DNFJ's TJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > DNFJ's TJ Build
Alloy usa heavy duty ball joint kitsBds fox ipf 2.0 racing series shocks now available at rockENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 10-31-2014, 10:02 PM   #1
DNFJ
DNFJ's Avatar
DNFJ's TJ Build
So earlier this week I sold this:
'00 6.5" IRO lift on 35s
and bought this:
'00 w/ 160k TJ surface rust on the frame, a broken body mount, and rotted fenders for $4000
Ordered some flat steel tube flares for it, 33" grabbers, and a friend is giving me his old 2" budget boost. Long term plan for this one is 3.5" of lift, long arms with a rear stretch, and a D44 or Ford 8.8 on 35s with a tummy tuck. Stubby bumper for approach angles, etc.
I want to keep it low and centered with a good amount of articulation but also streetable for DD duties for now.
Will post some more updates tomorrow once the cutting gets started.
Just Another Yellow TJ
Built Not Bought #704
Previous:
'00 XJ 6.5 on 35" KM2s
'96 ZJ 2 on 31" Baja Claws
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 02:07 AM   #2
DezertTJ
Phrasing
DezertTJ's Avatar
Grind that surface rust down and make it all cleaned up before you get to modifying it. I have intense ocd about rust and that's in the az desert! Looking forward to how it turns out
06 LJ Rubicon: AZ Backcountry LJ Build
Iím very important. I have many leather-bound books and my apartment smells of rich mahogany
DezertTJ is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 07:07 AM   #3
DNFJ
DNFJ's Avatar
Already planning on it, it was obviously treated at some point, but I'm going to clean it up a bit more, use an air gun to blow out the inside, then coat it with Eastwood's internal frame spray
Previous:
Unread 11-01-2014, 11:18 AM   #4
dadkinsemt
Lost
dadkinsemt's Avatar
Like what you did with the XJ, looking forward to this one.
Dusty
05 LJ rubicon
14 JKU, wife's
Mile Hi jeep club, Patrol 9
MY BUILD
dadkinsemt is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 05:22 PM   #5
DNFJ
DNFJ's Avatar
And here's how it sits after the first weekend. Still have the rear flares to do and finish up my led conversion for most of the bulbs, along with get 2.5" led turn signals to put in the front grille.
Rampage housings, smittybilt (ugh) front fenders which will serve as a platform to weld flares onto at a later point, along with a possible semi-exo cage at least for the front end, and 33" grabbers.
Previous:
Unread 11-02-2014, 07:01 PM   #6
MOBBiN
MOBBiN's Avatar
Ive been thinking about selling my cherokee and buying a wrangler a lot lately. I'll be watching.
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 11:13 PM   #7
LeeMasterGT
Build: http://www.jeepforum.com/forum/f22/project-ruby-re-do-1481704/
LeeMasterGT is online now   Reply With Quote Quick reply to this message
Unread 01-13-2015, 05:43 AM   #8
tofuzeppelin
tofuzeppelin's Avatar
Anything been goin on with this man, & what rear are you planning on running?
01 TJ with some stuff
01 XJ with no rust
76 Ford with both
WTB TJ hard top, let me know what cha got
tofuzeppelin is offline   Reply With Quote Quick reply to this message
