Dirts 98 TJ "Runt" LCG Build thread - JeepForum.com
post #1 of 650 Old 08-25-2010, 10:10 PM Thread Starter
Dirt22
I bought "Runt" in Feb of this year with the intention of haveing a mild rock crawler and daily driver... But the longer I have her, the more I go t'wards Rock crawler and less t'wards DD.
Current specs and pics as of Feb 2012 are here ---> http://www.jeepforum.com/forum/f22/d...l#post12987843
Bought "Runt" in Feb of 2010, a 98 6 cyl TJ with AC and a Hard Top
Here's what aftermarket stuffs she had on at the time:
2.5" Rancho Rock Crawler lift
Ox Locker in the D35
3.73 gears
285/75/16 KM2s on Rubicon alloy wheels
Unknown name Aluminum rock sliders
Not bad for $7000 - No rust, but was missing the rear seat, and carpet. (easy craigslist finds)
Sence then I've added the following:
sh!ttybuilt front bumper
Rampage rear bumper w/ tire carrier and lights
Rampage frameless soft top
High Lift jack mounted on hood
sh!ttybuilt 8000# winch and winch plate
No Name brand stearing linkage (bought at TDS event to replace broken one on the trail)
4- Hella 500 with Daystar switches in the vents
Cobra CB, Firestick etc... the kind where all the controls are on the mic
Flush mount tail lights
Stuff I made:
Custom built a stinger, 1.5" .120 wall DOM Chromolly
1.25" seat riser (aluminum block with a hole drilled thru it)
Custom built hard trail doors 12 ga Chromolly (stripped the canvas off a set of spice Bestop doors and welded the chromolly plate to them, then had them powder coated satin black)
Here's a pic of the doors
Now here's where we went from cool to COOL:
(5) 15x8 pro Comp 98 series wheels
(5) 35x12.5-15 pro Comp Mud Terrains
1" wheel spacers
4:88 gears front and rear (Advance Adapters)
MCE Flattie Fenders
LED blinkers under the headlights
JKS ACOS set at 3/4" (front only)
This is how "Runt" looks now.
Durring all this I found my "easter-egg" While doing the rear gears, we discovered there was a "S35" kit in the rear, not a supirior one, but better than stock for sure, My D35 has 30 spline Alloy USA axle shafts in it. pretty neet!
I've also done the maintenance/replacement parts that come with a 12 year old vehicle with 106,000 on the clock...
new battery
exhaust manifold
tranny mount
brakes/pads
radiator
thermostat
oil pan
Next week I'm installing:
SYE
Drive shaft
adjustable upper rear control arms
Under Cover Fabworks Deep cover skid plate system with LOPRO mount (should add ~2" clearance and cover my unders)
Future mods:
real Superior S35 w/ARB and truss work
Superior S30 w/ARB
Fuel tank skid
Full corners
Sterio system
So I've got a 2.5" lift with 35s stuffed under it, that articulates pretty darn good.
"Runt" handles all the trails in SoCal with only one mishap so far (locker creap put me on my side, cosmetic damage only)
More updates as they happen...
What do you guys think of my LCG build?
Dirt22 is offline
post #2 of 650 Old 08-25-2010, 10:59 PM
apfroggy0408
1982 CJ7
Wow awesome job with the doors they look like something you would buy off a website!
apfroggy0408 is offline
post #3 of 650 Old 08-25-2010, 11:02 PM Thread Starter
Dirt22
Thanks, It was realy pretty easy, a little plasma cutting - a little welding... the powdercoaters did the hard work. LOL
Dirt22 is offline
post #4 of 650 Old 08-26-2010, 06:40 AM
the_art_of_desi
I like the look of 35's on a 2.5" lift. Do you rub in the back or have you adjusted your bumpstops to suit?
1997 TJ SE - Emeral Green Pearl
2.5L : AX-5 : NP231, D30HP : D44 : 4:88 : Front Aussie
2.5" OME lift, OME LT shocks, 2" BL, Currie Control Arms, Currie HD Steering, Currie Trackbars, Warn M8000
Custom Front and Rear Bumpers, Custom Rock Sliders, OBA
33" x 12.5" x 15" Goodyear MTRs, Black Steelies
the_art_of_desi is offline
post #5 of 650 Old 08-26-2010, 07:21 AM Thread Starter
Dirt22
I rub just a little. Once I get the SYE etc in I'll be installing the ACOS on the rear as well. I didn't put it in yet because my driveline angles are already bad... I only have 2 spare u-joins and don't like changing them while laying on the rocks.
