-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   The "Get Me By" MJ Truggy (http://www.jeepforum.com/forum/f22/get-me-mj-truggy-1450509/)
cgmrdc 12-15-2012 05:20 PM
So, a small introduction here, I started off in an XJ and then built a very capable, DD TJ while in school, click the link below for the build thread. Traded it with plans of building a buggy, but a year later and a big career move i still hadnt started the buggy build and was tired of not wheeling so i picked this up for 500 bucks.
Sample of previous work
My TJ
http://i189.photobucket.com/albums/z...7899233684.jpg
Friends TJ
http://i189.photobucket.com/albums/z...788F8000D8.jpg
Two other friend's XJs
http://i189.photobucket.com/albums/z...7893282BD7.jpg
And another XJ
http://i189.photobucket.com/albums/z...7896900B52.jpg
TJ Build
http://www.jeepforum...ge-fund-878243/
NEW BUILD
88 MJ
4Cyl, 5 speed, 2 wd
Basically everything I have collected for the buggy will be going into this build.
350 on propane, sm465, dana 300.
Currie Rock Jock 60, 5.38s, 35s spline inner and outer alloys, drive flanges, detroit. Full hydro
Shaved 14 bolt, 5.38s, detroit, disc brakes.
Currie antirock Rear Sway Bar
16 inch FOA coilovers
4 in FOA air bumps
39.5 TSLs
105-107 in WB
Dual Wilwood master cylinders and cutting brake.
Mastercraft seats
Warn HS9500 winch
4 links front and rear
The plan for the MJ is do 2x6 rocker/boat sides, internal cage, Rear in going to be cut off behind the cab and tubed out, Front grill is going to be narrowed, tube fenders and engine cage with the winch behind the grill and the radiator in the back. Interior is going to be stripped and have custom dash... Hopefully done by March.
cgmrdc 12-15-2012 05:22 PM
makin some progress
strippin stuff
http://i189.photobucket.com/albums/z...60F8930494.jpg
shed cleaned up again
http://i189.photobucket.com/albums/z...D82928443B.jpg
jeep rolled in with all major components removed
http://i189.photobucket.com/albums/z...D83146CEC8.jpg
http://i189.photobucket.com/albums/z...D835ECDCB4.jpg
http://i189.photobucket.com/albums/z...D83AB0DC52.jpg
literally zero droop...
http://i189.photobucket.com/albums/z...D83EE8EE10.jpg
no longer an issue...
http://i189.photobucket.com/albums/z...D842A61D26.jpg
sage is ready to go wheelin...
http://i189.photobucket.com/albums/z...D847AA731B.jpg
and just cant stop cutting!
http://i189.photobucket.com/albums/z...D8513A4472.jpg
http://i189.photobucket.com/albums/z...D8558DE205.jpg
http://i189.photobucket.com/albums/z...D85EC0A730.jpg
http://i189.photobucket.com/albums/z...D859BB0FDF.jpg
cgmrdc 12-15-2012 05:23 PM
frame prep
http://i189.photobucket.com/albums/z...90A8CD7F8E.jpg
http://i189.photobucket.com/albums/z...90AD6FED52.jpg
http://i189.photobucket.com/albums/z...90B6BFA152.jpg
a sharp wood chisel works really well to scrape the majority of the undercoating off, for future reference. then i used aircraft stripper to remove the rest of the paint and such
when i cut the inner fenders out i left the finch seem where it was spot welded to the frame, but im wanting to box the whole front frame section in sooo...
http://i189.photobucket.com/albums/z...90BAB666E6.jpg
http://i189.photobucket.com/albums/z...90BF595644.jpg
then folder it over with a hammer and welded it back together
http://i189.photobucket.com/albums/z...90C389C6C6.jpg
http://i189.photobucket.com/albums/z...90C905A42B.jpg
the last 12in or so were left unstripped and welded because one the motor goes in ill be cutting it off and tubing the rest to clear the 60
http://i189.photobucket.com/albums/z...90D4FDF70D.jpg
cgmrdc 12-15-2012 05:51 PM
Currie 60
http://i189.photobucket.com/albums/z...7AD0CF6809.jpg
14 Bolt
http://i189.photobucket.com/albums/z...7AC5565861.jpg
39.5s
http://i189.photobucket.com/albums/z...7ABDF7910E.jpg
FOA air bumps
http://i189.photobucket.com/albums/z...7ACB634ED7.jpg
Imped 12-15-2012 05:55 PM
Awesome, welcome back my dude.
cgmrdc 12-15-2012 06:09 PM
been too long...
kellerumps 12-15-2012 06:13 PM
Welcome Back.....
IEcrawlerTJ01 12-15-2012 07:00 PM
Mj's are sweet. The only other rig I would build besides a tj
I like your work. Lookin forward to this build :thumbsup:
cgmrdc 12-15-2012 07:09 PM
when i started thinking about putting the buggy on hold the only other thing i could think of that i would consider building was an MJ... im excited.
cgmrdc 12-16-2012 01:41 AM
finally feel like im making steps forward instead of just taking things apart
folded all the pinch seams and rewelded them
http://i189.photobucket.com/albums/z...B1983871F7.jpg
Cut off the "gussets"
http://i189.photobucket.com/albums/z...B19240CB65.jpg
started on the templates for the frame plates, doing 3/16 on bottom and inside, 12 ga on the outside
http://i189.photobucket.com/albums/z...B19CDEA2DF.jpg
got one section cut out and tacked up
http://i189.photobucket.com/albums/z...B1A5540593.jpg
http://i189.photobucket.com/albums/z...B1A94C7C0A.jpg
cgmrdc 12-17-2012 02:07 PM
Cut the rear frame off yesterday
http://i189.photobucket.com/albums/z...CA7A9FE2C1.jpg
http://i189.photobucket.com/albums/z...CA81B3144F.jpg
http://i189.photobucket.com/albums/z...d/IMG_0062.jpg
And before anyone throws a fit about this next picture, its only temporary, i can lift the jeep myself, the 4x4 is just a secondary support, its also safety chained to the ceiling rafters...
http://i189.photobucket.com/albums/z...CA85F6E1C3.jpg
http://i189.photobucket.com/albums/z...CA8AE6E827.jpg
i got the rest of the bottom plates cut out and the middle pieces tacked up
http://i189.photobucket.com/albums/z...CA908541E7.jpg
http://i189.photobucket.com/albums/z...CA955B1A37.jpg
http://i189.photobucket.com/albums/z...d/IMG_0066.jpg
Rockdrummer93 12-17-2012 03:23 PM
Will be keeping an eye on this one. :PopCorn:
TechJeeper 12-19-2012 11:18 PM
You don't have side business running a chop shop do you? You should definitely sling the axle and tires under there roughly placed so we can have good mental picture of this thing.
cgmrdc 12-19-2012 11:46 PM
lol, no chop shop, just skilled with a sawsall lol.
im picking up as set of 12 bolt h1s over christmas so when i get back to tx after the new year and finish the frame plates thatll be the first thing i do
ginger-mech 12-20-2012 05:07 AM
Subbed. Lookin' forward to reading more.
The time now is 11:54 PM.
