GTX's low rider TJ build - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > GTX's low rider TJ build
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 10-26-2010, 07:49 PM   #46
nibstools
So now you got to cut the hood down? Looking good so far!
nibstools is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 08:07 PM   #47
jharvey615
Are your tires the red label crawlers and what about the sipes in the tread custom?
Don't out think your common sense!
jharvey615 is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 08:26 PM   #48
gtxracer
Thanks! Just the hood left to cut.
Blue labels, street compound. 35 Krawlers aren't available in red compound but I still drive it to the trail so I need the blue labels anyway. The sipes in the tread are for better traction in the snow, previous owner (shameless plug: Larry @ Crawl magazine) did them.
gtxracer is offline   Reply With Quote Quick reply to this message
Unread 10-27-2010, 09:08 AM   #49
BPJOOP93
looks nice so far whats the plan for the rear, with tire clearance?
BPJOOP93 is offline   Reply With Quote Quick reply to this message
Unread 10-27-2010, 10:42 AM   #50
gtxracer
Thanks! Actually the rear has a built in 1" lift from the 8.8 axle tubes donors slightly higher than the front. This is why I want zj coils up front but right now some minor trimming will be more than enough to clear the krawlers. I'll take pics and write that up too.
Unread 10-29-2010, 08:15 PM   #51
gtxracer
Made a lot of progress on the TJ and even drove it today. It sits nice and low so I'm real happy. Need to finish the little touches then its time to install the RCV shafts.
Here's the rest of the install:
First off, I can't stress enough - CUT YOUR HOOD FIRST! And make sure it's straight. I need an entirely new front clip, maybe not a grill, but everything else is too tweaked. Oh and don't even try to crimp a lip on the hood, just cut it and make sure you measure 15 times before you cut.
So, I have a very loose front end and wanted to make sure it was secure. I made some extended front body "bumpers" by taking off the stock ones and adding some leftover body mount pucks and making their holes bigger to put a bolt through. There's no nut on the end, they're held in place by gravity and the frame. Oh and drilling out the bumpers takes some patience and technique, it will take off the finish from any black drill bit-
Unread 10-29-2010, 08:20 PM   #52
gtxracer
Then take the hood off since you didn't cut it first
I would show the measuring and taping process but mine didn't work correctly and I had to eyeball it and trim, test fit, trim, test fit, etc because I didn't cut the hood first then build the fenders off it. So, that's another reason to cut the hood first AND while it's on the Jeep....so much easier.
Finished product
Unread 10-29-2010, 08:22 PM   #53
USAFRecon
Awesome man great job
USAFRecon is offline   Reply With Quote Quick reply to this message
Unread 10-29-2010, 08:23 PM   #54
gtxracer
Today I parked on a hill next to a TJ that is similar to mine but mostly stock in the lift/tires. Overall mine is only about 3-4" higher even with a hard top.
Unread 10-29-2010, 08:24 PM   #55
gtxracer
Thanks!
What's your AFSC? I was an active duty Ammo troop (2W0) for fours years and now I'm a 1C4 in training in the ANG.
Unread 10-29-2010, 09:55 PM   #56
USAFRecon
2F051 Fuels Troop
Unread 10-29-2010, 11:16 PM   #57
gtxracer
Ah, cool! I knew of few fuel guys when I worked on the flightline. Try not to smell the fumes! Haha
Unread 11-06-2010, 12:24 AM   #58
gtxracer
So I replaced the springs and pins in the front lock right the other day and found this-
Whoops. I put it back in after I removed the chunks. It was still working, just had the clicking action, so I think it should be fine. Gonna run it til it explodes I guess.
Start this crazy install-
Won't be done until mid next week, too much stuff going on right now. Might be going wheeling up north in the S N O W
Unread 11-06-2010, 11:27 PM   #59
Ramathorn
Can't wait to see the finished product! Thumbs up for a fellow Washington jeeper!
Ramathorn is offline   Reply With Quote Quick reply to this message
Unread 11-07-2010, 02:53 PM   #60
gtxracer
Thanks! Hope to finish it this week!
