Dub J build on a budget - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Dub J build on a budget
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-16-2014, 08:57 PM   #1
NorAzWJ04
The wife has my wallet!!!
NorAzWJ04's Avatar
So picked up my 2004 jeep overland about a year ago. I had a 2002 jetta tdi just me the wife a daughter....then came the second daughter,obviously not big enough so got the jeep for the wife.....and here we go!
NorAzWJ04 is offline   Reply With Quote
Unread 04-16-2014, 09:16 PM   #2
NorAzWJ04
NorAzWJ04's Avatar
Up to date pic pulling my buddy to Moab /f12 Moab trip 2"bbin front roof rack hi lift shovel 17x8.5 mb razors 245/65 Faulken ats
Unread 04-16-2014, 09:18 PM   #3
NorAzWJ04
NorAzWJ04's Avatar
So I found out in Moab that the offset of my wheels pulled out the lips of my rear fenders, so I ordered a rear 2" bb,I want it to be level so I'm thinking about 2.5" springs in front as we'll give me ideas concerns feedback parts list of what I might need
Unread 04-16-2014, 09:34 PM   #4
NorAzWJ04
NorAzWJ04's Avatar
Another update crown king run
Unread 04-16-2014, 09:49 PM   #5
AZdEvilYJ
Garage Junkie
AZdEvilYJ's Avatar
Damn the YJ is SICK!
Let's get that BB on!
'95 YJ 2.5L
March '13 & '14 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
http://www.jeepforum.com/forum/f22/a...nally-1575209/
AZdEvilYJ is offline   Reply With Quote
Unread 04-19-2014, 01:29 AM   #6
AZdEvilYJ
Garage Junkie
AZdEvilYJ's Avatar
Hooked up the dub with a 2" budget boost with some poly spacers
Install was pretty straight forward. Took is about 1.5 start to finish
We started by removing tires, shocks, and sway bar.
Then we dropped the axle as low as possible and jacked up the other side enough for is to pull out the coil. After the coil was out we pull out the rubber spring retainer and put in the spacer and reinstall the rubber retainer
Put the Coil back in and reseat it, and reinstall everything else.
All finished up
And of course we had to go test it out!!
Stuffin it but no more fender rubbing. It was pulling out the fender lips on Fins N'Things in Moab
'95 YJ 2.5L
My Build Thread
Unread 04-21-2014, 08:19 PM   #7
NorAzWJ04
NorAzWJ04's Avatar
We'll got some bad news, after installing the lift did a shake down everything went well. Headed home and all of a sudden the jeep lost power started smelling fuel,big manifold leak limped in couple miles and just died at a stop would not start, checked the battery it was dead recharged it all good alternator was good as we'll put a jump box on it started but barely huge manifold exhaust leak idled ruff then wouldn't start back up. So tis weekend going to do a compression test and go from there. Any ideas of what's up?
Exciled offroad-Arizona
http://www.jeepforum.com/forum/f22/d...udget-2332545/
Unread 04-21-2014, 09:15 PM   #8
AZdEvilYJ
Garage Junkie
AZdEvilYJ's Avatar
lol that was a tough read. Commas, periods, and paragraphs my good friend!
Did you pick it up already?
'95 YJ 2.5L
My Build Thread
Unread 04-21-2014, 09:17 PM   #9
NorAzWJ04
NorAzWJ04's Avatar
I'll pick it up this weekend most likely Sunday only day I can get dans diesel...take it back to his house and do a compression check then go from there
Unread 04-21-2014, 09:35 PM   #10
AZdEvilYJ
Garage Junkie
AZdEvilYJ's Avatar
I think there is a short somewhere. There was no water in the oil right?
'95 YJ 2.5L
My Build Thread
Unread 04-22-2014, 06:02 PM   #11
NorAzWJ04
NorAzWJ04's Avatar
Lol short is right I think someone put the jumper box cables on backwards!
