 4 foot FireStick
• Wild Boar Fastback T-Top Painted to Match
• MyGIG (AllGIG)
• Modified LOD Trail Rack to install behind rear seats for extra storage.
• Complete Speaker Upgrade (still looking for the right speakers)
• Full FatMat Interior (Double Layered)
• Sponsor Stickers
After the motor is running we will determine correct gear ratio. 4.10 gears should work better than the 5.38 gears. The Hemi has dynoed well over 600 HP and torque at the crank.
SPY PHOTO:
426 Hemi and G56 Test Fit
IMAGES:
Follow Build At:
RockCrawl.org - Facebook - Twitter - YouTube
Sponsors:
4ws.com - Pitbull Tires - Rock Krawler Suspension
Liquor is offline   Reply With Quote
Old 03-27-2009, 07:43 AM   #2
TedderX_
Outdoorsman
TedderX_'s Avatar
goodluck to ya
-Tedder
Originally Posted by BeerMe View Post
You need to start making sense. Drink a V8 or something. If it's an X it has coil springs, but it isn't a 92. If it's a 92 it has leaf springs and it isn't an X. Unless it's a 2092 and you're from the future. If it's a 2092 it has gravity ion coils and they don't crack because they're made of dilithium crystals.
Originally Posted by gixxerphil
Ah Ok, I can't read
/\/\/\ Proof
TedderX_ is offline   Reply With Quote
Old 03-27-2009, 08:57 AM   #3
allanmacaulay
This sounds like it's gonna be an intense Jeep, Good luck and can't wait to see it get along
"Tonka" 2000 TJ, Solar Yellow 4.0, 31" M/T's
http://www.facebook.com/album.php?aid=2001058&l=28219&id=1241460067
Some of my Jeep Pics
allanmacaulay is offline   Reply With Quote
Old 04-30-2009, 04:56 AM   #4
Liquor
BOUNTY HUNTER
Liquor's Avatar
Phase I nearly completed, rock hard safety cage and skip plates are on order, LOD rock rails are being installed and the srt-8 seats will be in shortly as well.
I ended up extending in Iraq a couple more months to finish it up while Im away. will be in states for a couple of days to check it out and do some light wheelling. Phase II and III will start in August and should be finished up by Christmas. I plan on doing a cross country trip with it for a couple of months finishing off in Moab next Easter.
/wave
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
Post Comments or Questions on "CAIN" Build
Phase III The 426 Hemi: Wrapping Up
Full Build Thread
2002 TJ Sport - Sold
Thanks to My 2011 Sponsors
4ws.com - Pitbull Tires - Rock Krawler Suspension - Poison Spyder Customs - Poly Performance
Old 04-30-2009, 08:58 AM   #5
teamoney
very cool. the seats are a nice touch to phase III
teamoney is offline   Reply With Quote
Old 04-30-2009, 01:37 PM   #6
CalebsXJ
I saw thing in the shop the other day, Its a looker great job!
2000 Jeep XJ; Heated Leather; 5.5 w/ACOS; 32's BIGHORNS; RK 3 Link; RE Monotubes; Rock Sliders; Rustys TC Skid; Front & Rear Recovery; Cobra CB; Flo-Pro Exhaust; Airaid; Surco Rack; HD Steering Crossover; IRO Adjustable Track Bar; SOLID d30 Cover; Recessed Winch Bumper; Gorilla Silver Back Series Winch; Hella 500 Lights...
CalebsXJ is offline   Reply With Quote
Old 04-30-2009, 05:39 PM   #7
03Jeeper
03Jeeper's Avatar
i am for sure crawling this thread, looks awesome, I can't wait for more pics!!
sick build
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
My totaled TJ rebuild
03Jeeper is offline   Reply With Quote
Old 05-09-2009, 02:22 PM   #8
Liquor
BOUNTY HUNTER
Liquor's Avatar
added the Tuffy Security Deck Enclosure, the Cobra 75 WX ST, and a 102" Whip Antenna to the Phase I list. gotta secure the subs, receive trail chat with the CB, and get the "Redneck Stamp of Approval" with the classic whip antenna
Phase I is about to wrap up. so long as i stop adding stuff to it. it will make an appearance at the Project-JK West Coast Mega Meet 2009 on June 27th. the suspension is good to go now. skid plates arrived and are to be installed early next week. seats are installed but having issues with the wiring. safety cage is in paint now. sway bar skid is on back order though.
im having a hell of a time finding another set of '07 300c srt seats. was hoping for find another front set to get them installed. also wanting to get rid of the hard top and get a wild boar fastback top. thought i had it sold but no reply from a possible buyer recently.
im really looking forward to finally seeing this JK in person again. its been far too long since i drove it. just 1 more month and ill be waving at the rest of our community again. this time in a built JK.
oh and i put in a request for more pics and a side profile along with it sitting next to a stocker. we'll see what i get this monday or tuesday.
Full Build Thread
Old 05-12-2009, 03:42 AM   #9
Liquor
BOUNTY HUNTER
Liquor's Avatar
added 2 more pics to OP - will get a few more pics soon of it in a side by side comparison with a stock JK
Full Build Thread
Old 05-12-2009, 09:48 AM   #10
digitalcox
digitalcox's Avatar
Awesome build so far, good luck and have fun. I would like to see how the SRT-8 seats look inside the JK.
digitalcox is offline   Reply With Quote
Old 05-26-2009, 03:05 PM   #11
Liquor
BOUNTY HUNTER
Liquor's Avatar
I added Rock Krawlers Rear Coil Over and Triple Threat Systems to Phase II. Combined Phase II and Phase III. Phase II starts this August.
Full Build Thread
Old 06-11-2009, 11:32 AM   #12
Grant211
more pics!!!
i'd like to see the seats installed.
Grant211 is offline   Reply With Quote
Old 06-11-2009, 11:37 AM   #13
smithtime09
my JK dream..............
-Captain Obvious
smithtime09 is offline   Reply With Quote
Old 06-11-2009, 11:43 AM   #14
Kraxen
your running 39s on stock d30 wow lol
Blue 92 YJ 4.0L. - RIP
Green 95 YJ 2.5L.
"jeeps dont die, they just get rebuilt"
Ordnance corps us army
Eat, Jeep, And Be Merry,
Kraxen is offline   Reply With Quote
Old 06-11-2009, 12:16 PM   #15
4pointOH1998
It's not a stock D30
One hell of a build, but if you're going through all the effort, why not go for some beefy axles?
-Bryan- ΚΔΦ-MΘΣΝΔ
Fighting the rust since April '08...
A Maine XJ Nightcrew!
4pointOH1998 is offline   Reply With Quote
Glock Forum
