G's LJ Build (It's not the devil I swear) - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > G's LJ Build (It's not the devil I swear)
Rancho Shocktober is here for fall 2015!!!!You Pick the Size and Style of Lift Kit. We will Find you FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-12-2013, 03:25 PM   #121
g-rocc
growing a redsox beard and holding the head of a deer is a good look for you G
That frozen beard look is nice too...
[B][COLOR="Red"][URL="http://www.stfoffroad.org"]Set Them Free Off Road[/URL][/COLOR][/B]
[B][URL="http://www.facebook.com/setthemfreeinc"]Set Them Free On Facebook[/URL][/B]
[URL="http://www.jeepforum.com/forum/f22/gs-lj-build-its-not-devil-i-swear-1570632/#post15866677"]My build thread[/URL]
g-rocc is offline   Reply With Quote Quick reply to this message
Unread 11-12-2013, 03:29 PM   #122
gspup
The frozen beard is great !!! haha
Originally Posted by dayriesw View Post
Nice to see someone who isnt scared of mud too.
I'm not scared of mud...
Here's mine after hunting...there is still mud falling off.
gspup is offline   Reply With Quote Quick reply to this message
Unread 11-12-2013, 03:31 PM   #123
AngryTJ
AngryTJ's Avatar
good thing you put those inners on huh
Tarantula_TJ Build
AngryTJ is online now   Reply With Quote Quick reply to this message
Unread 11-12-2013, 04:35 PM   #124
dayriesw
dayriesw's Avatar
Who needs those???
Jeep LJ on 37s : Build - http://www.jeepforum.com/forum/f22/i.../index125.html
Jeep Comanche: Build coming soon.
dayriesw is online now   Reply With Quote Quick reply to this message
Unread 11-12-2013, 04:40 PM   #125
LeeMasterGT
LeeMasterGT's Avatar
Real nice lookin deer! Looks pretty full bodied in that photo. Got an estimate on his weight?
Build Ruby Re-do
LeeMasterGT is offline   Reply With Quote Quick reply to this message
Unread 11-12-2013, 04:59 PM   #126
g-rocc
Gutted the camp consensus was around 200 lbs. I'm doing all of the processing for the first time so no butcher to actually weigh him. He had a really big neck in comparison to other deer I've seen.
Unread 11-12-2013, 05:13 PM   #127
LeeMasterGT
That's awesome. Very nice harvest!
Build Ruby Re-do
Unread 11-14-2013, 01:54 PM   #128
gspup
It was a very good thing I put them on.
G's wifey busted his new steering set-up mall crawling the other day
So we crawled under the LJ last night, sleeved the lines with kevlar wrap and re-routed others to keep them from rubbing through again. I'd figure I'd update this build because there isn't much happening in my thread.
Unread 11-15-2013, 08:11 PM   #129
g-rocc
It was a very good thing I put them on. G's wifey busted his new steering set-up mall crawling the other day So we crawled under the LJ last night, sleeved the lines with kevlar wrap and re-routed others to keep them from rubbing through again. I'd figure I'd update this build because there isn't much happening in my thread.
You have done enough work on it, update away.
Also, drove to work today and went to get a car wash and the manager cane out and denied me a car wash. A car wash denying me a car wash? Are you serious?
No leaks too.
Unread 11-16-2013, 06:37 AM   #130
AngryTJ
AngryTJ's Avatar
You have done enough work on it, update away. Also, drove to work today and went to get a car wash and the manager cane out and denied me a car wash. A car wash denying me a car wash? Are you serious? No leaks too.
Why were you rejected?
Tarantula_TJ Build
Unread 11-16-2013, 07:46 AM   #131
g-rocc
Too dirty. That's like a bar tender telling me I'm too sober for a drink.
Unread 12-05-2013, 08:46 PM   #132
g-rocc
Cage Ideas
Went to work on some cage design today with a buddy. Take a gander at some of the screen shots. It's not complete but it is a good start. Some questions that you guys might be able to help me answer.
1. For the rear seat belt, do the mounts on the cage need to be in the exact same place as stock or can they be be moved some? I would like to bring the C Pillar on a slightly steeper angle if we can move those rear seat belt mounts.
2. Does anyone have the bends and distances laid out for the A-Pillar? That's pretty hard to estimate w/o tearing it all apart.
Note it's not finished but please feel free to comment and provide me any feedback you can.
Unread 12-05-2013, 09:06 PM   #133
MO2500
MO2500's Avatar
There is no need for the bends in the A-pillar dash tubes. You can get straight tube down through the dash to the floor and it will be stronger. I would do something like Poly Performance and build a 2 piece A-pillar with a sleeve in the windshield area so you can rotate it into position before final welding. When I did Lu's cage it made it very easy to line up the A-pillars and door surrounds.
I will see if I still have the bend program for the A-pillars on my last cage. If i am remembering correctly the proper angle at the top is like 58* and so the bend at the dash would be like 32*. Those numbers sticks in my head for some reason but I'll see if I still have those dimensions saved.
Also, the windshield overhead bar, is there a reason it bends right before it welds to the A-pillar? If possible, I would run a straight bar and then bring the overhead diagonal right into the same joint between the windshield overhead bar and the A-pillar bend. That or if you want to keep your design like that at least add in a gusset between the bend in the windshield top bar and the bend in the top of the A-pillar.
Lastly, I would move that short little piece of tube supporting the bent diagonal brace in the C-pillar window area up to the actual bend in that tube so that it supports the bend. I assume you are trying to keep that area open for back seat access? otherwise I would just make that bent piece straight into the node on the B-pillar.
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 09:15 PM   #134
MO2500
MO2500's Avatar
My suggestions to make it a little stronger but still keep the interior free of tubes.
Build Thread
Instagram: @omsmike
Unread 12-05-2013, 09:18 PM   #135
MO2500
MO2500's Avatar
Using a top that windshield top bar can't be as far forward as I drew it. Just thought about that since you will need to be able to swing the latches on the top and clear the bar.
Build Thread
Instagram: @omsmike
colorado , lj , rokmen , set them free , spyder9
