"DAT JEEP" Teenagers Build - Page 6 - JeepForum.com
post #76 of 105 Old 05-27-2013, 09:23 PM Thread Starter
HardworkWorks
Well a few things! I got a bunch of parts ordered so i can get my fuel system done, next my dad and i went to harbor freight and picked up some cheap tools one of which was a 40lb blaster so tonight i droped some 30grit in it and turned it on and holy crap i was amazed it just blasting threw everything its like a dream come true! So next is blasting the bottom of the tub!
HardworkWorks is offline
post #77 of 105 Old 05-30-2013, 08:45 PM Thread Starter
HardworkWorks
Ok so here is some updates! I got my slave cylinder ordered, sending unit ordered, fuel lines ordered, tank straps, exhaust system, and skid. All on the way! Also i was in BMORE for a football combine (won strongest man and got invited to the ultimate 100 showcase met the national record set in 2006 at 29reps at 185 on the bench) and while i was there i went to the harbor freight and spent 500$ between me and the old man. And if you have ever been to a harbor freight you know 500$ is alot to spend there. I got an inline sander a new DA an abrasive 40lb blaster and some Cutt of wheels some spray can under coating a regulator for my air system in my shop 100ft of airlines and to much more to list. The sand blaster has made my life 1000x easier it peals paint and rust off of anything i blasted a whole fender in about 5 minutes my old blaster would have taken about 10hours to do it, and that is no exaggeration. I also am going to pick up some metal to build a front bumper with this weekend because there is no way i am droping 300$ on a bumper i can build for 40$ and some time. So ill post up some pics. Enjoy
post #78 of 105 Old 06-01-2013, 05:48 PM Thread Starter
HardworkWorks
Really getting the the hang of this body work thing!
post #79 of 105 Old 06-05-2013, 10:08 PM Thread Starter
HardworkWorks
Well my exhaust came in and i got some exhaust paint and went ahead and put it on there was really nothing to it. Some bolts a little welding some paint and bang!
image-1852808520.jpg   image-2523879025.jpg   image-3663707483.jpg   image-968288006.jpg   image-1621897669.jpg
post #80 of 105 Old 06-06-2013, 10:48 PM Thread Starter
HardworkWorks
So i have been planning on building my own bumper for a bit now so when i was passing the welding shop today i stoped and got what i needed. I know the guys daughter and he wouldn't let me pay for it which was cool since i am low on cash. Ill be sure to send him a thank you.
post #81 of 105 Old 06-06-2013, 10:52 PM Thread Starter
HardworkWorks
Anyways i got it back to the shop and got it measured marked then started cutting. I ended up with a huge piece because he was out of 4x2 so k got 4x3 but i am glad i did. Anyways got all my pieces cut and cleaned up then welded them on and got one side cleaned up. My buddy who is one of the most im mechanically inclined guys i know was able to teach me how to weld in like 5 mins. I was Absolutly amazed he knew how too. He can't change a light bulb without messing something up but he can weld d&)@ well!
post #82 of 105 Old 06-07-2013, 05:00 AM
iamBostonStrong
Great job man, real inspiration for the younger members aspiring to do their own jeep build. Kudos.
iamBostonStrong is offline
post #83 of 105 Old 06-07-2013, 02:35 PM Thread Starter
HardworkWorks
Ok so here it is finished just gotta die my final install now! Also it is already painted and tapped to put on but forum wouldnt let me upload those files
post #84 of 105 Old 06-07-2013, 06:48 PM Thread Starter
HardworkWorks
So got my bumper totally on now and looking good and my other fender primed up so tomorrow is time to get the grilled totally done!
post #85 of 105 Old 06-09-2013, 09:14 PM Thread Starter
HardworkWorks
Got my grille all blasted, sanded looking good and primed up!
post #86 of 105 Old 06-12-2013, 01:19 PM Thread Starter
HardworkWorks
Got my brake lines all put in, some retains g brackets made and repositioned my pro proportioning valve so its not in the way of my clutch fork also got my fuel i stalled and ready for the tank.
post #87 of 105 Old 06-14-2013, 08:00 PM Thread Starter
HardworkWorks
So here is an update got my new steering box and put it all in with the usual headaches but its in, also i got pics of fuel line and got the steering stabilizer on after basically making the u bolts for it!
image-880084803.jpg   image-3310976176.jpg   image-3642611012.jpg   image-3520543217.jpg   image-3696263382.jpg
post #88 of 105 Old 06-27-2013, 07:56 PM Thread Starter
HardworkWorks
Brickwall! Went to mount up my body today and got it on and all lined up and pretty looking went to start putting the bolts in! And guess what!? The PO decided it would be a great idea to what looks like he ripped the bolts out so every single mount is rusted out and stripped! So i decided to just go up a bolt size re thread the mounts a size bigger and proceed like that so 30$ later for new bolts and washers i will try agian tomorrow!
post #89 of 105 Old 07-06-2013, 07:58 PM Thread Starter
HardworkWorks
Ok so havent posted in awhile so here it goes! First of i have just been introduced to scrap yards and they are full of good finds! So my junk yard finds are. Battery tray retail-100 bought-10+time and paint. Fuel filler and bezel retail-100 bought -15. So i made out good there. Also i worked out all of my mount issues and that is cleared up now that is all mounted up and body work has started. Also got the front end mocked up and aligned which was exciting. Going to be blocking them for paint soon. Also had to cut fenders to fit exhaust but that took about 2 seconds. Also when mounts the grille we had to cut out and remake the mount and breaker that holds it in place so the was frustrating but hey good progress being made! Also as of July third i am a licensed driver! Thumbs up!
post #90 of 105 Old 07-06-2013, 08:07 PM Thread Starter
HardworkWorks
Also since i kinda skipped it ill go over the frame completion! We got the fuel system complete with skid and all we also got the clutch and flywheel all put in and just everything buttoned up! Also thats our redneck car lift!
