Goob's "Hell on Wheels" YJ Build - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Goob's "Hell on Wheels" YJ Build
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-07-2014, 01:12 PM   #61
The_Goob
Hell on Wheels
The_Goob's Avatar
Like the yj man, did i spy a zj back in that first vid on the first page? Good work so far, keep it up
Thanks!
There were a few, the videos were from a club run there were a few zj and wj?(the 2000ish ones) Oh how I miss wheelin
The_Goob is online now   Reply With Quote Quick reply to this message
Unread 01-09-2014, 06:32 PM   #62
The_Goob
Hell on Wheels
The_Goob's Avatar
Tore out the 231 today. Input seal is toast. Cleaning her up soon and then its SYE time.
Supposed to warm up this weekend so I might get back on the floor instead.
Sent from AutoGuide.com Free App
Unread 01-10-2014, 05:54 PM   #63
The_Goob
Hell on Wheels
The_Goob's Avatar
And today I brought home the 8.8! Starting to be a productive week for sure.
got the 231 cleaned up and ready to open, waiting on 1 part for that.
Unread 01-10-2014, 08:48 PM   #64
Gage56
Hells Yeah
1992 YJ
Gage56 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2014, 10:56 PM   #65
Sparrows
Originally Posted by Gage56 View Post
Hells Yeah
x2!
Cheers
[URL="http://www.jeepforum.com/forum/f22/warbird-2-a-2242713/"][size=3][b]WARBIRD 2[/size][/b][/URL]
[URL="www.exiledoffroad.com"][size=2][b]EXILED OFFROAD[/size][/b][/URL]
[size=2][b]June '13 YJOTM[/size][/b]
Sparrows is offline   Reply With Quote Quick reply to this message
Unread 01-10-2014, 11:18 PM   #66
Myusername1674
Nice man! I'm jealous
[SIZE="3"]95 FiveTwo ZJ, DD, Lifted, Locked on 35s, [URL="http://alturl.com/d6vk7"][B][COLOR="Blue"]Build[/COLOR][/B][/URL] (in progress)[/SIZE]
[URL="http://alturl.com/22263"][COLOR="Blue"]My 5.9 swap[/COLOR] (in progress)[/URL]
[URL="http://alturl.com/x4ryd"][COLOR="Blue"]Want your zj to be doorless in 60 seconds?[/COLOR][/URL]
Myusername1674 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2014, 01:53 PM   #67
The_Goob
Hell on Wheels
The_Goob's Avatar
x2!
Cheers
Hells Yeah
Thanks guys! Got all the perches and sway bar brackets cutoff this AM, most of the way ground down. got the rotors off for turning and tried to BFH the dust shields back to usable. going to pick up some more brake cleaner and cutting wheels, and a new $10 grinder from HF. And probably a 30 pack too
Putting this list here because im too lazy to use paper.
Stuff I need:
Driveshaft-tatton
front locker-probably Lokka, i like $198 shipped
rear trans seal-actually it looks good and not leaking so I will leave it alone
tc input seal, leaking badly
shackle bushings frame side
front brake pads
turn front and rear rotors
front hub to knuckle bolt, 1 is missing
rear brake calipers, pads (ebrake pads) all new lines needed
zj or xj pitman arm
Unread 01-12-2014, 02:05 PM   #68
The_Goob
Hell on Wheels
The_Goob's Avatar
Got primer on the floor. Still deciding if the seam sealer is all I will use, or if I should body fill the edge first . didn't turn out exactly how I had hoped but I'm done caring.
Unread 01-12-2014, 04:11 PM   #69
daddyjeep87
1987 YJ Wrangler
Looks just fine to me. I think you will be just fine with seam sealer. After all, I don't think you are building a show Jeep. You are building it to use it.
87YJ 5.2/46RH/NP231 D44/9in 4.56 4 link rear, radius arm front
My Build http://www.jeepforum.com/forum/f22/daddyjeep-121-day-87-yj-5-2-lcg-4-link-build-1479204/
Start planning for 2014, updated site http://www.bantamjeepfestival.com/
daddyjeep87 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2014, 04:26 PM   #70
The_Goob
Hell on Wheels
The_Goob's Avatar
I plan on monstalining it sometime this year, and im not sure how hard the seam sealer gets. The old stuff is hard but its 23 years old. just dont want it to end up too spongy is all.
I did throw the seat back in, oh it looks so good with a seat. been out since november something. Now if my damn part would show up I will finish the TC, button that in and start ripping axles out
Unread 01-14-2014, 12:42 PM   #71
The_Goob
Hell on Wheels
The_Goob's Avatar
Dropped off the 4 rotors to be turned, found out the 8.8 ones are too thin. Already have to buy calipers too and the core charge is more than the caliper.
Think I will be going junkyard surfing yet again because I dont have $241 to dump in the rear brakes
Unread 01-14-2014, 03:15 PM   #72
Myusername1674
That's a lot for brakes! Have you priced it on rock auto yet? Or just local auto.
Unread 01-14-2014, 03:36 PM   #73
The_Goob
Hell on Wheels
The_Goob's Avatar
that was O'rielly auto. They all have a core charge on the calipers, I don't have any old ones to give em, the 8.8 came w/o them. However my favorite local upull has them for $20 each. the pitman arm I need is $10. The rotors were $12 or something. Just a matter of finding some in decent shape. Love that they list all part prices online so I can see before I go. rock auto cheapest is $116 for all of it before shipping or brake pads ($20). I might get the rotors If unable to find decent used ones, since they are 16 vs 33 at the store.
Not trying to be a total cheap-*** but I have spent a ton already and have another ton to spend yet on other stuff Suppose I could just do my taxes
Unread 01-15-2014, 10:12 AM   #74
hig69
That looks great, it will certainly serve the purpose. Good work.
Steve
Father & Son YJ Frame Off Rebuild
http://www.jeepforum.com/forum/f22/father-son-88-yj-rebuild-1602609
hig69 is offline   Reply With Quote Quick reply to this message
Unread 01-15-2014, 10:36 AM   #75
skyj
Dont worry I dont think you could be a bigger cheap skate than Me and Ashland dont tell him I said that. I reused my brakes calipers and pads my 8.8 had good ones on it so I just turned the disks I got friends in high places and my father-in-law works at a stealership so just used their machine in after hours. there are cheap ways to do things just got to make friends with the right people.
Nice build by the way been watching for a while and decided to speak up.
build thread: http://www.jeepforum.com/forum/f22/skyj-eccentric-build-1467426/ '90 YJ 5.2 magnum MPI, AX15, NP231 SYE, Dana 30 4.56 open/ 8.8 4.56 detriot locker. 1" shackles
skyj is offline   Reply With Quote Quick reply to this message
build , islander , YJ
