Frame up daily driver/ Weekend warrior - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Frame up daily driver/ Weekend warrior
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Looking to re-gear?! CRAZY DEALS ON YUKON GEARS right here
Unread 02-11-2014, 01:03 PM   #1
nacheswheelin
1960 CJ5
A couple years ago I bought a beat up buthchered cj5. I ripped the axles off of that jeep put some dana 44s off of a waggy on it stuffed them with yukon gears and detroits and ran the 225 t90 and dana 18 through some of the nastiest trails around my area. One day going through a couple feet of snow I slid into a tree and trying to get out I may or may not have (probably did) mess up the engine pretty good. At first it seemed like i needed to tighten the lifters, I did and it still ran horrible. Instead of rebuilding the oddfire I am going fuel injected with a chevy goodwrench 350 and a tbi unit. Behind that will be a T18 ford tranny mated to an np 208. To fit this combo in I will add about six inches to the rear of the jeep when I build my frame. This will not be noticable becuase my tire carrier will sit over the top of the extended frame/step bumper. The body will get new tube fenders on the front and a comp cut corner replacement in the rear. I am going to run hp dana 44 front and a 31 spline 9 inch rear with 4.10 gears in each (4.09 and 4.11s). Each axle will get an arb locker, I would use ox lockers but the 9 inch only takes arbs or detroits and I dont want to skimp on 400 dollars for the rear when I could have a selectable in both and a way to air up my tires. I have heard that the 9 inch arbs are not as strong as other arbs but I will never really run bigger than true 36 inch tires so I am assuming that the arb will manage to hold up just fine. I will make this thread as pic heavy as possible and all comments are welcome.
Who ever said less is more never owned a jeep.
nacheswheelin is offline   Reply With Quote
Unread 02-15-2014, 08:11 PM   #2
nacheswheelin
1960 CJ5
Started building my frame using this template
Unread 02-15-2014, 10:04 PM   #3
nacheswheelin
1960 CJ5
Starting on the frame
Unread 02-15-2014, 10:08 PM   #4
nacheswheelin
1960 CJ5
Nothing like cutting some 4x2 .188 wall with a metal chop saw
20140215_170643.jpg   20140215_160911.jpg   20140215_160902.jpg   20140215_155119.jpg
Unread 02-15-2014, 10:09 PM   #5
nacheswheelin
1960 CJ5
I used the .188 wall for the center section of my frame and the .120 for the outer four pieces
Unread 02-15-2014, 10:14 PM   #6
nacheswheelin
1960 CJ5
Few more
Unread 02-15-2014, 10:23 PM   #7
nacheswheelin
1960 CJ5
This is where I had stopped for the night. I added 2 1/2" to the front frame rails so my winch will fit better and not sit directly against the grill. The rear rails are 10" longer than stock, but I plan on cutting a little off once I mock up everything and figure out exactly how much I will extend them.
Unread 02-15-2014, 10:32 PM   #8
nacheswheelin
1960 CJ5
This Is what I am going for except ill stay Sua becuase I really do not want to be that tall.
Unread 02-16-2014, 10:22 AM   #9
lovett86
nice project
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline   Reply With Quote
Unread 02-16-2014, 06:42 PM   #10
daddyjeep87
1987 YJ Wrangler
Sounds like a cool project. I'll be watching.
87YJ 5.2/46RH/NP231 D44/9in 4.56 4 link rear, radius arm front
My Build http://www.jeepforum.com/forum/f22/daddyjeep-121-day-87-yj-5-2-lcg-4-link-build-1479204/
Start planning for 2014, updated site http://www.bantamjeepfestival.com/
daddyjeep87 is offline   Reply With Quote
Unread 02-16-2014, 08:22 PM   #11
nacheswheelin
1960 CJ5
Originally Posted by lovett86 View Post
nice project
Thanks guys!
Unread 02-16-2014, 08:38 PM   #12
nacheswheelin
1960 CJ5
Here is a couple pictures of my welds (im not a professional but they should hold up fine) and the frames side rails almost finished I will still need to put some gussetts on.
20140216_164604.jpg   20140216_164622.jpg   20140216_173743.jpg   20140216_170531.jpg   20140216_164139.jpg
Unread 02-17-2014, 07:00 PM   #13
nacheswheelin
1960 CJ5
Just ordered tube fenders with no flare for 200 shipped from ccfabs
Unread 02-26-2014, 11:12 PM   #14
nacheswheelin
1960 CJ5
Building the new rear quarter panel
20140222_143215.jpg   20140226_122723.jpg   20140226_124349.jpg   20140226_133359.jpg   20140226_133403.jpg
Unread 02-26-2014, 11:18 PM   #15
nacheswheelin
1960 CJ5
Comp cut the rear
20140226_141207.jpg   20140226_141626.jpg   20140226_141647.jpg   20140226_141911.jpg   20140226_145254.jpg
