G's LJ Build (It's not the devil I swear) - Page 9 - JeepForum.com
 2Likes
post #121 of 473 Old 11-12-2013, 03:25 PM Thread Starter
g-rocc
growing a redsox beard and holding the head of a deer is a good look for you G
That frozen beard look is nice too...
g-rocc is offline
post #122 of 473 Old 11-12-2013, 03:29 PM
gspup
The frozen beard is great !!! haha
Originally Posted by dayriesw View Post
Nice to see someone who isnt scared of mud too.
I'm not scared of mud...
Here's mine after hunting...there is still mud falling off.
gspup is offline
post #123 of 473 Old 11-12-2013, 03:31 PM
AngryTJ
good thing you put those inners on huh
AngryTJ is offline
post #124 of 473 Old 11-12-2013, 04:35 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Who needs those???
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #125 of 473 Old 11-12-2013, 04:40 PM
LeeMasterGT
Real nice lookin deer! Looks pretty full bodied in that photo. Got an estimate on his weight?
Build
LeeMasterGT is offline
post #126 of 473 Old 11-12-2013, 04:59 PM Thread Starter
g-rocc
Gutted the camp consensus was around 200 lbs. I'm doing all of the processing for the first time so no butcher to actually weigh him. He had a really big neck in comparison to other deer I've seen.
g-rocc is offline
post #127 of 473 Old 11-12-2013, 05:13 PM
LeeMasterGT
That's awesome. Very nice harvest!
Build
post #128 of 473 Old 11-14-2013, 01:54 PM
gspup
It was a very good thing I put them on.
G's wifey busted his new steering set-up mall crawling the other day
So we crawled under the LJ last night, sleeved the lines with kevlar wrap and re-routed others to keep them from rubbing through again. I'd figure I'd update this build because there isn't much happening in my thread.
gspup is offline
post #129 of 473 Old 11-15-2013, 08:11 PM Thread Starter
g-rocc
It was a very good thing I put them on. G's wifey busted his new steering set-up mall crawling the other day So we crawled under the LJ last night, sleeved the lines with kevlar wrap and re-routed others to keep them from rubbing through again. I'd figure I'd update this build because there isn't much happening in my thread.
You have done enough work on it, update away.
Also, drove to work today and went to get a car wash and the manager cane out and denied me a car wash. A car wash denying me a car wash? Are you serious?
No leaks too.
g-rocc is offline
post #130 of 473 Old 11-16-2013, 06:37 AM
AngryTJ
You have done enough work on it, update away. Also, drove to work today and went to get a car wash and the manager cane out and denied me a car wash. A car wash denying me a car wash? Are you serious? No leaks too.
Why were you rejected?
AngryTJ is offline
post #131 of 473 Old 11-16-2013, 07:46 AM Thread Starter
g-rocc
Too dirty. That's like a bar tender telling me I'm too sober for a drink.
g-rocc is offline
post #132 of 473 Old 12-05-2013, 08:46 PM Thread Starter
g-rocc
Cage Ideas
Went to work on some cage design today with a buddy. Take a gander at some of the screen shots. It's not complete but it is a good start. Some questions that you guys might be able to help me answer.
1. For the rear seat belt, do the mounts on the cage need to be in the exact same place as stock or can they be be moved some? I would like to bring the C Pillar on a slightly steeper angle if we can move those rear seat belt mounts.
2. Does anyone have the bends and distances laid out for the A-Pillar? That's pretty hard to estimate w/o tearing it all apart.
Note it's not finished but please feel free to comment and provide me any feedback you can.
g-rocc is offline
post #133 of 473 Old 12-05-2013, 09:06 PM
MO2500
There is no need for the bends in the A-pillar dash tubes. You can get straight tube down through the dash to the floor and it will be stronger. I would do something like Poly Performance and build a 2 piece A-pillar with a sleeve in the windshield area so you can rotate it into position before final welding. When I did Lu's cage it made it very easy to line up the A-pillars and door surrounds.
I will see if I still have the bend program for the A-pillars on my last cage. If i am remembering correctly the proper angle at the top is like 58* and so the bend at the dash would be like 32*. Those numbers sticks in my head for some reason but I'll see if I still have those dimensions saved.
Also, the windshield overhead bar, is there a reason it bends right before it welds to the A-pillar? If possible, I would run a straight bar and then bring the overhead diagonal right into the same joint between the windshield overhead bar and the A-pillar bend. That or if you want to keep your design like that at least add in a gusset between the bend in the windshield top bar and the bend in the top of the A-pillar.
Lastly, I would move that short little piece of tube supporting the bent diagonal brace in the C-pillar window area up to the actual bend in that tube so that it supports the bend. I assume you are trying to keep that area open for back seat access? otherwise I would just make that bent piece straight into the node on the B-pillar.
Instagram: @omsmike
MO2500 is offline
post #134 of 473 Old 12-05-2013, 09:15 PM
MO2500
My suggestions to make it a little stronger but still keep the interior free of tubes.
Instagram: @omsmike
MO2500 is offline
post #135 of 473 Old 12-05-2013, 09:18 PM
MO2500
Using a top that windshield top bar can't be as far forward as I drew it. Just thought about that since you will need to be able to swing the latches on the top and clear the bar.
Instagram: @omsmike
MO2500 is offline
colorado , lj , rokmen , set them free , spyder9
