Free wife to good home! Pics included.
#16 | |
So what are you gonna do with that cute little spare?
33s with the 3 speed and 3.73s is just about perfect.
'02 TJ X Apex Edition '00 XJ Sport |
#17 |
That looks really good.
04TJ 3.5 RE Extreme Duty Long Arm, ARB F&R, 4:88's, Cromo shafts, 35 MTRS, Rokmen Armor. TJ's gone. See you on the trail in my Toyota :). |
#18 |
100% improvement. You could take 1/2 inch off the rear spacers to level it out. That's what I did when I had my 2.25" BB on.
#19 |
Trust me....
I am proud of you for asking.
I thought all the pervs were in GD getting a lecture about their junk being nipped. ![]() However, here's the closest you're gonna get to my wife's meaty rack! ![]()
Patriot Blue 2001 TJ Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires. My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/ |
#20 |
Hey, Buddy, you posted wrong pics. Please post the correct pic, so we can post up some replies.
2009 JK Rubicon. Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip. Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009. Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008. http://community.webshots.com/user/thunder1strike |
#21 |
That is very nice man. I've got the same tranny but with 4.11's, and it definitely looks like it'll run better with 33's than my current tires. So were you getting a solid 16mpg before the tires and lift?
1999 White TJ Sport:
3'' lift, JK 32" BFG KM's on 17" JK Moabs, Auto, 4.11's, 2 pairs of Hella 500's, Cobra CB w/ PA, Warn m6000, Flowmaster 40, SpyderWeb ShadeTop, Viking Fastback Top {My Jeep on flickr} {Build Thread} {Viking Fastback Top Review} |
#22 | |
Trust me....
Today, there was no AC, ran at 70 mph and got 14.8 mpg.
Patriot Blue 2001 TJ Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires. My build threadhttp://www.jeepforum.com/forum/showthread.php?t=528892 |
#23 |
Trust me....
Everyone, thanks for all the accolades and questions. I am getting a bunch of questions (PMs) for more info and pics. Pics will come tomorrow, in this thread. Here is some more info about the build.
To properly fit 33's you need 3-4" lift. A Rubicon Express BB and the ever-popular Performance Accessories BL combo only yields 2.75". Just not enough. The 2.25" BB and JKS 1.25" BL yields 3.5". Sometimes, a BB will cause driveline vibes. A MML solves this. Anyway, a BL and MML go well together. Doing the BL alone would have necessitated modifying the fan shroud due to the AC lines, AND I would probably have to drop the TC to correct vibes. Ergo, the BL/MML combo was a no brainer. All BB's cause the rear axle to shift. The RE trackbar bracket is an easy fix and a lot cheaper than an adjustable trackbar. 2.25" BB w/skyjacker hydros - $225, 4 wheel customs Rear track bar bracket - RE $70, 4 wheel customs 1.25" BL and 1" BMML from JKS - Redrock 4x4, $178 free shipping 33x10.5x15 BFG MT, 4 DELIVERED for $667 from www.tirepackage.com. I will add extended discos sometime in the future. Probably JKS Quicker Discos. Today, the stock ones are on. The shocks are HYDROS....softer than stockers...but tend to rust from road salt, so I painted them black before the install. Just be sure to sand them before painting, or the spray paint won't stick. Useful links: BB install http://www.4x4xplor.com/REBB.html Trackbar relo install http://www.rubiconexpress.com/Img/Pr...ructions/0.pdf Steering stop adjustment http://www.4x4xplor.com/steerstop.html Front end alignment http://www.4x4xplor.com/alignment.html PICS will be in my thread, look late tomorrow.
#24 |
I have a 2" BB (the spacers are 2"), waiting to go in, along with the JKS BL and MML. I was going to go with 32's, but after seeing yours, you've caused me to start debating again.
2004 TJ Rubicon........My build thread, My URE Vid www.vanc4x4.net All Who Drive Jeeps Are Not Jeepers - Willy 3:16 |
#25 |
Exact same route I'm going, only I have the PA 1" BL. Looks Great. Looking foreward to more pics!!!
#26 |
Will I just wasted a few minutes of my life. Nice Jeep. Now I want to see the FREE WIFE!!!
'97 TJ Sport, 4.0 5 speed, Jeeperman Rock Skidz, JKS Quicker Disconnects, 2 inch BDS lift kit, Branik Motorsports Aluminum Control Arms, 32X11.5 BFG ATS, 15x10 Eagle Alloy Wheels, Detroit True Tracs with 4.56 Gears .. both axles, Best Top High Rock Rear Bumper I also own a lifited Golf Cart: www.buggiesgonewild.com |
#27 |
Looks nice. Tell the wife she can spend the Federal economy boost check in May, then your even and her most recent memory is her spending money. Take her for a ride and get her to buy into wheeling as a family.
How was the bl and mml to install? Did you have to do anything with the shifting linkage being that it is an auto trans?
Also have a '06 Rubi LJ, Auto |
#28 | |
Trust me....
![]() BL was a breeze. MML sucked bad. No problem with the linkage, no adapter needed.
#29 |
The next thing you want to do is save for another 33x10.5x15 BFG MT for your spare! Think of it as a parachute...you would rather have it and not need it, than need it and not have it!
Cheers! M2 |
#30 |
It doesn't have to be another BFG MT. Just as long as it's the right diameter (and remember not every manufacturer and model has the same idea of what 33" is). I bet you could use a 33x9.5 BFG AT to cut down on the weight on your stock carrier..
02 TJ Sahara, 2.25"BB + 1.25" BL, 32" Maxxis Bighorns |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
