#1 | |
The dark side
After stripping my jeep down to this a few months ago, I just picked up a new rig. I always said I wanted to go toyota, so that is what I picked up
Old rigs carcass: ![]() new rig Plans are: switch out the spools for detroits Swap out the 35s for some 37s Roll Cage Bob the bed Front bumper w/ a mount for my winch off my old rig
#2 |
Cool.. least you don't have to fool with the solid axle swap. What axle/springs in the front?
2000 TJ : RK 5.5" X-Factor Long Arm, 1.25"BL/MML, RE Monotubes, RK HD Steering, Warn M8000, Lock-Right D30, Detroit D44 w/4.88's, 35x12.50R15 Pitbull Rocker Radials 1990 MJ : 2.5L, 5spd, 2wd, short bed and bone stock. |
#3 |
here is a photoshop of how the bed should look after we bob it in a few weeks
#4 | |
as for the axle it is a toyota axle out of an 84 pickup. 5.29 gears and 30 spline longfields |
#5 |
nice... from another toy die-hard driving a jeep...
rightcoast4x4.com |
#6 |
That is sweet, you are going to have too hook up with Dave and Javier from Javiers Autos/Gulf Coast Crawl Shop. Javier drives an FJ on 39.5's and Dave is building a Yota buggy on 39's.
And just to drop a shameless plug , here is what you will be leading me around at Trees in when the build is done in a month or two: http://www.pirate4x4.com/forum/showthread.php?t=550186 |
#7 |
This space for rent.
I've always loved the toyota pickups.. pretty much ever since I was little and had stompers.
'97 SE Lockers and stuff |
#8 |
Some Call me RockDog
Here's what you get for going to the dark side...
http://www.youtube.com/watch?v=anxtmHCAb_Q Here's a couple yotas in my club... ![]() ![]() This one's got a 302 ![]() ![]() He built the bed himself.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#9 |
hey man im in austin are you parting with the 35" toyos how much would you want for them and how much tread is left if so
93 yj lifted locked and ready to rock 6.5"soa 35's lockers beadlocks,8.8 and some other junk here and there www.krawltex.com if your in austin look them up best guys to deal with hands down |
#10 | |
#11 | |
I am going to keep them for a little while, I have a few things that need to be done before swapping out the tires. I will post them up for sale on the board when I do decide to unload them |
#12 |
Just violated my Parole
should get Unimog's and run 40's
#13 | |
the beauty of toyotas as compared to jeeps, is that the axles can be built to handle alot of abuse. The only thing I am going to do to the axles is swap out the spools for detroits Plus mogs would be way to heavy |
#14 |
are you going to fix the bodywork? or just leave it as is?
#15 | |
here is what was left of the body of my old rig ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
