Frankenstein Street Queen - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Frankenstein Street Queen
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-13-2015, 02:54 AM   #1
ckruzer
Jeremiah 33:3
ckruzer's Avatar
1987 YJ Wrangler
Ok. Plan is to take the best of CJ, YJ, and JK and put them all together with a GM drivetrain. This is Street Queen Jeep build. Meaning, it will be tough enough to handle any off road adventure, however it will not be scraped over rocks. Will keep most recent photo here. Locating frame to begin welds asap. Budget is $15k. Donor YJ already found.
This will be a Church build for use with Youth outreach.
Anyone who wants to contribute to the recipe, I will gladly consider their input.
1987 YJ, Toy & Hobby. Tinker Thread
1987 Frankenstein Street Queen. Build Thread
Phillipians 3:20 - "For our citizenship is in Heaven..."
My President is Jesus
ckruzer is offline   Reply With Quote Quick reply to this message
Unread 05-13-2015, 02:45 PM   #2
partegolkar
Good plan, Good luck guys!
partegolkar is offline   Reply With Quote Quick reply to this message
Unread 05-13-2015, 04:04 PM   #3
ckruzer
Jeremiah 33:3
ckruzer's Avatar
1987 YJ Wrangler
Thanks. Here is the recipe so far. Will keep this edited if plans change. Feel free to suggest brands.
Frame: Front tube shock mounts. Rear no pocket shock mounts. 350 MM with Browndog MML. Drill/tap rails for c-clamps. Custom transmission crossmember, w/ torque bar for tcase. Custom rear cross member for fuel cell, with custom skid plate. External fuel pump, with internal sending unit. Fuel relay tied into OPT. Cage frame tie-in's.
Drivetrain: Chevy 350 sbc roller tbi. Lakewood BH. LUK clutch. SM465 with snapring upgrade. NP205 married. Tom woods DS (f/r).
Axles/Suspension: f250 44 front, 60 resr with RSE Bombshell kit on 44. SOA. High Steer Kit. RCV CV Front Axles. Front Detroit E-Locker. Rear Detroit Locker. Warn Hubs. Rear Disc Conversion. 4.88 Gears. 35x10.5 Tires, Black Wheels. 2" RE Lift.
Steering: Durango Box. HF Pump. GM Tilt Column reinforced. Borgeson Shaft. NRG Quick Release and Wheel.
Interior: Corbeau Moab Seats. Safari Rear. Monstaliner tub. Sport roll bar, w/ family 90's, and KOZ cage. Boat heater. DD Flat Dash w/ Phantom Guages. OTRATTW Rocker switches. CB and HD Radio. Amp on firewall. Sub/Box inside rear seat cushion. 4 point harness. Ford Nav Mirror. Tailgate security.
Exterior: Zinc prime. Por15 underbody/firewall. Gas fill relocate, tj. CJ tailgate swap w/ custom exterior latch. custom TJ grill to YJ grill mix. JK HUD lights w/ inverted bezel. CJ LED taillight conversion. Metalcloack fenders and rocker and corner armor.
Accessories: Dual Battery. Air compressor. Water sump pump. Air horn. Light Bar, bumper, reverse, crawl, and internal lights.
Unread 05-14-2015, 08:46 AM   #4
HaskiE
HaskiE's Avatar
in for the sub
#theneverendingaxe
HaskiE is offline   Reply With Quote Quick reply to this message
Unread 05-14-2015, 10:29 AM   #5
doublins
doublins's Avatar
Subbed- I love builds like these.
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
http://www.jeepforum.com/forum/f22/m...rings-1516649/
doublins is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 03:49 PM   #6
TexNVa
I'm excited to see the build. More excited to see how you use it
Pretty awesome to see a jeep being built for the Kingdom.
TexNVa is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 05:07 PM   #7
ckruzer
Jeremiah 33:3
ckruzer's Avatar
1987 YJ Wrangler
Originally Posted by TexNVa
I'm excited to see the build. More excited to see how you use it Pretty awesome to see a jeep being built for the Kingdom.
Best reason to do it!
Unread 05-16-2015, 08:38 PM   #8
TexNVa
No doubt my friend. Kind of switch off between reading on this site and another. At least i'll have some motivation to come back and keep reading
Unread 05-22-2015, 03:41 AM   #9
ckruzer
Jeremiah 33:3
ckruzer's Avatar
1987 YJ Wrangler
Got the frame. Need to get it up on the saw horses to get it sanded down and ready for welding fun
11287230_1485772018330910_1404050434_n.jpg   11304130_1485772078330904_1981781835_n.jpg   11297916_1485772141664231_807068158_n.jpg   11354889_1485772181664227_1779846069_n.jpg   11304119_1485773974997381_1366476103_n.jpg
Unread 05-26-2015, 02:52 AM   #10
ckruzer
Jeremiah 33:3
ckruzer's Avatar
1987 YJ Wrangler
Picked up a 14b to have on hand in case convinced to use it with a d60
