#196 | |
thats a nice jacket to be grinding in. lol, nice build
99 XJ Sport - 3" lift, 31 BFG At's -DD 94 XJ Sport - 5" Lift, Locked on Swampers and beaten I Just dropped in to see what condition my condition was in... |
#197 |
What are your plans for the evap. cannister and the gas tank?
#198 | ||||
Now in the 937
Thanks! Quote:
Yeah, it was really cold that night. Virginia Beach area has some weird weather, it was like 40 degrees one day last week, and like 70 a couple days later. The plan is to put the gas tank in the back seat area with some brackets that will bolt down where the rear seat brackets would go. I got my tires today Unfortunately I've been feeling sick as hell this morning, stayed home and threw up a lot. Didn't get much of anything done, just picked up some EFI fuel hose, fuel hose safe hose-clamps, and some snazzy connectors that plug into the stock hard fuel lines on the frame to extend everything into the cab.I'll get some pictures tomorrow at some point. I'll be picking up a semi-completed bumper from BESRK for my build. I was going to do it all myself, but the fact of the matter is that I have no means of cleanly/accurately cutting holes for a reciever hitch or d-ring tabs. I'm getting Eddie to cut holes and weld in the reciever hitch and d-ring tabs, I'll be doing the bumper mounts, the leaf-spring shackles, and capping it myself.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#199 | |
Now in the 937
Tires:
![]() ![]() Balancing patch on one of them: ![]() Funny story about that, I thought it was an incomplete molding or something and ripped a small section off. Luckily I couldn't get much, I posted it on Pirate and found out quickly it's not to be removed. Take note of this if you ever plan on big big tires. Brackets for the fuel tank in the back seat area: ![]() Mounted and giant mess in the back: ![]() I started it up with the exhaust cut off by the oilpan, sounded loud ![]() Still have to hook up the emissions crap. I'm struggling with figuring out how to run the electrical connectors through the tub for the LDP or NVLD or whatever the hell it is back there. Going to pick up a rear bumper from Eddie today, I'm having him just cut holes/weld in the reciever hitch and D-ring tabs as I have no way to make straight cuts through front and rear. I've got a bumper mounting kit from Rokmen that I'll be using and the shackle mounts for the leaf springs to weld on myself.
#200 |
GROUND POUNDER
Whew!! Just read all 14 pages!! Good stuff!
One thing.. you should have just brought those axles up to the shop.. we could've plasma'd those brackets off in about oh.. 15 minutes!! ![]()
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#201 |
Just violated my Parole
psh, plasma cutters are for wimps
#202 | ||
Now in the 937
![]() Thanks again for spoiling me with your plasma cutter and 220v welder today Now I've gotta put those towards the top of my "Wish List" once I've got a house.Think what you want, I'll take a decent plasma over a cut-off wheel any day now that I've used one. ![]()
#203 |
very nice! everything is a little blurry after 14 pages
#204 | |
Now in the 937
Here's some pics of what went on today, painted everything for the tank mounting, figured out what to do for the emissions crap, and not pictured I started mocking up my rear bumper, didn't weld anything yet, I have just a little bit more 0.030 wire to burn off so I've been (attempting) teaching Shaynea how to weld with that last bit before I start using the 0.035 wire for the rest of the stuff.
![]() ![]() ![]() ![]() If you are familiar with the evap system, you'll notice that I changed the order in which stuff goes. It's supposed to go to the charcoal canister > NVLD > filter breather. I changed it to NVLD > charcoal canister > filter breather. I've read about people removing the canister portion entirely and only keeping the NVLD without problems, I want to keep the charcoal canister to keep from smelling gas fumes constantly. I just need to extend the wire harness to the NVLD. ![]() ![]() ![]() ![]() ...
#205 | |
Now in the 937
More evap goodies:
![]() ![]() ![]() If you look in the first 2 pics, I used one of the existing self-tapping screws that originally held the NVLD to it's bracket, to actually hold it to the mounting hole for the stock gas tank skid. I used some washers so it didn't pull through obviously but it is sturdy enough for what it is. And the ever fabulous tie-down strap holding the charcoal canister down For the time being it works so I'll let it eat.![]() ![]() ![]()
#206 | |
Now in the 937
Here's a sneak peek at the rear bumper I started welding mounts to today
#207 | |
Now in the 937
The rear bumper is welded up and about ready to bolt onto the frame after I clean the flux-core dingleberries off. Also mounted my first beadlock wheel/tire combo. That took about 1-1/2 hours
I need to buy a torque wrench that doesn't weigh 5lbs ![]() Unfortunately last night my daily driver/beater 240sx had a timing chain tensioner self-destruct and killed the timing gears/chain and I'm about 90% positive valves are bent. The car's a damn money pit so I'm trying to get rid of it and find something else cheap temporarily. Unfortunately this will divert my Jeep funds a bit ![]()
#208 |
That sux man. I'm about to start my 60/60 combo on mine. I've just gotta find the front now.
#209 | |
Now in the 937
Got my bumper mounted and ready to mock up the spring shackle hangers:
![]() ![]() ![]() ![]() Mounted and "balanced" my first beadlock wheel w/ the 40" LTB. They're 17" Allied Daytona Rock-a-Thon wheels. ![]() Stuck 14oz of BBs in them. Got a $5 "diet scale" from Wally World to measure them out. Here are the other BBs ready to go in the other 3 tires: ![]() Admired my Ballistic Fabrication joints for a bit The large 3" joint on right, their 2.63" joint on left. The large joints are being used for my single upper control arm for my front 3-link.![]() And also on Friday I stopped on my lunch break to get new face shields for my welding helmet. None were in stock so I left w/ a $220 Hobart helmet. This thing is awesome and I can see what I'm doing so much better now. Definitely worth the money.
#210 |
This probably shows that im a newb, but thats ok.
Why did you put bbs in them?
Seinna Jeep Club: Member #25 ___ ___ [l_,[____], l---L- OllllllO- ( )_) ( )_)--)_) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
