GTX's low rider TJ build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > GTX's low rider TJ build
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 10-20-2010, 05:31 PM   #16
gtxracer
you can see the old shifter that I threw together for my first trip
Bent and cut it and got this:
Welded it up where I had cut it and it came out great. Painted it up, and it's ready to go. It's just a simple push/pull shifter, not much. I have a new boot to go over the shifter opening and it just slips over the lever on the case. I'll crimp the end once it's on the case.
Picture of the nutsert. My camera makes everything look 10 times worse than it really is!!!
Another shot of the rear corner, came out great!
gtxracer is offline   Reply With Quote Quick reply to this message
Unread 10-20-2010, 05:32 PM   #17
gtxracer
After this I wanted to wheel it a little bit, so I did that
Entrance to BusyWild. I won't be doing this trail until I get a winch and more armor. I also want it to be a little less wet, haha. It swallowed a CJ on 38s, a stretched YJ on 36s, and even tore up a Toyota front axle to the point where the 4 studs holding on the steering arm sheared off.
This had RCV axles in front....nice Rubi
Unread 10-20-2010, 05:33 PM   #18
gtxracer
and some video from evan's creek-
Click it for HD 720p
YouTube - Jeep TJ on 35 MTRs crawling on the way to Evans Creek
I'll post more later, I have a lot of wheelin pics and some more updates to do but this is quite a bit so I'll let it soak in
Unread 10-20-2010, 09:48 PM   #19
jharvey615
Nice like were you are going with it good choice on the 8.8 also.
Don't out think your common sense!
jharvey615 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2010, 01:17 PM   #20
gtxracer
Thanks I got a good deal on the 8.8.
Big update soon.
Unread 10-21-2010, 01:41 PM   #21
ibjeepin95
ibjeepin95's Avatar
Looking great so far! Did I see your build on Pirate??
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2010, 09:44 PM   #22
gtxracer
Thanks. Yeah I'm on pirate too.
Unread 10-22-2010, 08:47 PM   #24
gtxracer
nice YJ
another group shot in the rock bowl, my TJ in the middle front
Unread 10-22-2010, 08:49 PM   #25
gtxracer
Current stuff:
Got some new goodies for the TJ...starting with some new shoes.
Thanks to Larry at...
I've also been wondering what I wanted to do with my front end. I could go with a custom HP44 I found for about the same price as RCV shafts. It had been narrowed, new 4.10s and Auburn LSD, new BJs, brakes, etc. However, it had been sitting so it needed work, plus TJ brackets. I would have had a one-off stock 3/4 ton axle and would need to get some new shafts in the 8.8 to match the 5 on 5.5 pattern. After thinking about it and actually looking at the axle, I decided it would be a much better investment to buy the RCV Ultimate shafts for the HP30 since they can be sold for close to what I paid for them, are "unbreakable" with lifetime warranty, and are smoother and stronger than alloys and CTMs. Plus, with a HP30, it's a throw-away housing if I ever bend it or strip a gear set. I run 4.10s, so the gears are stronger than 4.88s and are found in factory housings easily for anywhere from free to $200. Decision made.
I do need to change my overall crawl and drive ratio, meaning if I'm not regearing I'll have to go a 4speed transmission with the granny low or a NV4500. Still deciding on that one. I don't use 5th gear as it is so I think a np435, sm420, or T18 is in order. Reading builds like Alxj64's 7/8 ton TJ has given me a lot of info and guidance so I'm thinking I'll go with a np435 later down the road. If I find a nv4500 for a good price I may go that route but I'll have to give the TJ a stretch. All this will happen mid-next year around May when I finally get done with training. Until then, I'm just gonna wheel
Unread 10-22-2010, 09:05 PM   #26
gtxracer
On one of my many trips out wheelin this year, I bent one of the body mounts. I tried to bend it back best I can but it needs to be cut off and a new one welded on.
Body lift removal....1" vs the 3" that came off. Yes, I just cut the pucks
Jack up the body with a block of wood, cut each mount individually and put the long bolts back in. Like this-
Don't forget the front puck, it matters!
Then let it down slowly, one side at a time. Remember to check the gas tank extension, steering shaft, both shifters, and other parts that come down the body but are connected to the chassis. I had no problems and everything works better than it did before.
All down-
Replace with the new, 2 inch shorter bolts. It will sit real low, like this-
Unread 10-22-2010, 09:11 PM   #27
gtxracer
One reason to replace the bolts, even if you're just bolting them back up, if they look like this-
That was my worst one, looks like that body lift has been on there a long time.
RCV shafts showed up while I was working-
most blingin parts on the jeep!
Almost forgot, 8.8 got some armor too-
Unread 10-22-2010, 09:21 PM   #28
gtxracer
Obviously this is too low to be useful, so we need to do something
take out the battery and battery mount
next, the fender
gives you a blank slate
Move it up a lil bit, where you want the hood line to be now
Unread 10-22-2010, 09:24 PM   #29
gtxracer
A high line hood and fenders also means either modifying the hood latches or mounting hood pins...guess which one I chose
Those are billet so they're heavy and I don't think I'll be messing with them again...however I like the Jeep feel when you unlatch the hood so I might find a way to keep them.
Unread 10-22-2010, 09:30 PM   #30
TJLover99
Killer build man. I like the cut off fenders in front and the rear corners came out great, keep up the good work
If it were easy, everyone would do it
TJLover99 is offline   Reply With Quote Quick reply to this message