Dirt22 is offline
post #6 of 650 Old 09-05-2010, 10:06 AM Thread Starter
Dirt22
Installed:
New rebuilt TC with HD chain, bearings, seals, etc.
Adjustable rear upper control arms (pro-comp)
Adjustable rear track bar (Teraflex)
SYE (Currie)
rear shock mount adapters (Teraflex) - So the shocks don't hit the spring seats when the axle is clocked upwards
This is in prep for my undercover fab works full skid and LOPRO tranny mount that UPS has and can't seam to get on a damn truck... my wife spent a total of 45 mins on the phone with them trying to figure out where the heck my skid is... they still don't know
Dirt22 is offline
post #7 of 650 Old 09-05-2010, 10:22 AM Thread Starter
Dirt22
I installed the ARCOS on the rear and didn't like them. The rear end was slightly higher than the front with them bottomed out.
I could have leveled the heep out by raising the front, then I figured that'd kinda be cheating. If I wanted a higher lift, I should put on a higher lift.
Dirt22 is offline
post #8 of 650 Old 09-06-2010, 02:53 PM
Boostmonkey
By "sh!ttybuilt front bumper" do you mean junk or that it is a Smittybilt bumper that is junk?
Boostmonkey is offline
post #9 of 650 Old 09-06-2010, 03:12 PM
Imped
Imped's Avatar
For some reason, your control arm angles (and driveline angle) looks incredibly high....way more than 2.5". Like 4-5". Just saying.
OlllllllO
IndyORV
Imped is offline
post #10 of 650 Old 09-06-2010, 03:21 PM Thread Starter
Dirt22
Lets just say I'm not a huge fan of smittybuilts welds, their hole alignment, their missing hardware, or their habit of breaking rear tire carriers on the trail.
Before I got the Rampage rear tire carrier I had a smittybuilt one, One of my wheelin buddys had the same one with a 30" tire (i had a 32" at the time) and we both broke them at the spindle. (crap welds, too hot, not enough fill, and too thin of material - I think they use sub standard mild steel in china) also the bolt holes had to be ovaled out to fit, and they were missing hardware. The front didnt fit much better.
I have a smittybuilt XRC winch that so far has worked fine, but hasn't been used much. I had a smittybuilt bikini top... fit like crap.
They all fit my budget at the time, but if I had waited and bought good stuff to begine with instead of buying cheep then upgrading, I'd have saved a bit of $$$
Bottom line is: You get what you pay for.
Dirt22 is offline
post #11 of 650 Old 09-06-2010, 03:23 PM Thread Starter
Dirt22
You talking about this pic?
heh, might be because it's up on a lift...
Dirt22 is offline
post #12 of 650 Old 09-06-2010, 03:25 PM
Imped
Imped's Avatar
Yes I am.....that explains that.
OlllllllO
IndyORV
Imped is offline
post #13 of 650 Old 09-06-2010, 03:57 PM
kyle_craig
Cool Jeep! Subscribed...
kyle_craig is offline
post #14 of 650 Old 09-06-2010, 05:03 PM
bandit455
how do you like the currie tail shaft conversion? my re hack and tap fits loose on the output shaft and causes things to oscialate, im looking at other sye's and the currie would be great since my new tom woods driveshaft has the 1310 cv flange mount. do you have any issues with yours?
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #15 of 650 Old 09-06-2010, 06:20 PM Thread Starter
Dirt22
Thanks man!
Dirt22 is offline
My TJ "Build" Thread MXCarson92 Jeep Builds 46 03-22-2011 10:14 PM
"Get your damn Jeep" Build thread Toedwy Jeep Builds 25 07-09-2010 08:11 PM
00CherokeeXJ14 Project "Xtreme Urban" Build thread 98GooseXJ14 Jeep Builds 15 02-26-2010 10:27 PM
"Om Nom" build thread hyperboarder Jeep Builds 28 10-07-2009 09:51 PM
The "I'm finally back in the jeeping world" thread... Fernman Jeep Builds 4 03-15-2009 03:56 PM
