Diesel Cummins 4BT TJ - Page 11 - JeepForum.com
post #151 of 175 Old 02-28-2011, 09:27 PM
CMOfoSHO
Im droolin right now!!!!!
CMOfoSHO is offline
post #152 of 175 Old 03-01-2011, 08:56 PM
redjeep1992
hey man this is an awesome build i have been looking at diesel build to see which one will fit best when my 2.5L craps out and this looks like a match
2004 Jeep TJ Rubicon- 2"BB with 32" tires- 2nd jeep (current)
1999 jeep TJ SE-1st Jeep. Sold but not forgotten
1991 nissan axxess-First vehicle RIP
redjeep1992 is offline
post #153 of 175 Old 03-01-2011, 10:56 PM
Ggg
I have been very happy with my own TJ/4bt. I will say because you have a 2.5l your trans will be too weak for a 4bt. I used my stock AX15/231 and so far so good. There is a lot of info on the 4btswaps site, several of us have done Jeep/4bt swaps and have lengthy build threads.
Ggg is offline
post #154 of 175 Old 03-01-2011, 11:03 PM
Mudmouse990
ok first i apologize for being lazy i looked throught the first four pages of the thread and awsome jeep but my question is how is highway driving what type of speed can you maintain and what type of acceleration does the 4bt have? thanks in advance once i get a dd im going to be doing a swap and this is an option
90 yj 2.5l or pure power,thrush turbo, gutted cat, RC 4in lift,1" boom shackles, 33" BFG A/T's, outlaw alum rims,Rhino lined interior,overhead lights,connex 3300 cb, Homemade disco's, no rear trackbar
future mods- diamond plate rocker gaurds, fold down bus steps,home made front and rear bumpers , tube fenders, paint my doors red,possibly a winch, 302 ford or a 350 chevy, ford 8.8, cv style shaft and much more
Check out my build thread
My Home made Quick Disconnects Write up
Mudmouse990 is offline
post #155 of 175 Old 03-01-2011, 11:11 PM
Lucky313
i must say, this build turned out awesome, love the paint and the swap and i am SUPER jealous cause i've wanted to do this swap for months but haven't had anywhere near the money and/or time to do it. major props to you my friend, hope it's working out awesome for ya
'95 Yj Rio Grande - 4 cyl., Rough Country 2.5" lift, 33x12.5R15 Cooper Discoverer STTs, 2 KC 6" Apollo Long Rang lights, 2 KC lights, Herculiner interior, etc.
Demain N'est Jamais Promis
- Lucky13 -
Quoted from
: "When I die I hope my wife doesnt sell my toys for what I told her I paid for them"
Originally Posted by XJAbuzer View Post
My girlfriend asked me how fast it would go. I replied with "Not fast enough......to get it to the junkyard."
Originally Posted by Joe203 View Post
You know you own a YJ when nothing goes as planned.:D
Lucky313 is offline
post #156 of 175 Old 03-01-2011, 11:30 PM
Deacon
Deacon's Avatar
That's going to depend quite a lot on tire size, gearing, and to some extent weight, don't you think?
Deacon is offline
post #157 of 175 Old 03-02-2011, 12:40 AM
Ggg
They will maintain 70 mph with proper gearing and overdrive, I believe mine will top out at about 60-65 due to rpm not lack of power. Economy depends a lot of the condition of the engine, gearing, weight, etc. I have no idea what mine gets for mpg because it is too high to be street legal, I built it for the trails. But I have gone out winter wheeling 5 times (full day trips) so far and have only used about 4 gallons total.
Ggg is offline
post #158 of 175 Old 03-02-2011, 08:14 PM
redjeep1992
i have read this thread i know if i put that engine with everything that i have stock it will blow up if i do this what i plan to have dana 44 front and rear 4.56 gears ax-15/231 combo so
post #159 of 175 Old 03-02-2011, 11:21 PM
Ggg
To me that sounds like a good combination, If you can get a better rear like a 8.8 or better yet a 9" I would. Just don't use the junk Rubi D44 front axle, use a true D44 out of a Ford to keep left side pinion, and get high pinion as a bonus. I am running a D60 front and a Sterling 10.25 rear axle but I also have big tires. Speaking of which what size tire are you running with a 4.56 gear? That is a good gear for about a 44" tire.
Ggg is offline
post #160 of 175 Old 03-03-2011, 01:18 PM
redjeep1992
i was hoping to use like a 33 or 35 inch tire with a 4 inch life with MML and BL so i guess a 4.10 maybe a better gear ratio but this is an after college build so hopefully i will have more info about this
post #161 of 175 Old 03-03-2011, 02:48 PM
Ggg
For 33" tires you will want to run 3.54, and for 35" tires a 3.73 would be best with a 5 speed trans and 65mph highway.
You want your highway RPM to be between 1800-1900 for best fuel economy.
A 4" lift and 1.5" BL is a lot of lift for that size of a tire. I didn't need any BL for mine to fit, I trimmed the pinch welds a little where the floor meets the firewall. As far as MML goes don't even worry about it. You will need custom engine mounts and the stock brackets will get cut off the frame to make room for what needs to be fabricated.
Ggg is offline
post #162 of 175 Old 03-03-2011, 08:57 PM
redjeep1992
thanks this is really helping me this is a build that I am interested in but i hope to do this after college and after i find a little DD while i work on the jeep so the only thing that I am really worried about is the wiring I should be able to do everything else hopefully lol
post #163 of 175 Old 04-11-2011, 06:14 PM
spiderman637
I am looking into this swap and I was curious as to your transmission choice. Does the NSG has to lower top gear (numerically speaking)? The adapter from Novak is almost $300 and I have seen diesel NV4500's for about the same price. Since the diesel NV4500 was bolted up to the 6bt, wouldn't I be able to bolt it up to the 6bt? I believe the transfer case splines are different but I could either swap that out or go with a np241 (haven't gotten that far into that aspect of it yet)and (famous last words) it shouldn't be too much harder or a swap with a stronger trans, right?
Friends help you move, good friends help you move bodies
spiderman637 is offline
post #164 of 175 Old 04-11-2011, 06:15 PM
spiderman637
I meant a better overdrive ratio, just to clarify.
post #165 of 175 Old 04-11-2011, 06:29 PM
Ggg
The NSG370 has a 0.84 OD ratio, the AX-15 had a 0.74 OD ratio, and the NV4500 has a 0.73 OD ratio.
Ggg is offline
CJ7 4bt Cummins swap medunwoody Jeep Builds 8 05-06-2014 02:20 PM
diesel story: 81 CJ 2.5td pazur Jeep Builds 12 08-06-2010 05:45 AM
95' diesel YJ rrbgtt Jeep Builds 17 04-22-2009 05:44 PM
Jeep ZJ with a 5.9 Cummins Diesel tomiko Jeep Picture Requests 5 01-18-2009 04:28 PM
my Turbo Diesel J53 crusher Jeep Builds 6 08-24-2004 10:42 PM
