Glockster's Rubihara Build - Page 36 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Glockster's Rubihara Build
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 10-26-2011, 05:58 PM   #526
glockster
glockster's Avatar
Originally Posted by Vinman View Post
I assume you needed a rear CV shaft for these mods to work together?
Vince
I did not need the TW shaft for the lift install but had the cash at the time so I bought it. Glad I did because when I added the SAVVY TT, I had nothing to worry about.
Marco
glockster is offline   Reply With Quote
Unread 10-26-2011, 05:59 PM   #527
glockster
glockster's Avatar
Originally Posted by jesse05LJ View Post
Looks like you need to offset your wheels.
Marco
Unread 10-27-2011, 09:21 AM   #528
jesse05LJ
nice! I caan't believe you got an LJ rubi for that cheep
jesse05LJ is offline   Reply With Quote
Unread 02-06-2012, 03:55 PM   #529
Necromancer_tat
Mall Crawler
Necromancer_tat's Avatar
Nice build!
When someone tries to tell you that nothing is impossible, ask them to dribble a football!
Originally Posted by misterpookie View Post
my best recommendation is keeping a dictionary in the restroom.
word to the wise: dictionary pages are generally thin and not quilted. :nono:
Originally Posted by 1999TJRED85000 View Post
Are you on crack?
I think you're a little off. The shell on a turtle is thicker by a factor of 1.6783 while compared to the speed of a Puma, when chasing a rabbit. Therefore, if you hit a nail with a 4 lb. hammer, the thickness of the wood needs to be 4, and your grip should be on your lower regions.
Project "Wrong Way" Jeep build ----> http://www.jeepforum.com/forum/f22/p...g-way-1293197/
Project "Bassakwards" Jeep build---->http://www.jeepforum.com/forum/f22/b...build-1483076/
Necromancer_tat is online now   Reply With Quote
Unread 02-06-2012, 10:03 PM   #530
glockster
glockster's Avatar
Thanks....we sure like it a lot. My wife, 27 yr old daughter and 23 year old son fight for the keys on the weekend but I usually win.
The week I spent with Blaine was incredibly enlightening and if anyone is offered that opportunity DO NOT pass on it.
We in So Cal are extremely fortunate.
Marco
Unread 04-17-2012, 07:25 PM   #531
SKT
1981 CJ7
I somehow missed this thread until now.
Very nice job with this clean rig!
Any new pics to share?
Click here to see thousands of 'Abandoned and Neglected' Jeeps rotting away...
SKT is offline   Reply With Quote
Unread 06-19-2012, 01:10 AM   #532
Laredo-Alex
Originally Posted by glockster View Post
A quick re-cap. Upper rear spring perches relocated and a custom trackbar mount fab'd up and installed. Cycle the suspension without and then with springs installed.
When everything is working as it should, carefully layout and then cut your frame relief notch for the shock tower. Blaine layed this out and made the cut without ever touching a tape measure. He started on the driver side (probably a good thing he did it before I got there) using a grinder and cut off disc. This picture was taken after he had tacked them on, checked everything, then removed them for final trimming of the brackets. He took 2 measurements from the drivers side to locate the passenger side. One for location on the frame (referenced from a factory hole) and a dimension for elevation above the frame.
Drivers side
Passenger side
Take note of how close the back of the shock mount comes to the track bar bracket. Unbelievably close. Not a lot of free real estate for the track bar mount. Here is one more shot from a different angle showing the amount of room Blaine had to work with. Remind yourself, he did this without a tape measure. Steel, a white soap stone pencil and a few trips back and forth from the garage.
Driver's side trimmed and tacked in place with shock installed. Check clearances from full droop to full stuff.
Then install the springs and check clearances again.
When both sides have been checked 2-3x,. final welding is next. You can see in the next picture just how close the trackbar mount and shock mount are to each other. They are back to back and welded to each other. Also visible is the signature Blainegroove, about half way up the inside of the bracket. Unable to weld the back of the bracket to the top of the frame, a groove is cut with a cutoff wheel that lines up with the top of the frame. A filler(?) weld is utilized that works perfectly for the task.
No more pictures for now. Blaine and I put some paint on the welds (well he did anyway, I painted half the tub )
I got a lesson on squaring the axles, setting pinion angles and installing control arms. That's about the time Gerald showed up and screwed everything up. Had to shift gears from suspension work to Vanco brake upgrades.
Gerald and I threw the rear tires on my Jeep and I torqued them down. That was sunday night and I had to go back to work on monday morning. When I left on sunday evening, Blaine was talking about wanting some more up travel for the front shocks and was staring very intently at a stock upper bumpstop cup and holding it up to the top of the upper shock mount. I pick up the jeep tomorrow and I'm very interested to see what he came up with.
Blaine completed the front suspension without me yesterday and today. Guess I'm just going to have to trust he knows what he's doing since I wasn't there to oversee him.
MrB & MrsC, thanks for sharing the better part of a week of your life to help transform my jeep into what it is now. I had a great time. Can't wait for that first drive tomorrow.
