first timer yj build - Page 4 - JeepForum.com
post #46 of 203 Old 07-24-2012, 11:54 PM
1SASjeepster
Can't wait to see it finished.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #47 of 203 Old 07-29-2012, 06:51 PM Thread Starter
sxi4evr
once again i'll let the pics do most of the talking, but:
i painted the inner fenders and inner grill to go with the blue once i paint it
finally took off that gay chrome grill to find some beautiful rust (luckily just surface rust) the chrome grill is going to be hung on the wall in my bedroom!
sanded the rust down to bare clean steel and primed it (primer not pictured)
took a step backwards as far as a well equipped off road rig goes by grinding off that huge angle iron winch bracket. (temporary until i buy a new winch idk when) this looks way better sans winch
grinding that angle iron off took 8 cut off wheels and the only sawzall blade i had at the end i just broke it off via hammer and pry bar. when i get another sawzall blade i'll trim the bumper.
AAAND we wired the dash for the cobra
and it looks like some of the pics got messed up from downsizing. oooops
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline
post #48 of 203 Old 07-30-2012, 03:42 AM
ashland82391
Awesome build so far. You have a great jeep for your first jeep build. RUST SUCKS! Kudos for staying with the 2.5 too
ashland82391 is offline
post #49 of 203 Old 07-30-2012, 06:53 AM
1SASjeepster
Great photos!
Take care,
post #50 of 203 Old 07-30-2012, 01:35 PM Thread Starter
sxi4evr
Christmas in July!!! packing was perfect, delivered right when they said, and good easy to work with people. A+++ for northernautoparts.com!!!
I took the pistons to the machine shop about 5 minutes after i opened the box haha they say it should be ready by Friday
sxi4evr is offline
post #51 of 203 Old 07-30-2012, 01:36 PM Thread Starter
sxi4evr
Originally Posted by 1SASjeepster View Post
Great photos!
Take care,
thanks, and thanks
sxi4evr is offline
post #52 of 203 Old 08-02-2012, 01:00 PM Thread Starter
sxi4evr
finished my bumper just now, took forever for the paint and primer to dry in this humidity. I think its an improvement also, my LUK clutch kit came in today. $131 shipped from clutch city online. as long as the rest of my parts get here and my block is done when the shop says it will be i should have it running by Sunday night
sxi4evr is offline
post #53 of 203 Old 08-02-2012, 01:24 PM
Mishimoto
Vendor
Mishimoto's Avatar
Did you already get your flywheel re-surfaced or do you have an aftermarket on the way?
Mishimoto is offline
post #54 of 203 Old 08-06-2012, 07:40 PM Thread Starter
sxi4evr
preparing myself to get flamed on.... LOL no i'm not getting it resurfaced.. i know i should however I've seen plenty of people just throw in the new clutch kit with zero problems. the flywheel was very closely inspected and cleaned. also the clutch felt 100% before
FINALLY got the block back! i love the look of freshly machined cylinders
sxi4evr is offline
post #55 of 203 Old 08-07-2012, 07:17 PM Thread Starter
sxi4evr
bottom end is together! main bearing oil gap is within spec, connecting rod bearing oil gap is within spec, crank end play is within spec, ring gaps are within and spec. and everything is spinning smooth! also, a pic of my new cam and lifters
sxi4evr is offline
post #56 of 203 Old 08-07-2012, 08:20 PM
lovett86
i remember when my dad had the engine rebuilt in the jeep i have now, he sent the block out with the pistons/crank/rods and every thing stripped from it, he new the guy at the machine shop, he had the head and valves done, new cam and bearings all around, only had to replace 1 piston and hone out the cylinders, turned out great when it was all back together, purred like a kitten,when it was all done, havent had a problem with it since
i wouldnt worry about getting flammed on a 4 cyl rebuild, its worth it in the end, at least it was for us
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #57 of 203 Old 08-07-2012, 09:55 PM Thread Starter
sxi4evr
oh i was just joking about getting flamed on for not resurfacing my flywheel with the new clutch haha but yeah i'm definitely looking forward to this thing running like new!
sxi4evr is offline
post #58 of 203 Old 08-08-2012, 07:32 PM Thread Starter
sxi4evr
not much to say here, but i am getting closer
sxi4evr is offline
post #59 of 203 Old 08-11-2012, 10:34 PM Thread Starter
sxi4evr
she's alive!!! had to extend the cherry picker a bit to get it in haha
after getting a couple mixed up wires sorted out she fired right up
took it around the block and the coolant temp was rising close to the red...shut it off and checked it, out visually everything was fine. got down the street and it was getting hot again so i shut it back off. slowly took off the radiator cap and it was pretty dry so we walked back and filled it up with coolant. it took maybe about 1/2 to 3/4 of a quart? (my dad poured it while i was holding the hood so not totally sure...) got down the street and it was getting hot again but then suddenly dropped showing the thermostat opened... after that we just let it run for about 20 minutes and it held a steady temp just above 210. we'll look into it more tomorrow i'm too tired to think straight now lol
also got my lube for the good ole ax5!!!
sxi4evr is offline
post #60 of 203 Old 08-11-2012, 10:37 PM Thread Starter
sxi4evr
aand a big thanks to my dad for helping me out when needed!
sxi4evr is offline
2001 TJ First Timer Neeglik Jeep Builds 35 06-24-2015 07:26 PM
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
