EugeneTheTJ's 2003 TJ Build Thread - Page 68 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > EugeneTheTJ's 2003 TJ Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-28-2013, 12:16 AM   #1006
Cavasar
No Longer DD
Cavasar's Avatar
How are you liking those MT/Rs? It'll be a while before I move up to 35s but I'm researching now. Considering BFG KOs (ran this style since we bought the Jeep), KM2s, and MT/Rs.
Cavasar's TJ
May TJ of the Month 2015
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 11-28-2013, 07:07 AM   #1007
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Hands down the best tire I've owned. As long as the jeep is dual purpose its probably going to get these tires
EugeneTheTJ is offline   Reply With Quote Quick reply to this message
Unread 03-12-2014, 06:08 AM   #1008
EugeneTheTJ
Tar Heel
I've got a tremendous squeak coming from somewhere up front. I've replaced the ds to yoke u joint and the unit bearing and it's still there.
Squeaks on take off and stops, 0 to 8 mph and vice versa.
Thoughts? Cv part of driveshaft?
It's bugging the **** out of me.
Unread 03-12-2014, 06:19 AM   #1009
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by EugeneTheTJ
I've got a tremendous squeak coming from somewhere up front. I've replaced the ds to yoke u joint and the unit bearing and it's still there. Squeaks on take off and stops, 0 to 8 mph and vice versa. Thoughts? Cv part of driveshaft? It's bugging the **** out of me.
Centering kit on the front DS.
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 03-15-2014, 02:44 PM   #1010
EugeneTheTJ
Tar Heel
Pulled the shaft and drove around. It definitely helped but there's still a squeak somewhere. I'm tempted to set the ****ing jeep on fire.
Unread 03-15-2014, 02:51 PM   #1011
tyvanwie
Let me buy some stuff before you burn it
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 03-15-2014, 05:31 PM   #1012
EugeneTheTJ
Tar Heel
I can't figure out what this could be.
Axle shaft u joint?
Brake rotor?
So confused.
Unread 03-16-2014, 09:27 AM   #1013
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Sounds like brake caliper and rotor to me. Look to see if the pads had a wired wear to them.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 04:22 PM   #1014
EugeneTheTJ
Tar Heel
It was the pinion yoke. Needing a nice lubing. No more squeak and driveshaft back in. No more 2wd jeep!
Unread 05-06-2014, 12:01 PM   #1015
EugeneTheTJ
Tar Heel
Eugene might be getting some relief as my DD.
Going to look at a seXJ either tonight or tomorrow.
Unread 05-07-2014, 03:22 PM   #1016
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
Didn't you pick up a FSJ a while back?
LifeProof is offline   Reply With Quote Quick reply to this message
Unread 05-07-2014, 03:32 PM   #1017
EugeneTheTJ
Tar Heel
I didn't really "pick it up." It was my (late) great-aunt's and I traded her son for it.
I finally got it in my possession though. Now that I have my own house and not an apartment I was able to finally get it out of my mom's driveway!
This is its new home. Restoration will be beginning soon...
Unread 05-16-2014, 10:14 PM   #1018
EugeneTheTJ
Tar Heel
Didn't get the xj. However I'm going to look at something different in the morning. Something too sweet to pass on.
Unread 05-16-2014, 10:16 PM   #1019
ucffootball85
nice
ucffootball85 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2014, 03:44 PM   #1020
EugeneTheTJ
Tar Heel
That deal didn't go through (vehicle was sold before I could make it there).
I'm pretty set right now on getting a Comanche as my dd. Need a truck...want a jeep. Seems like the solution!
best avatars on jf , dd on 35's , retired dd , tj