Hey marco, i need your help! Like you i´ve got a LJ Rubicon mit 6 Speed manual and bought the 4" Currie heavy duty springs. Okay, my back is a liitle bit heavy with rock crawler bumper, tire carrier and a extra tank on the end of the Jeep (90 KG). Because of the weight of the parts i decided to go to the 4" Currie HD Springs and kicked the old 3,5 RE with 1" spacer out. After the install of the new springs my back is still about 1,5" deeper than the front when i take now two passengers on the back seat as well, my Rubicon looks lika a baja race truck......front up and back down. You know what i mean?
So i startet to search in the forum to LJ Rubicons which have got the 4" HD coils from currie installed to find out if only my LJ has got a heavy back because of the parts. I´ve got 2 questions to your rig.
in the first pic (passenger side) you´ve mounted the spring with the progressive part on the top. in the 6th pic (driver side) the progressive part is upside down which one was mounted right and which is false? i did not get an install manual to my springs, so i mounted them the numbers/letters readable, the progressive part of the spring up to the frame. Maybe is there the problem that my LJ doesn´t sit in level??
Than you relocated your spring bucket in the rear, did you get a little lift because of this? Could you please take a photo from the back, each side, so that i can see what happens to your coil spring when the jeep is just standing on the road? At my rig the progressive part of the rear springs, the first two windings, is pressed together.
Maybe the relocation of the spring bucket is the easiest way to get mine back in level. I don´t want to add spacers ore something because if the gas tank is empty than the back is higher than the front.
Thanks for your help!
Proud member of the LJ-Family :) => 2005 LJ Rubicon - YES!
Laredo-Alex is offline   Reply With Quote
Unread 06-19-2012, 07:48 AM   #533
mrblaine
mrblaine's Avatar
I just finished dealing with this on a butt heavy rig. I also spaced the spring perches down 3/4" when I rotated them flat. No Marco's don't give any lift the way we did them.
It was still low in the back sitting empty and the only way I could fix it permanently was to remove the rear Currie springs and go to a set of RE 4.5" rear springs which then made it too high in the back, so I had to cut the spring perches loose and remove the lift I built into them and weld them back on.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 06-22-2012, 03:49 PM   #534
glockster
glockster's Avatar
Thanks for jumping in Blaine. I'm recovering from back surgery on Wednesday and I'm still a little loopy. Got some Magic Pills that are heavenly. Talk to yousoon about the hois.t
Guud nyght.
Marco
Unread 07-08-2012, 11:24 AM   #535
crateampscal
would you mind posting an interior pic of your shifter in 1st and 2nd gear with the Savvy Under Armor installed. im curious to where they sit after youve done all of this. Im interested in it but dont want be punching the dash when i put it in gear.
ps. good luck on the back surgery recovery. I slipped L4-S1 and had surgery. Recovery is key. dont push it and ease yourself into rehab. I could barely walk before surgery and now i can run and i was throwing around a 310 pound man like rag doll this week. its not perfect but im not complaining. im stronger than ive ever been. good luck
http://www.norcalfightingalliance.com/ - everything else is irrelevant!
crateampscal is offline   Reply With Quote
Unread 07-08-2012, 05:04 PM   #536
mrblaine
mrblaine's Avatar
It's bendable and you put it however you want it.
I am Savvy
Unread 07-09-2012, 12:37 AM   #537
glockster
glockster's Avatar
crateampscal, that's the short version but absolutely correct.
Let me elaborate. The body lift was installed at MrBlaines during the rest of the upgrades embedded earlier in this thread. He wrapped up working on my Jeep and when he went to test drive it, the shifter was not co-operating. He used his press to correct the alignment problem as the body was now 1.25" higher.
Fast forward 8 months later when I'm at the Savvy headquarters installing my TT with Gerald overseeing it. When I was done shoving everything up where it would be, the shifter once again was out of whack. Using Gerald's press this time, it was easily corrected. I'm pretty sure I just took the offset OUT that Blaine needed.
I'll try & get pix tomorrow of the dash/shifter relationship for you.
Marco
Unread 07-09-2012, 08:54 AM   #538
mrblaine
mrblaine's Avatar
I put a double bend in it. One to move it off the edge of the console which shoved the top into the dash, then another bend above the lower one to move the knob back away from the dash.
I am Savvy
Unread 07-14-2012, 11:46 AM   #539
crateampscal
Savvy under armor
wow it took two bends eh? Since i dont have a press, do you think i could heat it up and put the bends in it? how much did the savvy under armor push up the shifter? about 2-3 inches?
Unread 07-15-2012, 07:28 AM   #540
srfnfly227
I have an 06 LJ with the 6 speed also. If you are installing the UnderArmor all in one go (body lift, motor mount lift, UnderArmor) then your shifter should not need any bends. I installed the BL MML a few days before the UA and had a little problem with the lower gears, but could get it to work.
Marco, you still have one of my favorite Jeeps on this forum Great build and a good display of Blaine's talent and knowledge
Savvy/Currie 3" with Rancho RS9000XL shocks, Savvy UnderArmor, Currie Steering, 255/85R16 Toyo Open Country M/T, + other random goodies
My Build Thread
srfnfly227 is offline   Reply With Quote
