GR8 Half Top on my LJ Rubicon - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > GR8 Half Top on my LJ Rubicon
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 04-23-2010, 09:59 PM   #1
Mud Machine
Jeep Addict
Mud Machine's Avatar
I finished putting a GR8 Half Top on my LJ and thought I would share it. All in all the entire project went pretty well. Only A few minor setbacks along the way but nothing to serious.
Special thanks to my buddy Jim, your knowledge and time is greatly appreciated!!
They have a standard and an extended version of the top which is 2 1/2" longer. This is the extended top.
One of the toughest parts was making sure to drill the holes in the correct spot to run the roll cage through. You only get one chance so you have to get it right.
The bulk head fits nice and tight. Sealed it first with camper tape and then with a urethane sealant. The factory drain holes and seat bolt holes drain the bed quickly when it rains.
Inside view of cage going through the top.
GR8 Half Top Conversion Thread
Does your gas tank overflow at the pump?
SUBMIT FORMAL COMPLAINT HERE!
2005 Rubicon LJ Unlimited - 4 1/2" BDS Suspension - 285/75/16 Toyo M/T's - 12,000# Winch - Ground Pounder Fab Rear Bumper - FabRieckAtions Custom Front Bumper - Overkill Engineering Tube Fenders - GR8 Half Top - Rock Hard Cage - Banks Monster Exhaust - 5.13 Gears - High Performance Flux Capacitor
1976 CJ-7 - 33" Super Swampers - BDS 4" Suspension - 6 Point Roll Cage
Mud Machine is offline   Reply With Quote
Unread 04-23-2010, 10:18 PM   #2
AlTheKillerr
Looks awesome
AlTheKillerr is offline   Reply With Quote
Unread 04-23-2010, 11:04 PM   #3
Must-Be-A-Stang
Say it again...Nice rig. I like it a lot. If I didnt have to haul a 3yr old girl around everyday I'd think about doing this.
Must-Be-A-Stang is offline   Reply With Quote
Unread 04-24-2010, 01:49 AM   #4
Bama_WJ
Bama_WJ's Avatar
I've always loved those half tops. They look super nice.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel.
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- WJ JKS Shock Conversions
- OEM WK Springs
Bama_WJ is offline   Reply With Quote
Unread 04-24-2010, 04:46 AM   #5
Boundless
Boundless's Avatar
good job
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
http://www.canddautocenter.com/
Boundless is offline   Reply With Quote
Unread 04-24-2010, 07:50 AM   #6
ET48
Question though,
Since you have the cage running through the top like that, no bolt connection near the top (that I can see), you have to remove the rear part of the cage to pull the top now, correct?
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline   Reply With Quote
Unread 04-24-2010, 08:12 AM   #7
jeeptrash
Loving you LJ, Gr8 work
'06 LJ Rubicon 33's and stuff...
jeeptrash is offline   Reply With Quote
Unread 04-24-2010, 08:59 AM   #8
DirtyViking
1995 XJ Cherokee
Wow, that looks really great, and it looks like the construction on the cage and top is really solid.
DirtyViking is offline   Reply With Quote
Unread 04-24-2010, 12:05 PM   #9
Mud Machine
Jeep Addict
Originally Posted by ET48 View Post
Question though,
I have tube clamps near the top that you can't see in the pictures. Two bolts at the top and the two bolts at the tub and the bars come off. Then you can remove the top and reinstall the rear tubing and you can run topless. Takes about 15 minutes max.
Unread 04-24-2010, 06:58 PM   #10
ET48
Ooooo. Very nice!
ET48
Unread 04-25-2010, 09:45 AM   #11
Hillbilly Jeep
awsome..l love these half tops...good job
Hillbilly Jeep is offline   Reply With Quote
Unread 04-25-2010, 11:13 PM   #12
Doubledee90
That looks great, Im really jealous, if I had the money I would 100% do this. Great job!
3.25" Rough Country Lift
33x10.50 BFG KM2 Tires
Rockford Fosgate Subs and Amp
Midland CB
Dana 44 w/ Limited Slip Rear End
Doubledee90 is offline   Reply With Quote
Unread 04-26-2010, 04:37 PM   #13
thecalebwalker
Your Jeep is so awesome
I'm a big fan of red Jeeps with silver moabs if you can't tell
*Insert cool Jeep picture made out of text
[SIZE="5"][COLOR="Blue"]Selling an OEM TJ Front Bumper, OEM TJ Rear Bumper, OEM TJ suspension parts, Hidden Hitch, and/or side steps (not OEM). PM If interested![/COLOR][/SIZE]
thecalebwalker is offline   Reply With Quote
Unread 05-06-2010, 09:05 AM   #14
Mud Machine
Jeep Addict
Put a tonneau cover on yesterday....
Unread 05-06-2010, 12:03 PM   #15
woodkrawler
woodkrawler's Avatar
Put a tonneau cover on last yesterday....
Your Jeep looks really look with the half cab top! I always wanted to get an LJ and put a half cab top on it. Keep up the good work!!
Jeepless...
'06 Tundra DC TRD 4wd
'03 VW Jetta TDI - Commuter
woodkrawler is offline   Reply With Quote
