first timer yj build - Page 3 - JeepForum.com
post #31 of 203 Old 07-16-2012, 11:19 PM
huffdesign
1971 CJ5
Awesome Job
Man good job!!!!!
huffdesign is offline
post #32 of 203 Old 07-17-2012, 08:39 AM
Mishimoto
Vendor
Mishimoto's Avatar
What did you use to clean the ports and deck? Are you planning on repainting the Jeep at sometime?
Mishimoto is offline
post #33 of 203 Old 07-17-2012, 09:00 AM Thread Starter
sxi4evr
thanks! for the deck i used a round scotch bright style pad on a 90* die grinder, for the domes i very very VERY carefully used a small wire wheel type thing on a drill (its old and took on a different shape that its supposed to so it fit in the domes perfect) and in the actual ports i scraped out the carbon with a scraper. after i wiped it down with brakleen and blew it all off with air.
and yessss i have no idea what color though. originally i was thinking the 2012 gecko green but now idk haha it will be a single stage acrylic enamel though
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline
post #34 of 203 Old 07-17-2012, 09:09 AM
Mishimoto
Vendor
Mishimoto's Avatar
I'd be tempted to send the head out to have a 3 angle valve job, and milled to clean it up. I'm not sure what the specs are on that engine on how much you can mill and get away with, but if you can afford it now when everything is already apart, I'd do it.
I'd probably paint the block black. Why'd you change your mind from Gecko Green?
post #35 of 203 Old 07-17-2012, 02:51 PM Thread Starter
sxi4evr
well for this being mostly a maintenance/preventative build i think the head should be fine. and I haven't necessarily changed my mind, but when with all the options it's really hard for me to decide haha http://www.tcpglobal.com/restorationshop/rspcolors.aspx i guess a black engine would look best with any bright colored jeep
P.S. i'm open for color suggestions!!!!!
sxi4evr is offline
post #36 of 203 Old 07-17-2012, 03:10 PM
Mishimoto
Vendor
Mishimoto's Avatar
I'd do that work to the head for preventative reasons, not trying to go for performance.
post #37 of 203 Old 07-17-2012, 03:12 PM Thread Starter
sxi4evr
preventative of what exactly?
sxi4evr is offline
post #38 of 203 Old 07-17-2012, 03:25 PM
Mishimoto
Vendor
Mishimoto's Avatar
Well you've got the bottom end out to get some new bearings, an overbore, honed, etc. because of wear, why not treat the head? It's got 180,000 on it, and yes it has hardened valve seats, but personally I'd have them cleaned up. The valves you could clean the carbon off at home, then the shop would just have to grind the ends of the stems and the faces. Have it milled for the sake of the new headgasket.
I like to go through all that so that way I have the job done once, and it lasts. Sometimes the efficiency of the new parts/machining make the original parts show their flaws.
post #39 of 203 Old 07-17-2012, 07:29 PM Thread Starter
sxi4evr
update for the day: started cleaning external engine parts and picked up valve seals from autozone ($11.99 for 8 felpro) I also talked to the machine shop today. the block was in the hot tank so tomorrow they'll let me know what size pistons i should order
sxi4evr is offline
post #40 of 203 Old 07-23-2012, 07:49 PM Thread Starter
sxi4evr
well since the machine shop is taking foorreevvveeeerrrrrr i'm starting body work haha the color i'm thinking 2012 jeep cosmos blue/ford grabber blue also, i think i'm going to trim my rear flares instead of hacking the tub for tj flares. if it doesn't turn out good then i'll just go the tj route but its worth a try.
sxi4evr is offline
post #41 of 203 Old 07-24-2012, 07:21 AM
Mishimoto
Vendor
Mishimoto's Avatar
What about mopar's old B5 Blue?
post #42 of 203 Old 07-24-2012, 08:01 AM
1SASjeepster
sxi4ever,
Two questions:
(1) What size tires and rims are you running and what lift do you have?
(2) Glad to see another jeeper out there knows what a 427 Cobra is. Where is the chassis?
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #43 of 203 Old 07-24-2012, 09:43 AM Thread Starter
sxi4evr
that color looks awesome!!!! but correct me if i'm wrong because I'm a complete paint noob (I've only done one other none rattle can job which was on a jet ski)...but a metallic is probably harder to spray then a solid color right? that's why the solid grabber/cosmos blue is so appealing to me (besides the fact that i really do think it's awesome) i attached a pic of the ski i painted... just primer and acrylic enamel. had pretty good gloss and held up GREAT for about 4 summers
its a 4" rough country lift with 33" tires and 15x8 soft 8's and its in the 3rd garage bay...all aluminum is in, lines routed, just wiring up the dash then she'll be ready for the engine and trans!
sxi4evr is offline
post #44 of 203 Old 07-24-2012, 01:54 PM
1SASjeepster
That chassis looks beautiful and so does your jet ski. Well, if that paint lasted four summers through the hot sun and all of the landings, I would say you have done well!!
Take care,
post #45 of 203 Old 07-24-2012, 07:07 PM Thread Starter
sxi4evr
thanks 1sasjeepster!!!
got all of the pin striping off today and it looks way better already! and i started sanding, i really don't think there'll be too much body work which is always a plus.
and most exciting of all, got a call from the machine shop finally! i guess they've had a machine down and have also been super busy.. but they say .040 (which seems high for an engine that had no known problem, just high mileage i guess) will clean it up so now i have my pistons, rings, bearings, gaskets, oil pump, and water pump coming on its way!!! parts are federal mogul, melling, perfect circle, and cardone
sxi4evr is offline
2001 TJ First Timer Neeglik Jeep Builds 35 06-24-2015 07:26 PM
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
