Diesel Cummins 4BT TJ - Page 2 - JeepForum.com
post #16 of 175 Old 02-16-2010, 12:31 PM
jforse
Cummins turbo engine measurement table:
........................B3.3.................QSB3. 3.............B3.9.................B5.9
Advertised HP....75-85...............90-110.............110-125...........150-173
Peak Torque......193-215............274-304...........346-373............453-580
Length (inch)....28.1..................27.7.............. ...30.6.................40.0
Width (inch)......21.9.................24.3............. ....24.6.................24.9
Height (inch).....31.4.................29.9.............. ...37.7.................37.9
Weight (dry).....553 lbs.............585 LB
Weight (wet)............................................. .......745-782 LB.......952-997 LB
# of cylinders....4......................4............. .........4......................6
Links:
B3.3:
http://www.cummins-sp.com/document_l...ec%20Sheet.pdf
http://www.cummins-sp.com/document_l...20Brochure.pdf
QSB3.3:
www.everytime.cummins.com/assets/pdf/4087118.pdf
B3.9:
B5.9:
www.everytime.cummins.com/assets/pdf/4087025.pdf
Phoenix Casting for adapters:
www.phxgrp.com
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #17 of 175 Old 02-16-2010, 01:38 PM
LKrux
wow that looks awesome. i wana see it run
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
post #18 of 175 Old 02-16-2010, 01:42 PM
jondotcom
Originally Posted by doc_dyer View Post
well aware of the problems with the axles.
but this is what I have for now...
still looking for a good deal on some 44s at least
You'll be grenading 44s left and right with that kind of torque.
It will take time to restore chaos- GW Bush
jondotcom is offline
post #19 of 175 Old 02-16-2010, 01:51 PM
geewally9
Sick lookin jeep. What part of East TN are you in?
1988 YJ 32x11.50 (Sold)
1987 XJ 3.5 RE super-ride kit. 31x10.5 (Totaled, someone ran a stopsign)
1995 XJ 3.5 RE super-flex kit. 31x10.5 (Brother Flipped)
2001 XJ CRAPPY ABS (Sold)
1998 XJ RC 6.5. 31x10.5. (Sold)
(Current)1996 XJ 4.5 RE super-flex kit. 33x10.5 (Locked and loaded) All were DD
geewally9 is offline
post #20 of 175 Old 02-16-2010, 01:54 PM Thread Starter
doc_dyer
knoxville area
doc_dyer is offline
post #21 of 175 Old 02-16-2010, 01:56 PM
LKrux
theyll last for a little while..haha.
instead;
maybe you could get lucky and find axles off a diesel truck and fab away
LKrux is offline
post #22 of 175 Old 02-16-2010, 02:42 PM
jakeWI
that looks real good. finally someone that is actually doing a swap like that. not saying you are the only one, but to be honest I have only heard of people dreams builds putting that motor in there.
wi4x4.com
naxja.org
Jeep Build
jakeWI is offline
post #23 of 175 Old 02-22-2010, 08:21 AM Thread Starter
doc_dyer
doc_dyer is offline
post #24 of 175 Old 02-22-2010, 09:20 AM
srmitchell
So you really figured out how to get the gauges to work? sweet.
I work on Mopars
srmitchell is offline
post #25 of 175 Old 02-22-2010, 09:25 AM Thread Starter
doc_dyer
all but the tach
and there is some info on the web about it.
I have a 4 cyl harness and computer so... the stock flywheel has 4 notches 20 degrees apart then 180 degrees another set of 4 notches...
since the 4cyl tops out at 5 and redlines at 6... the 4BT as of now its max is 2500 or HALF of 5000....
so if I trick the computer into thinking that the motor is turning twice as fast as it is then at 2500 rpm of the motor the dash will show 5000 or the full range of my gauge.
but there is no room on the flywheel... so will use the bottom pully of the 4BT to make my notches
doc_dyer is offline
post #26 of 175 Old 02-22-2010, 09:31 AM
EaglesSJ
EaglesSJ's Avatar
Love the choice in color! I would have really rethought the whole 6 speed tranny though. I have one and I can tell you right now that they suck. There are lots of problems out there about them popping out of gear and such.
EaglesSJ is offline
post #27 of 175 Old 02-22-2010, 09:34 AM Thread Starter
doc_dyer
I have a AX-15 for backup if the 6 croaks out.
doc_dyer is offline
post #28 of 175 Old 02-22-2010, 10:41 AM
ratster
Sweeeeeet.I'll be on the lookout for ya.
ratster is offline
post #29 of 175 Old 02-22-2010, 05:13 PM
belyeujon
2005 WK
This thing is gonna have some tourque! id love to see some vids when its all ready! looks great by the way.
*High School Jeepers Member #270* *WK Owners #38* *Alabama Jeepers Member #42*
belyeujon is offline
post #30 of 175 Old 02-22-2010, 05:23 PM
stoplocknroll
what are you talking about? 350-400lbs of TQ is not going to "GRENADE" a D44
stoplocknroll is offline
CJ7 4bt Cummins swap medunwoody Jeep Builds 8 05-06-2014 01:20 PM
diesel story: 81 CJ 2.5td pazur Jeep Builds 12 08-06-2010 04:45 AM
95' diesel YJ rrbgtt Jeep Builds 17 04-22-2009 04:44 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
my Turbo Diesel J53 crusher Jeep Builds 6 08-24-2004 09:42 PM
