GTX's low rider TJ build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > GTX's low rider TJ build
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 10-20-2010, 05:20 PM   #1
gtxracer
For the fastest updates, follow me on Instagram: @Jeeps4Trevin
I'm nearly finished with the first "phase" of things. I know a few of my buddies on here have wanted to see it so I'm posting up.
First up, background-
'97 TJ Sport
4.0/AX-15/NP231
LP D30 with 3.55s
D35 with 4.10s
Smittybuilt bumper
chrome EVERYWHERE
sagging 4" Skyjackoff lift
3" bodylift...yeah, wow
The good stuff:
Full banks stainless exhaust, the good kind of header and flowmaster
came with a HP30 with 4.10s
got a great deal on it
swapped in 4.0 with less miles and all is good
Alpine deck and 6.5s, Kicker 5 1/4s
Came with 35 MTRs in good shape on black steelies
Sold some of the crap for cash
hard top
hard doors too
The plan (old, see last pages)
long arms - done, with stretch
0-1" suspension lift, 1" body lift done
cage
8.8 swap done
HP30 swap done
4.10s done
locked on both ends done
RCV shafts done
SYE + CV done
35" Krawlers on alum rims done
warn upright winch done
high line fenders done
sliders
rear corner armor done
front and rear bumpers
I'll add more to the list and update as time and build goes on.
This belonged to a guy's wife. She just liked having a lifted Jeep to ride around in, didn't care about 4wd or anything like that. Can't blame her, it's a cool Jeep. The sound of the full exhaust is awesome!
Pics when I got her
Euro tails :laughing:
gtxracer is offline   Reply With Quote Quick reply to this message
Unread 10-20-2010, 05:21 PM   #2
gtxracer
HP30 needed some help, I'll let the pics speak for themselves. It's a XJ CAD model, first used a stock plate that I modified then ordered the kit from Randy's. Also used a SealsIt D30 seal for the passenger's side since the ones in the kit were of NO use to me at all :shaking: This looks like a '87 or '88 model so be warned, skip the kit and just buy a SealsIt and never look back.
Unread 10-20-2010, 05:22 PM   #3
gtxracer
You get the idea, did the whole thing up.
Pulled in the Jeep, swapped it over
You can modify the stock box to blockoff the CAD if you cut the shaft and reinstall the clips
Unread 10-20-2010, 05:23 PM   #4
gtxracer
Found a lincoln 225 online. I learned on one of these, so I picked it up
Randy's kit, if you want it, this is what it looks like
stock fenders were beat up a little, so they had to come off
Cardan joint in the front shaft was fubar, bought a new shaft from a guy in PDX, he ran a sweet land cruiser shop
Unread 10-20-2010, 05:23 PM   #5
gtxracer
stock airbox was held on by one bolt and I knew I didn't want it after the highline, so I tossed it and bought this cone filter for around $20
Still need to make a good mount for it
These gayass tails had to go
LEDs, gonna black them out soon
Did the front too
Unread 10-20-2010, 05:24 PM   #6
gtxracer
Needed something up front to give me some kind of protection. Picked up some box stock to make a temporary stubby bumper and get better at using the lincoln.
One for the welding nazis
Few pics of how I did it
Cut out the back
Unread 10-20-2010, 05:24 PM   #7
gtxracer
East Coast Gear Supply has great deals on 8.8s ready to go for TJs so I jumped on it. I basically got an 8.8 for the same cost of parts but it was already welded up and had 4.10s in it.
35 has to come out
Also swapped out the saggy 4" springs for stock Rubi stuff
Unread 10-20-2010, 05:25 PM   #8
gtxracer
In
Only snag was the T adapter stud didn't quite line up. I'll weld it on in the original spot later. The E-brake cables were kind of a pain in the *** but no big deal.
Old next to the new before going in
slip yoke isn't going to be up to par
I'm not sure if all TJs come with the risers on the tcase to drop it about an inch, but my last TJ had them as well. Took those out, made the stock skid as flat as I could. You can see the angles in the above pics.
Snagged the Rubi takeoffs with shocks for $100
Just a couple pics underneath
Unread 10-20-2010, 05:26 PM   #9
flatlander757
Needs more trianglation
Welcome to JF buddy... why only 4:10s? You really need 4.88s or 5.13s for it to be great.
I'm guessing you got the 8.8 already geared to 4:10 so geared the front to match?
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2010, 05:26 PM   #10
gtxracer
Nutserts are $15 each, good thing I just needed one and bought a spare.
Oh, and these bolts are hard to cutoff without some kind of torch or plasma. Grade 8 bolts eat sawzall blades :shaking:
Aussie before going in
Goodies from Rokmen arrived
231s getting swapped out
stock 231 vs SYE 231
Picked it up cheap, so I just swapped them. It was from a YJ so I had to swap some random plugs but that was it.
This big ***** tried to ****ing smother me. I didn't realize they were so damn thick and heavy. It's comparable to my RE skid but doesn't look like it. I thought maybe 30-40lbs but it must have been close to 60 or 70 and I didn't have a clue or a trans jack, haha.
Unread 10-20-2010, 05:26 PM   #11
gtxracer
All this came out from the skid....wow
Pic from the workspace
Pics of the skid plate, pressed flat, like I was saying.
Pic of the Explorer CV shaft I had cut down. Also got the Spicer adapter on there
Old vs new
Nothing but grade 8
Unread 10-20-2010, 05:28 PM   #12
gtxracer
Been lurking, figured I'd post up for more peeps. 4.10s with 4.0 and 5 speed ain't bad. I'll be doing a sm420 or np435 swap down the road so it will all make sense. Plus 4.10s are available in 8.8s and HP30s from the factory, makes it easy and cheap.
Unread 10-20-2010, 05:29 PM   #13
gtxracer
Yank out those spider gears
Install the Aussie
Unread 10-20-2010, 05:30 PM   #14
gtxracer
Hit the corners with the flap disk
Then primer and hammered black
Then onto the lock right
Pull the carrier
Take off the ring gear, loosen bolts while in the housing. Take out the crush pin and center large pin
another view
remove the spider gears
Unread 10-20-2010, 05:30 PM   #15
gtxracer
Got this lockright from my ex-SEAL buddy...he's an awesome guy
slap it together, use grease to make it easier
Put the springs in
done, torque ring gear bolts to 80 ft lbs
Took these cone washers out too
old school torque wrench
Remember to properly mark everything
