GTX's low rider TJ build - Page 29 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > GTX's low rider TJ build
Memorial Day Weekend Sale Starts Friday-Tuesday 10% off + All Bilstein shocks & struts - Lowest Prices Ever and RuffStuff Memorial Day Sale!
Unread 06-10-2012, 10:06 AM   #421
gtxracer
My bad, they're good to go now!
gtxracer is offline   Reply With Quote
Unread 06-11-2012, 07:02 PM   #422
gtxracer
It runs and drives, drove it around the neighborhood in 4lo. Couple things-
destroyed one of the cables on the D300 from the leverage of the twin sticks
definitely going to flat tow it for now, it's LOUD
no reverse, shift fork must not be lined up, easy fix
clutch safety switch bypassed with a closed circuit (some say a fuse is a fix)
starter works intermittently because of above
corners are nearly done, came out well and will use stock flares for now
steering hits the passenger side spring mount, need to trim it
front locker seems to be engaged permanently, like a spool
need to final weld the shock mounts
finish front 2 piece driveshaft
tidy up the welds, flap disc any remaining edges and paint them
Sorry for my lack of pics and tech, I'll add more later. I spent most of the time in the shop from the past three days fixing little issues, tracking down wires, and finally driving around the block.
Carrier bearing mount finished, ready to put in place. The plan for this came together well, the opening I drew happens to be in just the right spot for the bolt to pass through
stubby short shaft of the 2 piece driveshaft
corners, my fantastic girlfriend drilled the holes, what a sweetheart!
The clutch safety bypass, took out the connector and made the circuit complete. Starter works most of the time, feels like the computer or solenoid is fighting the wiring for control over the starter.
I'll be back Friday and will be kicking *** all weekend to get the TJ and Silverado ready for the trip next Tuesday.
Unread 06-11-2012, 08:14 PM   #423
Louie4
Injanir
Louie4's Avatar
I'll be waiting for the pics. Sounds like you got a lot done.
BTW, thanks for the idea of the pitman arm. I got one as well to help with my hi-steer setup. Works great. Now I just need trim some brackets off the frame.
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Unread 06-11-2012, 10:59 PM   #424
gtxracer
No problem! I like them, they give the steering more of a bling look.
Unread 06-12-2012, 07:32 AM   #425
Louie4
Injanir
Louie4's Avatar
Mos def.
The pic is deceiving because the scratches on the tie rod were there with the old arm and actually the drag link clears the tie rod when I turn the wheel to the left.
Lou
Unread 06-14-2012, 07:29 AM   #426
MisfitSeven
MAIL Crawler.
MisfitSeven's Avatar
So, here's the million dollar question: How much of your turning radius did you guys lose after installing that pitman arm compared to stock?
I would take a pair of JJ innards off of someone's hands... PM me.
MisfitSeven is online now   Reply With Quote
Unread 06-14-2012, 08:45 AM   #427
gtxracer
I haven't noticed anything so far, but I'll keep it in mind and report back. It's not much shorter than stock.
Unread 06-14-2012, 05:27 PM   #428
Louie4
Injanir
Louie4's Avatar
I noticed some but it's not a deal breaker. I have about 1/4"-3/8" gap between my steering stops and my C. Of course I can't hold the wheel at full lock and check so I had to rely on the wheel lock. I did try to make a right hand turn at a small intersection and I didn't start turning soon enough and went into the other lane. I'm glad no one was coming the other way.
Lou
Unread 06-15-2012, 05:19 PM   #429
MisfitSeven
MAIL Crawler.
Mos def.
What knuckle do you have on your passenger side? Pic?
Unread 06-15-2012, 07:41 PM   #430
Louie4
Injanir
Louie4's Avatar
Teraflex. I got it from a buddy in PA. He sent it to me as well as a drag link and beefy tie rod.
Lou
Unread 06-22-2012, 07:34 PM   #431
gtxracer
Alright here's the update...
I picked up a HF tow bar and magnetic light kit then made my own mounts that bolt to the factory bumper mounts. It's all 3/8".
Here's the total pain in the *** 2 piece shaft
The couple days before the wheeling trip are a blur. I was in the shop no less than 14 hours each day, throwing things together, drilling, welding, etc. I got most of it finished to go to the shake down run but didn't get to test the front shaft. Then the front locker wouldn't disengage :shaking: So I had to pull the shaft from one side in order to flat tow.
Filled up and heading out
Had to take the pass in order to get to the trail
After settling in I tore apart the front end to see why the lockwrong was acting up
I had the damn thing apart for 5 hours and rebuilt the diff but it still won't unlock. Springs are pretty fresh, I replaced them a few runs before the rebuild.
Unread 06-22-2012, 07:53 PM   #432
gtxracer
Side shot, the wheelbase felt great
Onto the wheeling...
Couple things to note - I didn't have FWD. Front driveshaft wouldn't stop moving, more specifically, the carrier bearing wouldn't stop moving inside it's mount. I couldn't get the damn thing to stay in one spot and the angle was too much. I wish I would have had more time to test it but the front locker put me out of the game anyway. It's hard as **** to drive a spooled front end - unless you have twin sticks. Wanna guess which cable shifter broke the other day? Yeah, the front stick. haha
So, screw it, I'll wheel in RWD. Air'ed down to 6psi and hit the trails. Only ONE hill denied me and I almost made it! I got it on video, I need to do some editing though. I also got a GoPro Hero 2 from my fantastic girlfriend so I got footage there too.
I'll get the vids uploaded as soon as I can. Overall the Jeep kicked ***! The suspension felt MUCH better than the stock junk. I didn't get a chance to really test flex but I need longer shocks up front for sure. I knew this already since they're only 9" travel but I'll need to have a lot more seat time to know if it's really needed. The np435 was great, low gear is great to have. The D300 is actually a good case despite it's inability to hold fluid.
I'll be redesigning a few things and hopefully have a regular CV shaft up front instead of the time consuming 2 piece and the heavy mount. I'm also ditching the cables and converting to a regular linkage shift for the D300.
Unread 06-22-2012, 08:36 PM   #433
Tylerzap
Damn that thing is beautiful!!!
My 98 XJ "Zap" Build Thread
http://www.jeepforum.com/forum/f22/zap-98-xj-build-1462622/
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline   Reply With Quote
Unread 06-23-2012, 10:48 AM   #434
gtxracer
Thank you!
video - don't mind the rambling, might be a couple bad words in there so if you're sensitive don't watch it
Unread 09-26-2012, 09:24 PM   #435
gtxracer
Ordered a stak D300 replace-a-case last week, I've been told it will ship tomorrow. I'm STOKED.
