Frame Swapin Time - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Frame Swapin Time
Time To Save On Yukon Lockers!Rough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 12-22-2015, 03:01 PM   #1
jbryant
Frame Swapin Time
This is the reason for the alarm. I can’t believe he drove this thing.
Project is: Red 2001 Sport, 6 cylinder, 5 speed in a bad need for a frame swap. This gem already has a 4 inch Pro Comp lift sitting on 35 inch tires.
The Main To Do’s:
Frame Swap.
Front Fender replacement.
Motor mount lift.
Transfer case drop removal.
Other items to do:
Replace all the other Rusty crap.
2000 TJ 5.9/46re, Zone 4.25, 35" Goodyear MTR's w/Kevlar
jbryant is offline   Reply With Quote Quick reply to this message
Unread 12-22-2015, 03:07 PM   #2
jbryant
After further investigation and removal of the flaky rust debris, this is the hole left.
Unread 12-22-2015, 03:08 PM   #3
jbryant
Pyle if said rust crap.
Unread 12-22-2015, 03:13 PM   #4
jbryant
New frame sourced. The new frame is a 4 cylinder and some modifications will need to be made to drop the 6 cylinder 5 speed in, but it was local and cheap. Frame was purchased completely stripped, the transfer case skid plate was thrown back in on the deal.
Unread 12-22-2015, 03:19 PM   #5
jbryant
Front sheet metal removed.
Unread 12-22-2015, 03:20 PM   #6
jbryant
Holy oil pan batman!
Unread 12-31-2015, 11:51 AM   #7
jbryant
Trying to separate the body. I've successfully lifted it a couple inches, but it feels a little squirrelly doing it by myself. Hopefully I can get some help in the next few days.
Unread 01-01-2016, 07:52 AM   #8
TJ-Bville
In advance thanks for doing a write up, good luck.
Most LCOG Builds are like a fat girl in Yoga Pants, just cause it fits doesn't mean it works...
TJ-Bville is offline   Reply With Quote Quick reply to this message
Unread 01-02-2016, 12:42 PM   #9
jbryant
We have separation today!
Unread 01-02-2016, 02:37 PM   #10
jbryant
I had a little left in my day so I was able to get the rear axle out. My plan is to make the new frame into a roller before pulling the motor out of the old frame. I don't really know how it's going to work out with the off balance of weight.
Unread 01-02-2016, 05:23 PM   #11
TJ-Bville
How difficult was it separating the wiring etc from tub/frame?
Unread 01-03-2016, 03:26 PM   #12
jbryant
The wiring is not overly difficult. Just check recheck and check some more for anything connected to the tub. So far none of this project is overly difficult. I don't suspect many obstacles until moving the motor mounts from the 4 cylinder position to the 6 cylinder position.
Unread 01-03-2016, 04:10 PM   #13
wijeepguy716
I wish I could find a rolling chassis like you are swapping too, my frame is patched for the winter but I need another. I'll be watching...
wijeepguy716 is offline   Reply With Quote Quick reply to this message
Unread 01-04-2016, 09:38 PM   #14
jbryant
I got the old rear axle into the new frame tonight. I think I've decided to pull the motor/trans/transfer case before removing the front axle. I initially didn't want to do it that way for not having the space in the shop for everything, but I do believe this will be the easiest way in the long run.
Unread 01-05-2016, 06:18 PM   #15
TJ-Bville
I was thinking of pulling motor/trans/TC as one piece?
