Quantcast flatlander757's 03 TJ build/update thread - Page 51 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > flatlander757's 03 TJ build/update thread
Old 10-30-2009, 01:29 PM   #751
AngusTJ
Originally Posted by spyder6 View Post
did somebody say elliptical?
Ghey
"Run what ya brung and hope ya done brung enough"
Originally Posted by pjleslie03 View Post
I know how bad the D35 is in the rear, but would it be bad to have one in the front?
Originally Posted by Lostj View Post
yes, you wouldn't be able to steer
98' TJ, 4" Superlift, JKS 1.25" BL/ 1" MML, 8k Gorilla winch, Cowl intake, D30 Aussie, shafts/D44 Powertraxx, shafts (4.56's), Rusty's Adj CA's front/ RE Adj CA's rear, Recessed tails, sway discnct'd, 152 db train horns, 34x10.5 LTB's Amer Rac/36x13.5 Irok's Streetlocks, Grenade shifter, Pioneer deck/speakers, Warn bumpers, KC upper lite mts/Slim lites, EBC yellows, 40 series Flowmaster, couple tasteful more ...
AngusTJ is offline   Reply With Quote
Old 10-30-2009, 02:20 PM   #752
flatlander757
Now in the 937
flatlander757's Avatar
Originally Posted by AngusTJ View Post
Ghey
Yeah... that would be Spyder
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Old 10-30-2009, 03:44 PM   #753
wolfen
Just out of curiosity did that bearing come egged out like that or did teh rear end do it? I worked on aircraft in eth Navy long enough to se ea definite problem with that bearing
gone somewhere else
wolfen is offline   Reply With Quote
Old 10-30-2009, 07:19 PM   #754
flatlander757
Now in the 937
That's the old bearing... somebody told me it could have been caused by the rear diff dropping off a ledge and landing on the pinion, sideloading the outter pinion bearing.
Anyways I got the new one and unfortunately I need some shims to add as it is too tight still(but smoother now).
I need shims that are 1.25" ID, 1.625" OD, as many as possible in varying thicknesses so if anyone knows where I can get those that would be awesome.
Build thread here.
Old 10-30-2009, 07:47 PM   #755
spyder6
Just violated my Parole
spyder6's Avatar
id call Motive Gear
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 10-30-2009, 07:58 PM   #756
flatlander757
Now in the 937
Found a place called East Coast Gear Supply(Drivetrain Specialists East Coast Gear Supply) and called them up... Chase there is sending out a shim set to me on Monday for $12 or so
It's coming from NC so hopefully I'll have them before Thursday so I can make the Jeep right before I go to Disney World
Build thread here.
Old 10-30-2009, 09:08 PM   #757
wolfen
I was gonna say them, Thats where I got the shims for the old Dodge pickup I had
gone somewhere else
Old 10-30-2009, 09:11 PM   #758
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
You do need links for a eliptic rear.
There's several guys I wheel with that have them in the rear. Some with leaf's up front or air shocks up front. The are on YJ's and CJ's though, a little of the classic look with a more modern touch.
If you saw a recent (mid to later summer) JP magazine, the Kentucky Longrifle guy and the white TJ in that same month, both of them are in my club.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 10-31-2009, 01:36 PM   #759
TJamz
TJamz's Avatar
So that's how you created a monster! Excellent writup. you got the skills man. Subscribed!
TJamz is offline   Reply With Quote
Old 10-31-2009, 02:03 PM   #760
spyder6
spyder6's Avatar
we do all of our drivetrain shopping with ECGS. chase is a good guy and will work with you on prices
USAF
Blue Crush Build
Really?
Old 10-31-2009, 03:17 PM   #761
redbob2323
guess what i did for halloween. i just spent the last several hours reading this, i CAN NOT wait to see this thing wheeling
98 jeep wrangler 4.0 6cyl green, tan soft top
4" RC X-series w/ 33" dunlop MT on 15" steelies
jks disconnects, cassidys custom f/r bumper, rockers
AA SYE w/ tom woods drive shaft, CB/PA
2 10" subs in stealth box, flush rear lights, light bar w/ 4 130w, 2 55w lights
future plans tube flares, rhino line, skids, lockers, D44
redbob2323 is offline   Reply With Quote
Old 11-01-2009, 05:31 PM   #762
LuckRider
LuckRider's Avatar
Anything new on the Jeep front flatlander?
Do you have anything planned for the Jeep before Disney other than fixing the rearend?
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Old 11-01-2009, 05:52 PM   #763
flatlander757
Now in the 937
Haha thanks, I can't wait to wheel it!
Probably not, need to clean up the garage badly, I'm hoping to get the shims I need before Wednesday.
As soon as I get back I think I'm going to get cracking on building a front driveshaft. I think I may measure and cut up my stock TJ front shaft for a longer slip and need to get a 1310 to 1350 conversion joint for the front axle. It's still 1310 at the t-case so I'll probably just remove the CV assembly from the front shaft and attach a plain 1310 u-joint.
Hell if I really want to get ghetto I may just cut the shaft up and do a square driveshaft like I was originally thinking.
Build thread here.
Old 11-01-2009, 09:01 PM   #764
TJamz
TJamz's Avatar
This should be made a sticky. Can't wait to see this thing offroad. Have you named it yet?
Old 11-01-2009, 09:31 PM   #765
flatlander757
Now in the 937
Haha on Pirate 4x4 it's named "Project Get That Heep Done Before the Wedding!" but it didn't exactly live up to it's name
The joke name that it had for a while was "Jeeperdoodles" but I never called it that seriously.
Some time when I get around to it I want to get a custom plate since they're so cheap in Virginia, BGFNJP is available, so is 1TONTJ. We'll see.
Build thread here.
Glock Forum
