Dawg's TJ build thread - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Dawg's TJ build thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 01-30-2014, 09:55 PM   #1
Thedawgshow
Just purchased my 1997 TJ Sport this past December and now it is time to start building her up. A one owner with only 80K miles. Soft top and half doors with the 4.0L in line 6 and 3 speed auto.
The previous owner is an older gentleman who is a mechanical engineer, so he took pretty good care of her. He did some modifications himself,( new shocks w/ about 3/4" lift, stainless steel brake lines, new radiator, tires, wheels, brakes and more. Downside is I really do not know all of what he had done yet. I know he did not change axles, gears or anything like that, so most of this jeep is stock and most of what he has done was just maintenance.
So anyway, I am not sure where to start. She does have some problems. A slight wobble at take off, and a sort of grind when I turn my wheels hard right both forward and reverse. I think I will start there, and have no idea what I am in for.
I will get pics of her on here soon!!!
This is sure to be a great adventure and I can not wait to get started!!!
DAWG
My pappy was a pistol, I'm a son of a gun.
Thedawgshow is offline   Reply With Quote Quick reply to this message
Unread 01-31-2014, 09:21 PM   #2
Thedawgshow
I went to a 4X4 Parts store and looked around for ideas yesterday, and maybe left there even more confused on what to do to my TJ. Since I am not really a mechanic or tech, so many things that I read or look at, I just don't understand. I do know that I need to get her on a lift and do some serious snooping around underneath. I think the first things I need to do are all service related, like change all the fluids like transfer case, axles, transmission, oil and such. Hmmmmmmmm, I bet there might even be some grease fittings under there.
DAWG
Unread 02-01-2014, 05:43 PM   #3
DKenyon28
DKenyon28's Avatar
Definitely start with the fluid and regular maintenance. Then wheel her a bit to help decide how you want your Jeep to ultimately end up.
DKenyon28 is offline   Reply With Quote Quick reply to this message
Unread 02-01-2014, 07:56 PM   #4
Cuder
That's great advice. After reading on here for awhile you will see where you want to go with it also. Is the steering wheel wobbling on take off? Does the shifter move any on take off?
A lot of times the rubber in the axle bushing of the trackbar and the transmission mount will deteriorate on older Jeeps and let things move when it shouldn't.
My Build Thread:
http://www.jeepforum.com/forum/f22/c...-lift-1268317/
Cuder is offline   Reply With Quote Quick reply to this message
Unread 02-02-2014, 02:52 PM   #5
Thedawgshow
Great advise for sure and thanks DKenyon28 and Cuder!!!
As far as the wobble, the steering wheel doesn't wobble, and the shifter is automatic, but I can feel it and here it. Not a hard wobble and only on take off for just a moment.
I am headed outside right now to figure out what gears I have and such and take my first pictures of her to post on here. I really like the forum and there seems to be so many friendly, knowledgeable people on here!!! Jeepsters are such AWESOME people.
Not sure if I want to do it, but the first thing I might do after the fluids and such might be taking off the "milk jugs".
DAWG
Unread 02-02-2014, 03:29 PM   #6
Thedawgshow
WOW!! Just crawled under the TJ and is she rusted. All over under there.
DAWG
Unread 02-02-2014, 04:30 PM   #7
DKenyon28
DKenyon28's Avatar
If it is mostly surface rust you can just take wire wheel on a drill to it to clean it up and spray it. I need to do this to mine this spring as well.
Unread 02-02-2014, 04:31 PM   #8
Thedawgshow
Ok.... I now know what axles and gears I have. They are more than likely stock, since the tags are still there. Also updated my jeep info. I do like this whole forum thing. It is really helpful!!!
DAWG
Unread 02-02-2014, 04:33 PM   #9
Thedawgshow
Yes, a lot of it is surface rust, but the floor pans are going to need a lot of love!!!
DAWG
Unread 02-02-2014, 06:05 PM   #10
Thedawgshow
Just took a bunch of pictures of the TJ to post on here but can not seem to get them to download. Uuuuuuuuug!!!!!!
DAWG
Unread 02-02-2014, 08:35 PM   #11
Thedawgshow
Let's try and load these pics this way!!!!
http://www.facebook.com/photo.php?f...type=1&theater
DAWG
Unread 02-02-2014, 09:00 PM   #12
Thedawgshow
http://rs35.pbsrc.com/albums/d182/th...525b6.jpg~c200
DAWG
Unread 02-02-2014, 11:05 PM   #13
Cuder
You need to click the IMG link in photobucket and it will copy. Then right click in the reply window and paste it.
Like this.
My Build Thread:
Unread 02-03-2014, 08:19 AM   #14
Thedawgshow
AWESOME!!!! Thanks Cruder. I was having a heck of a time trying to make this happen.
DAWG
Unread 02-03-2014, 09:53 PM   #15
Thedawgshow
I hope this works, but I was reading that I might have to be a member for a while and have so many posts before it will let me load any pics.
DAWG
