Dbl's Newb Build - All Suggestions and Opinions Welcomed... Even You Imped :-) - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Dbl's Newb Build - All Suggestions and Opinions Welcomed... Even You Imped :-)
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-18-2011, 03:33 PM   #16
dblplay1212
Originally Posted by Ripper3494 View Post
http://eastcoastgearsupply.com/i-132...ars-yukon.html
gears can be found for a pretty wide variety of prices some higher than this some lower. if your friends can do gears thats a big help, they're not terribly hard but some shops will charge you out the *** for it. it depends on what kind of shape you find the axle in, if you find one with good bearings, rotors. basically if stuff works it'll be easier on you. and cheaper. id say 2000 per axle including purchase and gears would build you a pretty serious set. give or take a few hundred. brackets aren't real expensive, you can find brackets for both axles for probably around 400. you'll save quite a bit of money if you do 44s, parts are cheaper but also they're not near as strong. if you want to make a 44 as strong as a 60 you'll be spending about even, maybe even a little more on the 44 because hardcore axle shafts aren't cheap
Decision, decisions. Still leaning towards the 60's. The extra money now can save me a swap later. That's a win in my book.
Plus the 60 looks cool with the huge diff cover.
dblplay1212 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 03:36 PM   #17
dblplay1212
and the highline kit looks like it can probably be installed pretty easily in your garage
I was just looking at that, too, and I agree with you. Will definitely put that on in a buddy's garage. Obviously paint is going to be the expensive part there. The hood and all 4 corners have to be painted. At that point, might as well go ahead and paint the whole damn Jeep. Already checked on the Sahara badging, too. Damn Sahara stickers are like $58 each.
Unread 07-18-2011, 04:00 PM   #18
Ripper3494
I recently bought an hvlp gun, high volume low pressure, from harbor freight for around 30 bucks, painting isn't hard, I painted my metal cloak fenders and corners and it turned out pretty decent. But if ur not comfortable painting a body shop is deff your best bet
Sent from my DROIDX using JeepForum
build thread:
[url]http://www.jeepforum.com/forum/f22/94-yj-6-0-build-spud-1218315/[/url]
1997 ZJ limited - BONE stock
[url]http://www.jeepforum.com/forum/f12/alternator-welder-write-up-1301614/[/url]
[url]http://www.jeepforum.com/forum/f12/tj-uppers-yj-half-doors-hard-top-installation-1417686/[/url]
RC vs BDS
[url]http://www.jeepforum.com/forum/f12/rough-country-vs-bds-1461555/[/url]
Ripper3494 is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 04:07 PM   #19
dblplay1212
haha. Yea, I'm not even going think about thinking about trying it.
Unread 07-18-2011, 05:01 PM   #20
Ripper3494
http://eastcoastgearsupply.com/i-686...4-5-5x5-5.html more food for thought
build thread:
RC vs BDS
Unread 07-18-2011, 05:49 PM   #21
dblplay1212
Yea, checked those out previously. $3k+ with gears and a locker. Ouch.
Unread 07-18-2011, 07:25 PM   #22
Hendrix
TJOTY 2013
Hendrix's Avatar
Check out some JK Rubi 44s if you want a nice axle that is locked and great for 37s. You will not lose all that ground clearance as with 60s. And it makes a great DD. BTW they are not your everyday D44s. Much stronger and bigger than the previous Rubi D44s.
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 07:32 PM   #23
dblplay1212
How do they width-wise compared to the 60? Do they have to be cut down, too?
Unread 07-18-2011, 07:38 PM   #24
jforse
Nope. Run them stock width. Use a sleeve kit, c-gussets, and a truss of some sort for the front. Truss the rear. Check out Hendrix build he has JK RUBI 44's.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 08:31 PM   #25
dblplay1212
Awesome. Will check it out now. Thanks for the suggestion.
Unread 07-19-2011, 07:38 AM   #26
dblplay1212
Going to put about $3k into this build at the end of this month. Thoughts on where I should spend it? I was thinking buy the AEV Highline kit. Thoughts? Or should I just bank all the cash and buy it all at one time? Sorry, first time doing this so not sure the best way to go about it, if there is one.
Unread 07-19-2011, 07:50 AM   #27
Imped
Imped's Avatar
Even me?
I'm diggin the tune upgrades. I miss my bass. One of these days I'm gonna try to come up with a center console woofer/amp. Everything needs to be completely hidden, though. As for the future plans, looks good. Keep on wheelin.
And as for where you should put your money, that's up to you. I'd start on beefing up the weak or vulnerable areas. Steering, namely the tie rod. Steering box and oil pan next. Rocker guards and gas tank skid after that in terms of importance. First figure out where you want to be in terms of tire size, axles and wheelbase and go from there. If you're going 35-37" tires, don't bother with the ZJ tie rod IMO. Just go straight to Currie. If you're going with non-stock axles, don't buy Currie since you'll have to build custom steering anyway. Just go through that kind of process and you'll figure **** out.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 07-19-2011, 08:33 AM   #28
dblplay1212
Even me?
Yea, even you.
Hmm, hadn't thought about that direction, honestly. With my wheelin being relatively light, I was thinking highline and lift > tires and wheels > axles > brakes > steering/skids etc. The rocker guards 1st isn't a terrible idea, though. I say that bc I hate the look of the current steps and the rocker guards I have planned is probably what I'm looking forward to most.
I'm going to have a local shop fab them up for me. I want to keep my Sahara bubble panel on the side. I know the hardcore wheelers will laugh, but I like the way it looks. I had a picture in my head for 15 years of what this Jeep looked like on the lot (i went twice a week to look at jeeps as a kid) and I want to stay relative true to form of what I always wanted. I want the traditional look, but I want more than just protection from them. Basically, I want this:
but it will have to be shaped to hug the body line of the Sahara. Instead of folding down and under, I want them to fold from a rocker position to a step. Fiance is short and needs the step to get in and it's only on 31's. Basically the opposite of this:
I suppose I could do that and the skids while I'm eating away the meat on my 31's. They only have about 12k miles on them now and I wouldn't be opposed to eating them up some more before taking them off. Maybe even do bumpers, too. Damnit Imped, I knew inviting you in would turn this build upside down.
