GTX's low rider TJ build - now 4500 Ultra4 wannabe
***updated Dec 2015 - This has turned into a nearly full blown 4500 Ultra4 wannabe build!
The 1/2 ton version of the build is complete (I broke my D30 in half at the dunes) and moving onto one tons, see page 39 for 1 ton Eaton hybrid***
For the fastest updates, follow me on Instagram: @jeeps4Trevin
I'm nearly finished with the first "phase" of things. I know a few of my buddies on here have wanted to see it so I'm posting up.
First up, background-
'97 TJ Sport
4.0/AX-15/NP231
LP D30 with 3.55s
D35 with 4.10s
Smittybuilt bumper
chrome EVERYWHERE
sagging 4" Skyjackoff lift
3" bodylift...yeah, wow
The good stuff:
Full banks stainless exhaust, the good kind of header and flowmaster
came with a HP30 with 4.10s
got a great deal on it
swapped in 4.0 with less miles and all is good
Alpine deck and 6.5s, Kicker 5 1/4s
Came with 35 MTRs in good shape on black steelies
Sold some of the crap for cash
hard top
hard doors too
The plan (old, see last pages)
long arms - done, with stretch
0-1" suspension lift, 1" body lift done
cage
8.8 swap done
HP30 swap done
4.10s done
locked on both ends done
RCV shafts done
SYE + CV done
35" Krawlers on alum rims done
warn upright winch done
high line fenders done
sliders
rear corner armor done
front and rear bumpers
I'll add more to the list and update as time and build goes on.
This belonged to a guy's wife. She just liked having a lifted Jeep to ride around in, didn't care about 4wd or anything like that. Can't blame her, it's a cool Jeep. The sound of the full exhaust is awesome!
section out some material to blend it into the frame
angle is a lot better, 20*, tack in place
gets you this
Needs quite a bit of trimming in the rear...but it's progress. Gotta pull the corner armor off and trim some sheet metal on the passenger's side before I can mount up the last tire but at least it's sitting on it's own.
Werd, I forgot to mention I needed to move the Jeep around so I am using these temporarily. I was hoping I could notch these to achieve a perfectly flat surface but I don't think it's possible with a 4" stretch. I have a new design for a coil bucket and it will be flat. Thanks for the advice.
Not really looking to do that much work. It's easier to fab some coil buckets from 10g or 1/4" plate but thank you for the advice.
Cables came in
I've been babbling about a couple of new tools in the shop
It's a JMR Sportsman bender with a Pro Tools 1.75 240* 6 CLR die. I bought the bender directly from JMR and the die from TMR Customs. Overall I'm satisfied with both purchases so far and they were shipped in a timely manner for the most part. I'll be converting the bender to air over hydraulic with some homemade brackets and a HF 8 ton jack.
Now that you say your just doing that for temporary purposes.. Thats fine. Haha. But ya. Flat and custom will be nice.
Im pretty sure you can get away with a 4in stretch and not notch the frame while keeping the coil spring mount the same height as factory and not giving extra lift
Builds Lookin good so far. Keep it up :thumbsup:
I just could not stand to see you leave
That coil mount Lookin like that when you put all this time into everything else
Nice build ive seen your jeep at elbe before. I ran with Dog pound offroad and that cut up willys before he breaks alot lol I was neigbors with his buddy with the red cj7 red beard
I checked them out, forgot about those. I would love to backhalf my jeep, especially since I have the bender now, but that's a lot of work and I need most of the factory brackets back there so it has to stay.
Front shocks will go down to the axle side coil bucket mounts. Might even just weld a bolt there if it's the easiest route. They cannot be mounted to the control arms as they're 4130 heat treated and that would alter the (chemical) properties of the metal. They would have to be TIG'ed properly to do it right and that's not needed anyway.
Had to work all weekend so only got a little bit done last night. Cut the tub a little bit, yanked off some of the armor and tailgate, then set her down on all four tires. In order to steer her around she needs a track bar.
Yes, the track bar is longer than the current steering setup because I am anticipating a WJ knuckle swap and only want to do the track bar once. I'll live with a little bump steer for a short time before the swap. Don't be jealous of my camo frame mount.
holes drilled, mocked up, frame sleeve. Hopefully this gives me enough adjustment to account for the WJ knuckle swap. Track bar is 32.75" right now, plenty of adjustment left. I may end up having to redo the frame side mount but if this design works then It should just be a simple unbolt and move.
everything is tight, clearance is low, but this is at stock height. I've been thinking of running some 2" coils. It will make more clearance for when I run 37s anyway. That's still a while down the road but a 1-2" lift could make things easier down there. As of right now there is 4.5" uptravel at the coils. Actual clearance is more like 3". The axle side track bar mount will get into the frame if the passenger side is fully articulated. I'm not sure if I'll be able to clearance it or if I'll have to notch the frame.
Here you can see that it's not exactly the angle it should be with the factory steering. It's already ~6" too long (factory drag link length is about 26.5" for reference).
I'll be rolling out the TJ this weekend to do some maintenance on my XJ and the girlfriend's civic. I'll be sure to snap some pics in the sun daylight. Track bar is tacked in for now but I already know I want to move it back an inch or more on the frame. No big deal, just need to trim the coil bucket mount.
Put a tape measure under the rig. Went from the back of the rear axle tube to the back of the front axle tube...102".
Are your lower arms going to rub or bump your coil bracket if you droop far enough? Are you going to mount the lower shock bolt to the axle tube or the coil bracket?
This is an area that I have been running into problems, and have a couple questions and concerns. I am watching this build like hawk, keep it up.
They shouldn't rub, it's almost exactly the same as the stock location. They're ~10" travel shocks, so shouldn't be a problem.
A single bolt will be welded underneath the coil bucket in the corner nearest the tire. Easy, effective, and will break off if it ever has stress on it instead of killing a shock. The stock bump stop buckets aren't exactly bulletproof so I would rather have it this way for now until I get a better setup...like coilovers.
Thanks for the props. Unfortunately the shocks won't get mounted until the very end of this build since it's an item that needs to be done after the suspension is finalized and burned in.
Looks good! that wheel base looks good with the front stretch! been reading your thread on pirate about the troubles you are having with shifting been giving me some good ideas for what i want to do! Keep up the good work!
:thumbsup:
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
