GTX's low rider TJ build - Page 36 - JeepForum.com
 2Likes
post #526 of 683 Old 01-05-2014, 11:59 PM Thread Starter
gtxracer
Still haven't started my cage. Picked up the toob 2 weeks ago.
Went on a day trip this weekend, needed that for sure
small video from messing around, rear seems stiff and was jolting a bit. Shocks might be bad in the cold?
gtxracer is offline
post #527 of 683 Old 01-06-2014, 09:13 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Very cool looking and nice to see it on the trails.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #528 of 683 Old 01-07-2014, 01:32 PM Thread Starter
gtxracer
Thank you, it was good to get back on them. Might make it out this Saturday but we'll see.
gtxracer is offline
post #529 of 683 Old 01-09-2014, 03:04 PM
'92 vegas YJ
Hurry up with your Eaton swap. Hoping to throw in my rear Eaton soon with a D60 front. I have a 4.56 3rd currently for the Eaton but wouldnt mind a 5.13 3rd member. need to start looking around.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #530 of 683 Old 01-09-2014, 05:54 PM Thread Starter
gtxracer
Haha! I'm working on it. I need to do some measuring to finalize the width of each axle tube and then cut to length. I am also debating just retubing the axle. This would make it easier for me use a seal from Trail Gear or Spidertax but would cost around $240. For that money I could make a truss front and rear and just make sure everything is aligned.
As for axle shafts, I think I'll be picking up some of the Spidertrax two piece units from a racing team. It will just be the yokes and I can have the full float shafts resplined. Much cheaper in the long run.
Need to get the beadlocks powder coated. Hopefully picking up new tires Sunday. New coils and shocks will be going in the rear unless I can find coil overs for cheap. Will be going with a fuel cell like a RCI 2162 unless I can make the tj stretch tank fit. Also need to buy heims and the 7075 steering material. One last thing, I'd really like a sway bar in the rear if I can swing it.
gtxracer is offline
post #531 of 683 Old 01-22-2014, 10:39 AM
Ben
Originally Posted by gtxracer View Post
Update finally
Fabbed a new mount. 1.75x.120 DOM, 1/4" for the center mount. Still need to trim it up and weld it. I like this mount a lot more. Frame angle is 8* per side.
I like this build man, got a couple questions for ya.
Nice crossmember, is it a 4.0L/465/300?
What forced you into the front pillow block, the slave cylinder? You mention CJ hydraulics, what master/slave did you run?
Thanks,
Ben
Ben is offline
post #532 of 683 Old 01-22-2014, 04:16 PM Thread Starter
gtxracer
Thanks,
Ben
Thank you! Yes, 4.0/435/300. The 465 and 435 are pretty much the same trans, muncie 4 spd.
The front 2 piece shaft was to go around the slave cylinder. That's running low lift. With a 4" lift, you probably wouldn't hit it. I have to limit the uptravel on that side, even with 2" springs and 1.75" diameter driveline.
I'm currently remaking that 2 piece shaft and figured out what needs to happen in order for it to work properly. I'll post that up when I finish it. Might wait for the 1 tons.
I run a CJ master and slave cylinder, from a 4cyl iron duke motor, around 1985 year. I modified the TJ clutch plate on the firewall in order to mount the CJ master cylinder. Any will do, just make sure they jive with each other and run a hard line between them. If you have any more questions, feel free to ask. I over-thought a lot of the np435 swap, its much simpler than I realized at first.
gtxracer is offline
post #533 of 683 Old 05-08-2014, 11:56 PM Thread Starter
gtxracer
I guess this is a good time to announce that I ordered a pair of coilovers for the TJ. I need to get them on the Jeep before July 4th as that is my first ever dunes trip. I will try to get the cage in there by that time too.
Finals finished yesterday. Onto the madness! Trying to help my buddy finish his Taco 2RZ rebuild then I can work on my junk at night.
gtxracer is offline
post #534 of 683 Old 05-26-2014, 10:33 PM Thread Starter
gtxracer
Been busy since the semester ended...let me know what y'all think
this fell out
Took a joy ride like this around the block...pretty fun actually. Makes me want a flatty.
These showed up
Then started messing with some toob
gtxracer is offline
post #535 of 683 Old 05-26-2014, 10:41 PM Thread Starter
gtxracer
14" Fox 2.0 with resis, they will get thrown in the back first. Hope everything fits and the "stock" frame can fit all that shock and uptravel! That might fall off too...
Cut off the rear shock hoops to get max packaging
Also noticed that all of the forward fuel tank bolts were loose and one broke off. I hit a stump with the entire weight of the jeep back in january. Trying lines that only the guys with 40s took...heh, should probably cut all that off huh?
Bought these from Chassis Unlimited. These are $16.99 for a PAIR!!! Shipping is around $7 so that's a steal compared to all the others. Everyone else wants $25+ for EACH one plus $15 shipping. Good lord!
Also made these frame tie-ins
But my old press had seen better days. This is what happens when you don't have enough support on your press brake.
And this is the fix
Which led to this. Fits a 3" poly bushing from RuffStuff.
measure measure measure cut notch measure measure measure cut notch measure measure measure cut notch
gtxracer is offline
post #536 of 683 Old 05-30-2014, 08:40 AM
Holaday
Looking good. Can't wait to see the new axles in. There is a set on Pirate I have been eyeballing for months
Holaday is offline
post #537 of 683 Old 05-30-2014, 10:57 AM
Imped
Imped's Avatar
Wow, that's a hell of a deal for some seriously proper shock mounts. Nice tube work man, keep posting up.
OlllllllO
IndyORV
Imped is offline
post #538 of 683 Old 05-30-2014, 03:01 PM Thread Starter
gtxracer
Thank you! There's an Eaton/60 hybrid on Pirate for sale and some sweet built 60s. Both good deals! New axles will get built after the cage and coilovers and my tow rig needs new shocks.
Yup! Couldn't believe the price. Thank you, I have more to share, I'll post them soon!
gtxracer is offline
post #539 of 683 Old 05-30-2014, 07:49 PM Thread Starter
gtxracer
More progress
B spreader is at just the right height
windshield bars are in too. needs the support bars in the center
Thoughts? Still have a few more tubes to add, obviously
gtxracer is offline
post #540 of 683 Old 05-31-2014, 07:57 PM
AngryTJ
notching looks awesome man... any plan to run some diagonals from B to C both overhead and on the sides
AngryTJ is offline
88 yj Flat tow trail rider Shawn94 Jeep Builds 28 07-17-2011 07:37 PM
Low rider YJs frumpy Jeep Picture Requests 13 07-02-2008 10:50 PM
