First Jeep - 99 XJ Build - Page 3 - JeepForum.com
post #31 of 395 Old 06-05-2010, 11:10 AM Thread Starter
NW99XJ
Originally Posted by ajxj9197 View Post
great start! any specifics you got the procomp lift? keep up the work and cant wait to see it with some meats
Thanks, yea its just a start. Still have a long way to go with armor, and recovery. As to the specifics on the lift: I covered everything on earlier on in the post, but it consists of 3" springs, full leafs, lower control arms, trac bar relocation bracket, extended sway bars and links, and ES3000 shocks. I picked it all up at 4Wheel Parts, (have one local.) Meats are next. I've got 235/75/15's now, will probably go with 31x10.50's maybe 275/75/15's. Unless i find a screaming deal on CL for some 30's. But thats the size range i'm looking for.
Originally Posted by 2000BB6 View Post
looks great man think once i save up for a real lift ill go with your same setup
Its not a bad way to go! Seems to be one of the more complete kits out there, the only other one I was looking at was the Rubicon Express 3.5" kits. But they were several hundred dollars more with full leafs than what I paid for this kit. Just do your research, and dont be affraid to go into your local 4WD shops and talk to the guys there. You'll get good advice and gain some valuable knowledge. Crawl the forums looking at set ups on similar years of Jeeps as yours, and what the owners ran into when doing their lifts.
5+" of lift, 33's, OTK, Armored, Lighted, Chipped, Winched & Locked up Front.
NW99XJ is offline
post #32 of 395 Old 06-05-2010, 01:22 PM
AustinTexasXJ
1987 MJ Comanche
trim and go straight for 33's
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #33 of 395 Old 06-05-2010, 01:52 PM
platinum5.9
2003 WJ
Might as well you will be wanting to go bigger soon enough...could always do shackles and spacers.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #34 of 395 Old 06-05-2010, 02:02 PM
billabongopblue
I agree, i did the same setup you have now last october and im building up to be ready for 33's in the near future.
If you have the money get the axles re geared to 4.56's and get some 33's on there. Then trim it up.
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #35 of 395 Old 06-08-2010, 08:13 AM Thread Starter
NW99XJ
Thats kind of the next phase of things. Armor and recovery are next, as well as a new exhaust. But then i'll do some shackles, and (maybe) spring spacers, if not just find some 4.5" springs. But i'm gonna have to save a serious pile of pennies to re gear. I wont even attempt to do 33's with out goin to 4.56 gears. I'll of course have to get the rear locked at the same time (prob just a lunch box)..... but thats gonna be a big chunk of change dropped all at once. But yea thats the plan. Next couple of weekends gonna have to get this out and get some flex pics for ya'all.
NW99XJ is offline
post #36 of 395 Old 06-08-2010, 09:55 AM
AustinTexasXJ
1987 MJ Comanche
nothing wrong with 33's and 3.55
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
post #37 of 395 Old 06-08-2010, 08:02 PM
XJ713
Nice jeep!
1999 jeep Cherokee 4.5" lift, DD
XJ713 is offline
post #38 of 395 Old 06-08-2010, 09:17 PM Thread Starter
NW99XJ
Transfer Case Drop
So last weekend I picked up a transfer case drop kit. The driveline vibrations were getting to me, and ignoring something like that for any extended period of time is just not a good idea. They werent bad really, not shaking the fillings out of my skull or anything. But still something had to be done. Called around, and no body had anything in stock, everybody was a week out. And internet shipping was going to get spendy. But Mark down at Central 4WD really came thru for me. They didnt have anything on their shelves, but he knew a local install shop that did, and had one drop-shipped for me that day. THANKS MARK!! So after work Friday, went and picked up my new Skyjacker Transfer Case Drop Kit for lifts 2.5" - 4.5".
The install is pretty straight forward, however the instructions were recommending I loosen up the engine mounts, and breaking one of those bolts, or replacing a mount was just not a risk or project I was willing to deal with that weekend. So i went about dropping the transfer case cross member, 4 bolts (well 2 bolts and 2 nuts - each side has a stud that comes down, and a bolt that goes up into a weld nut.) 3 of the 4 came out no prob.
But of course, nothing is ever easy when working with Jeep hardware:
Ugh... i'm getting real tired of seeing this every time I turn a wrench on this thing:
I tried for over 5 hours to extract that damn f_cking bolt. No luck. Drilling, easy outs, 2 broken drill bits and a bunch of torching and welding experiments later, and it hadnt budged a inch. So i continued on with the install anyways. It all went in real easy (i still have to install the linkage drop bracket) and after everything else was in. It was time to WELD. I've only welded a couple times before. Nothing major. So lets hope my Farmer Jon Welds hold up.....
Yea I know, ugly as hell. But its been a few days now, and everything is rock solid still. Trail abuse will be the ultimate test. But i'm confident it'll hold.
NW99XJ is offline
post #39 of 395 Old 06-11-2010, 06:22 PM
BeepBeepGoJeep
1994 XJ Cherokee
looks good cant wait to see it with some meats, i had one of the 4 bolts on the t case break also lol.
