Quantcast Heep to Jeep - 97 TJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Heep to Jeep - 97 TJ Build
Old 01-05-2009, 08:54 PM   #1
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
I have really enjoyed looking at all the build threads here on JF and the build by Gerald with Savvy "2003 Unrolled (pics)" actually inspired me to buy this Jeep. I bought this heep back in early July 08 and have spent the following couple months putting it back together. I thought I would create a build thread for everyone to enjoy. My intent of this build was first to get the Jeep running and driveable and go from there, however building this on a budget was important and getting as many things as possible used was my intent. I have been working on the jeep for a couple months and will do my best to update you with my past progress and any further updates. Please be patient as is might take me some time in between posts. Thank you for your time!!
The jeep specs are as follows:
97 Jeep Wrangler Sahara
4.0L
5-Speed
Dana 30 and 35 3.55's
127,000 miles
4" Pro Comp Lift
Quick Disconnects
Major Front end damage, Passenger Rear Tub Corner damage, bent front axle and misc missing or damaged parts.
Here are some pictures of the damage
cotton_4x4 is offline   Reply With Quote
Old 01-05-2009, 08:57 PM   #2
spyder6
Just violated my Parole
spyder6's Avatar
you've got some work ahead of you! good luck
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 01-05-2009, 08:59 PM   #3
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
Here are some pics of the day I picked the heep up. The PO had bolted up a grill and some fenders. You can see the bent axle pretty good in the second pic. The tires were pretty nice too!
Old 01-05-2009, 09:02 PM   #4
abeshures
WOW!!! i cant wait to see what you do to it. good luck man thats quite an undertaking. Keep us posted
abeshures is offline   Reply With Quote
Old 01-05-2009, 09:42 PM   #5
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
Here are a couple more:
Old 01-05-2009, 09:52 PM   #6
hockeyplayer21
how much did you shell out for that?
hockeyplayer21 is offline   Reply With Quote
Old 01-05-2009, 09:53 PM   #7
MasterCujo
Well, at least the interior looks pretty good, all things considered. Good luck, man. Can't wait to see the final product.
'98 BOR HEMI in OD green paint
MasterCujo is offline   Reply With Quote
Old 01-05-2009, 09:54 PM   #8
b_c
ambition is the key ingredient to great men...
...good luck
b_c
Colorado JeepPeople
my 2008 jk build
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline   Reply With Quote
Old 01-05-2009, 10:10 PM   #9
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
So the wreck messed up a lot of stuff in the front end, like the radiator, A/C condenser, power steering pully, fan, fan shroud, overflow bottle, etc. I started with replacing the bent steering pump pully and while I was at it I replaced the Harmaonic balancer, water pump, timing chain gasket. and thermostat gasket. Following this I installed a new radiator and A/C Condenser.
Old 01-05-2009, 10:14 PM   #10
jimaug87
how did the airbags not blow?
good luck that heep jeep
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline   Reply With Quote
Old 01-05-2009, 10:24 PM   #11
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
Thank you all for the kind words!! I really appreciate the encouragment....it was definetly a little scary buying something that most people would say is junk and not worth anything. I am just trying to keep in mind the potential the jeep has. Anyways.....for those that are curious as far as cost.....I bought the Heep for $2700 and a grill, fenders and tailgate for another $400 bucks from the same seller.
I am not sure how the Airbags did not blow!! Crazy! I have also been trying to figure out how the frame did not get bent! I wish I new the story behind the wreck!
Old 01-05-2009, 10:35 PM   #12
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
Next I found this Hood on Craiglist for $100 bucks. However it had been in a roll over and needed some work. I figured a little bondo would do the trick considering the jeep is going to get painted Flat Black anyways!
Old 01-05-2009, 10:42 PM   #13
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
Next I painted the Hood and Grill Flat Black....sorry I don't have a pic of just the hood painted! This brings me to the next big project of removing the bent front axle and installing a used one out of a cherokee. I ended up finding a Dana 30 out of a 2002 (I think) cherokee with the same gear ratio for $250 bucks on Craigslist. Here is a picture of the paint and axle removal.
Old 01-05-2009, 11:11 PM   #14
cotton_4x4
Rollin Dirty
cotton_4x4's Avatar
Here is the xj axle......not a High Pinion...but o well it is the right gear ratio!! Everything bolted right up with out any big issues! Picked up some Free 32X11.50 BFG All Terrians with about 1/4" of tread left from my Cousin....should work for the time being. Also found a full set of TJ sport flares for $60 bucks...threw these on and we are getting close to a test drive!!
Old 01-05-2009, 11:32 PM   #15
ArrizX
1997 XJ Cherokee
Great job I like it so far!
The work must be tedious with this. Not only are you replacing busted parts and panels, but for each panel and such you need to get the correct bolts, nuts, washers, etc. I would hate that!
ArrizX is offline   Reply With Quote
Glock Forum
