First Jeep- '04 TJ Rubicon - JeepForum.com
post #1 of 64 Old 06-06-2012, 06:42 PM Thread Starter
FirstTJ12321
My Jeep shipped from Ohio to Massachusetts and it FINALLY ARRIVED!
I have pics that i took today just from my driveway. It isnt registered or titled yet so its currently illegal , and because of this i will not have any trail pics for about a week. Until then i have some pics right here!
2004 TJ Rubicon --- 4" Teraflex Long Arm+ 1" BL --- 35" Bf Goodrich 35 x 12.50R-17LT
My Build Thread: http://www.jeepforum.com/forum/f22/first-jeep-04-tj-rubicon-1378151/
FirstTJ12321 is offline
post #2 of 64 Old 06-06-2012, 06:50 PM Thread Starter
FirstTJ12321
(long) list of things currently broken/ in need of repair:
1. Need to replace blower motor resistor
2. (This Pisses Me off) Lock on center console (which also rattles like crazy) fell off, and does not want to go back on for some reason.
3. HORRIBLE rattle on the dash where the speedo is
4. Right tail light has broken bulb EDIT: BROKEN WIRE
5. Custom Locker Toggle switch has an LED out.
6. I have no f***ing idea how to turn on the extra blue lights that this guy before me stuck on the bumper for no reason, or what they are for.
7. The man before me stuck extra orange lights on hard top (looks good from outside) inside there are wires all over the roof.
8. The front right and rear windshield wipers need to be replaced.
9. I don't know if this is normal but in first and second gear it sounds like there is a ton of really fast clicking coming from the axle or something.
*Thats about it, and i look foward to getting these things fixed. Pics In next post.
RED MARKS DONE
post #3 of 64 Old 06-06-2012, 06:55 PM Thread Starter
FirstTJ12321
post #4 of 64 Old 06-06-2012, 07:01 PM Thread Starter
FirstTJ12321
_
post #5 of 64 Old 06-06-2012, 07:02 PM Thread Starter
FirstTJ12321
_
post #6 of 64 Old 06-06-2012, 07:03 PM Thread Starter
FirstTJ12321
_
post #7 of 64 Old 06-06-2012, 07:06 PM Thread Starter
FirstTJ12321
_
post #8 of 64 Old 06-06-2012, 07:16 PM Thread Starter
FirstTJ12321
Sorry the pics are so big its the camera. This is by far the funnest thing i have ever been in. It's like a rollercoaster all of the time, except the seat belts don't lock!
post #9 of 64 Old 06-06-2012, 09:16 PM
G Beasley
1. A/C only works on High Fan Setting
Sounds like you need a blower motor resistor .
Mine has a C clip that holds it in .
Havent had that one luckily .
No biggie , easy to fix .
New switches arent too bad and theyre some really nice ones laser engraved with front and back already on them .
Looks like reverse lights to me . With the key in the ignition but the engine off put the transmission in reverse and see if they come on .
Wire loom and velcro will clean it up . Though it will slow down the removal of the top . You can remove the lights and fill the holes with a stainless steel bolt . Just make sure to seal them as you install them .
This ones cheap and easy .
This could be potentially scary as my 6 speed doesnt make any noise . At the bare minimum a fluid change should be in order . Dont use just any gear oil . I got mine from the dealer as it is transmission specific , but some of the guys on the forum have been using Amsoil / Redline products .
Was any of the above disclosed before you purchased ? If not did you get it below blue book ?
G Beasley is offline
post #10 of 64 Old 06-07-2012, 05:32 AM Thread Starter
FirstTJ12321
I got it waaay below blue book and none of this was disclosed but i like to spend time fixing things so i don't really see this as a bad thing. it kinda occupies my time .
Thanks for the help man the c-clip thing i'll have to look into.
post #11 of 64 Old 06-07-2012, 05:43 AM Thread Starter
FirstTJ12321
Just checked- those lights arent reverse lights… and they dont turn on with hazards or headlights… im stumped.
post #12 of 64 Old 06-07-2012, 07:31 AM
janesy86
Nice Rubi you got there! I'm on the North Shore also with a Silver Rubi, just not quite a big!
As for the lights on the rear, they must be some type of aux reverse light, I'd guess. Any switches on the inside that you dont know what they are for? Or maybe they aren't hooked up somewhere, try tracing the wiring?
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
janesy86 is offline
post #13 of 64 Old 06-07-2012, 05:18 PM Thread Starter
FirstTJ12321
Thanks! There arent any switches on the inside relating to those lights. I'll try tracing the wiring
Right now I am going to get a tail light, windshield wipers, and some screws for the dash.
post #14 of 64 Old 06-08-2012, 07:34 PM Thread Starter
FirstTJ12321
The wiring is a complete maze. It goes from the light, down the frame, up the inside from the rear, around the rollbar, down the rollbar and then into a hellish jumble of wires.
It still remains a mystery. Adding onto a list of things to do……
1. Spiff up the inside. Person before me put POR-15 on about 30 percent of it.
2. New weather stripping. Swimming pool sized hole on left door and tears all over right door
3. Make wires for aux lights on hardtop have a plug leading up. Wires need to be stripped so im heading to You-Do-It electronics tomorrow.
4. Found out source of dash rattle- Where two screws WERE there are breaks in the plastic that holds the dash down. The dash needs to be replaced.
5. Oil filter needs to be changed.
6. Idiot light is currently ON. Need to check everything and see if something is wrong.
7. Need to identify axles, as they do not appear to be stock.
That covers today's inspection i think… yaay...
post #15 of 64 Old 06-08-2012, 07:42 PM
G Beasley
Post close up pics of the axles , probably 44s with aftermarket diff covers .
Jeep Rubicon AEV build mbuch65650 Jeep Builds 0 05-09-2012 09:15 PM
My 2004 Jeep Rubicon Build...new to this JEEP thing!!! bcheung30 Jeep Builds 554 10-27-2011 01:56 PM
Your Jeep on the Rubicon Trail 4bangersampler Jeep Picture Requests 15 05-20-2011 10:11 AM
2003 Jeep Rubicon sgraham Jeep Builds 4 10-02-2009 06:02 AM
Jeep RUBICON MB98XJ Jeep Picture Requests 5 06-25-2008 09:39 PM