[]IIIII[]
BeepBeepGoJeep is offline
post #40 of 395 Old 06-30-2010, 12:16 PM
HikerX
2014 WK
Great job so far!
If the look of the drop bugs you too much, you might want to get some scrap metal and try different spacing to see if you could get by with less of a transfercase drop. Might take some experimenting...
Case in point, I went from this:
...to this:
Granted, I have barely 2 inches, but in about a month I'll have another 1.5" or so over that, so I may have to reinstall the original transfercase spacer.
Nice job so far, and kudos to dealing with all the troublesome bolts. I tend to have the same luck with every bolt I touch as well....
'14 WK2 Limited
Previous Jeeps
'11 JKU - '96 XJ Country - '04 TJ - '86 CJ7
HikerX is offline
post #41 of 395 Old 06-30-2010, 12:21 PM
HikerX
2014 WK
Originally Posted by NW99XJ View Post
Whoops!
I just reread your post and realized you had to *weld* it up thanks to that broken bolt. Guess experimenting with different drops isn't an option right now...
'14 WK2 Limited
Previous Jeeps
HikerX is offline
post #42 of 395 Old 06-30-2010, 12:34 PM
getgnar
1997 XJ Cherokee
cherokee looks real good. looking forward to seeing more updates
getgnar is offline
post #43 of 395 Old 06-30-2010, 03:18 PM
Toedwy
AFTER: (rear only)
Thats the exact OPPOSITE of what my xj looks like haha...
Toedwy is offline
post #44 of 395 Old 09-25-2010, 07:09 PM Thread Starter
NW99XJ
Well Its been a little while since I've done any work. Been staring at a pile of parts, and finally got the time to do something about it. HOWEVER.... On my way up to my buddy's place to use his tools and driveway, my passenger front window fell into the door. Out of nowhere! No issues before hand on this, but right before it happened i hear this loud *TICK*... and I knew instantly what had happened. The regulators on the XJ's have a slight design flaw in how the window track grabs the worm drive gear to make it go up and down; its a tinly little piece of plastic. I know there's repair kits online, i've seen 'em before, but with rain on the way, i had to do something about it right away. $120 later, and I was tearing apart the door to do the swap. New motor and regulator went in.
Here we are with the door panel off,
Easy to do, just take out all the screws, pop it loose from the door, remove the two blue plugs from the switches, and pop off these clips from the door release and lock linkage. They just rotate off. Might need to use a little force, but they DO come off, a flat head screwdriver will help with prying them loose.
Just remove all the bolts, that hold in the regulator and motor, unplug the wiring harness to the motor, and pull the whole assembly out. Here is the door all gutted. Just do the reverse to put in the new assembly. Pretty easy really. Only took about 30-45 min, if that.
Next up was the Transfer Case Drop Bracket Shift Linkage Spacer. Finally got my 4Lo back!
Installation was pretty simple, had to pull the front seat out to get to the top of the bolts that hold the bracket to the floor pan, where the pivot point is. Other than that, it went pretty quick.
Next up was the Dyno Max Cat Back Exhaust. Been sittin on this for a while now, so I was anxious to put it on. This too went in real easy. Out with the old, in with the new!
(Bizz the Cat decided to lend his expertise in this endeavor)
As you can see it tucked up pretty nice.
And I picked these up a couple moths ago, couldn't pass up the deal on got on them, and they're in like new condition. They'll work out perfectly too, as I don't do a whole lot of extreme rock crawling. Couple mounts to the "frame" and five across the pinch seam. Pretty much the same as alot of other rails out there.
Looks good to me!
And here's a shot in the daylight:
Went to install a JCR "type" bumper I got off a guy on Craigslist too, (almost identical in every way) but I think his jig was off when he welded it together, cuz it sat about a 1/4" too high, and wouldn't let the rear hatch close. All the work to take off the factory rear bumper, get this new one mocked into position, only to find out that it doesn't fit properly. I don't have the time or the means to fix the fab work on it to make it fit right. So I'll have to figure something out down the road as far as thats concerned. So its back to stock on the bumper for now.
NW99XJ is offline
post #45 of 395 Old 09-25-2010, 07:13 PM Thread Starter
NW99XJ
Found a killer deal on Cragslist, a Brand New ProComp Steering Stabilizer, for only 15 BUCKS! The guy even had a black shock boot to go with it. Matches my whole suspension set up in every way! (ftw)
I'll probably be putting this on sometime in the next couple weeks.
(weather providing)
NW99XJ is offline
First Jeep Build Bosefus Jeep Builds 4 06-20-2012 09:35 PM
My Last Jeep Build!! PSIBrad Jeep Builds 1 06-23-2010 10:03 PM
My Jeep Build itsge0ff Jeep Builds 24 06-21-2009 05:42 PM
My first jeep build KRIZB Jeep Builds 9 09-13-2008 02:06 AM
The First Jeep Build cowboyway Jeep Builds 0 09-11-2008 09:12 AM
