Diesel Cummins 4BT TJ - Page 12 - JeepForum.com
post #166 of 175 Old 07-18-2011, 11:39 AM
sesarz
WOW. Your jeep is awesome, I would like to see it someday if possible.
http://www.chopshopoffroad.com
sesarz is offline
post #167 of 175 Old 01-04-2013, 02:00 PM
BHaner
Originally Posted by doc_dyer View Post
used in a fritolay truck
if you have a manual transmission,
all you need to do if fab a motor mount and get an adapter from Novak, a little wiring and your done
Starting about the same project on my jeep at this time.
Can you tell me more about the adapter to make the NSG370 fit the 4BT?
What version of 4BT did you use? The Ford or GM?
Does the Novak adapter bolt directly to the 4BT block or use the bell housing adapter plate that came with the truck?
What did you use for a clutch and flywheel?
I am not able to view your pictures on the apple website BTW. Do you have them posted somewhere else?
Thanks!
Byron Haner - Wickersham, WA
2005 Jeep Wrangler Rubicon - Electric Green - 35x12.5R15 Goodyear Kevlar MT/r's - 6 Speed Manual
RE 5.5" LA Tri-Link - MC Rockers
BHaner is offline
post #168 of 175 Old 01-04-2013, 02:08 PM Thread Starter
doc_dyer
the adapter is a 1/2" plate of steel CNC cut
it bolts to the gm adapter housing
yes, when you order you adapter BE SURE TO TELL THEM to
put in the 10 degrees or so to level the engine to transmission
your gm adapter tilts the motor in the stepvan to clear the throttle linkage or something like that.
I used a 1966 Corvette clutch I will try to find a number for you
yea they did away with the free web hosting on apple
sorry bout the pics
doc_dyer is offline
post #169 of 175 Old 01-04-2013, 02:16 PM
BHaner
sorry bout the pics
Awesome. Thanks for the reply.
I had been reading that with the GM adapter you were not able to run the AC compressor due to the twist. Good to know that the adapter plate can remove that offset.
Was there a clutch to flywheel adapter as well?
BHaner is offline
post #170 of 175 Old 01-04-2013, 03:04 PM Thread Starter
doc_dyer
clutch bought at big box store.. auto zone, advance...etc
www.perfectionusa.com
MU5505-1
EDIT: no adapter this is a chevy clutch going on a chevy/cummins flywheel
doc_dyer is offline
post #171 of 175 Old 01-04-2013, 03:16 PM
BHaner
Thanks!
BHaner is offline
post #172 of 175 Old 01-04-2013, 03:41 PM
BHaner
What shaft size was the NSG370?
It lists a few different ones with that part number.
BHaner is offline
post #173 of 175 Old 01-04-2013, 08:12 PM
Ggg
Advanced Adapters makes bellhousings that will adapt the Jeep transmissions to either the Ford or Chevy bolt pattern flywheel housings. They also make an adapter plate so you can adapt the Jeep transmissions to Ford or Chevy bellhousings.
Ggg is offline
post #174 of 175 Old 12-29-2013, 08:06 AM
Mack4
Why did you not use the ax15, or thenv4500
Mack4 is offline
post #175 of 175 Old 12-29-2013, 04:10 PM Thread Starter
doc_dyer
Because I wanted the 6 speed
Newest tranny used in new JKs
doc_dyer is offline
CJ7 4bt Cummins swap medunwoody Jeep Builds 8 05-06-2014 01:20 PM
diesel story: 81 CJ 2.5td pazur Jeep Builds 12 08-06-2010 04:45 AM
95' diesel YJ rrbgtt Jeep Builds 17 04-22-2009 04:44 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 03:28 PM
my Turbo Diesel J53 crusher Jeep Builds 6 08-24-2004 09:42 PM
