Diesel Cummins 4BT TJ - Page 7 - JeepForum.com
post #91 of 175 Old 04-26-2010, 01:17 PM Thread Starter
doc_dyer
Originally Posted by Special_Z28 View Post
Lookin good! I always thought Jeep should have offered a diesel motor option from the factory..this is on my list for when the I6 dies..or an LSx.
How's the diesel sound when the tops off cruising?? I think it may get annoying after a while..DDing it. I'm not too picky tho.
if you are running normal it is very quiet,
however if you have to get on it, it becomes VERY loud, but that is partly due to the fact that the exhaust points down before the rear axle, if I were to extend the tailpipe further out the back it is fairly quiet
doc_dyer is offline
post #92 of 175 Old 04-26-2010, 01:18 PM Thread Starter
doc_dyer
Originally Posted by Chester405 View Post
I've been dreaming of a diesel swap ever since I have heard of it. Do you think that the 32RH would handle the 4BT?
biggest problem you will have is finding someone to make a custom
torque converter for it.
and I would go for one with overdrive
doc_dyer is offline
post #93 of 175 Old 04-26-2010, 01:21 PM Thread Starter
doc_dyer
Originally Posted by SaxManClay View Post
Great looking build! I'm actually saving up for this swap myself!
I was wondering, did your front springs sag at all after the swap? If so, how much?
well on my web page it shows that I built from parts soooooo...
I have no idea of what it was before the "swap" since I never had the old engine or tranny installed in the jeep for a height reference..
Bradley
doc_dyer is offline
post #94 of 175 Old 04-26-2010, 01:23 PM Thread Starter
doc_dyer
Originally Posted by baron View Post
What is the weight difference between the 4.0 & 4bt
i believe that someone once said that you could put a 4.0 and a 2.5 in for the same weight as the 3.9 4BT
but I have no clue...I do know it is HEAVY...
as per page 2 of this thread
Cummins turbo engine measurement table:
........................B3.3.................QSB3. 3.............B3.9.................B5.9
Advertised HP....75-85...............90-110.............110-125...........150-173
Peak Torque......193-215............274-304...........346-373............453-580
Length (inch)....28.1..................27.7.............. ...30.6.................40.0
Width (inch)......21.9.................24.3............. ....24.6.................24.9
Height (inch).....31.4.................29.9.............. ...37.7.................37.9
Weight (dry).....553 lbs.............585 LB
Weight (wet)............................................. .......745-782 LB.......952-997 LB
# of cylinders....4......................4............. .........4......................6
doc_dyer is offline
post #95 of 175 Old 04-26-2010, 04:55 PM
green89yj
Wow. I just did a 4.0 swap and I thought it was almost too complicated and it was from a Jeep vehicle. I can't even imagine swapping something as complicated as a diesel that wasn't even from a Jeep.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #96 of 175 Old 04-26-2010, 06:50 PM
baron
Did you use a custom spring rate to make up for the extra weight?
2007JK2DR
99TJ4.0L
baron is offline
post #97 of 175 Old 04-26-2010, 08:51 PM
BigOrange90YJ
diesel is definitely easier to setup after u get the few custom pieces made. These old diesels dont really have any wiring to do, no computer. kind of plug and play once u drop it in.
Currently Jeepless, if you get too frustrated with yours I'll take it off your hands.
BigOrange90YJ is offline
post #98 of 175 Old 04-26-2010, 09:01 PM
Renegade88
Awesome, from the 4bt to the paint love the whole jeep man,
2006 LJ
PanhandlePierFishing.com
Renegade88 is online now
post #99 of 175 Old 04-26-2010, 11:59 PM
ocTJ
and it's powerful plug n play with the right fuel pump etc
"People most often miss opportunity because it is dressed in overalls and disguised as work." Thomas Eddison
2002 Apex Jeep TJ Lifted, Locked, geared and ready for more
ocTJ is offline
post #100 of 175 Old 04-27-2010, 05:35 PM
rattlewagon
2010 JK Wrangler
For what you gave for the truck, after jerking the engine out you could scrap the rest of the truck and probably break even or better!!!
Nice job!
rattlewagon is offline
post #101 of 175 Old 04-27-2010, 05:38 PM
SaxManClay
Bradley
Sorry, I should have looked more carefully.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #102 of 175 Old 04-28-2010, 04:26 AM
HilltopperYJ
throw a stack on it like rrbgtt did
i wana see this bad boy blow some SMOKE
K Σ
A-E-K-Δ-B
ΜΟΛΩΝ ΛΑΒΕ!
HilltopperYJ is offline
post #103 of 175 Old 04-28-2010, 11:45 AM
apfroggy0408
1982 CJ7
This.
apfroggy0408 is offline
post #104 of 175 Old 04-29-2010, 05:47 AM
HitmanJustin
Dunno if you put this project on hold or what, but I think its time for a new video of it haha
HitmanJustin is offline
post #105 of 175 Old 04-29-2010, 06:39 AM Thread Starter
doc_dyer
no more video yet,
project done... it is my DD and I love it
doc_dyer is offline
CJ7 4bt Cummins swap medunwoody Jeep Builds 8 05-06-2014 01:20 PM
diesel story: 81 CJ 2.5td pazur Jeep Builds 12 08-06-2010 04:45 AM
95' diesel YJ rrbgtt Jeep Builds 17 04-22-2009 04:44 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
my Turbo Diesel J53 crusher Jeep Builds 6 08-24-2004 09:42 PM
